ASP/MAGNUM FS400AR Rebuild/Overhaul
Old 10-11-2012, 06:39 AM
  #1276
Carosel43
Default RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
I have the same issue with the esm sea fury (if it ever arrives) as i need to loose 30mm somewhere. As for the D9 you will have to get a video of it! assuming the planets align i may finally get to test fly my P39 this weekend :O
  #1277
retransit
My Feedback: (18)
retransit's Avatar
ORIGINAL: Kmot
Yes Bob I did. [8D]
I had thought about how I should do it, but decided to poll the forums and fortunately it was pointed out to me that I was wrong in my assumptions. [&:]
Once I was straight on what to do it was easy. For my run, I mixed 16 oz of Powermaster 15% nitro, 18% oil fuel with 25 oz of pure methanol. This gave me a blend of about 6% nitro and 7% oil.
Video is finished. Just need to get it uploaded, and figure out the best way to get the article I wrote in PDF format, converted for forum use.
Tom, isn't there a concern about adequate oil? We are, in effect, running five .80 four strokes on a common crankshaft. I know larger displacement engines require less oil content, but this engine should be considered a moderate in size as compared to a single 1.80. Is my thinking flawed?
By the way, I have a fuel mix chart in Excel for mixing ingredients. If anyone needs it, PM me.
Bob
Old 10-11-2012, 06:42 AM
  #1278
Carosel43
the oil requirement for the rings is tiny, and as most of the engine is ball raced i dont think running low oil is a problem. laser engines have been run as low as 5% oil by some customers but there were some seizures on the big end. The big ends on the radial are doing less work as they are not rotating sop should be ok. Also with 5 cylinders feeding one crankcase im sure it wil be ok, especially if the breather nipple is blocked off
Old 10-11-2012, 06:58 AM
  #1279
Reverend
Reverend's Avatar
ORIGINAL: Carosel43
I actually have a video of it. just need to edit it
holding my thumbs for your P-39
FWIW I just found another plane perfect vor the FS400AR...
http://letadla.grapo.cz/
Me likey. Me write email...
Old 10-11-2012, 07:09 AM
  #1280
SrTelemaster150
SrTelemaster150's Avatar
ORIGINAL: Reverend
ORIGINAL: Carosel43
I saw a full scale one of those fly @ Old Rhinebeck Aerodrome back around 1998.
It was built from original drawings W/an original rotary engine complete W/the ignition sequencing engine power control.
This isn't that particular Aeroplane, but it sounds just like the one we saw fly that day.
[youtube]http://www.youtube.com/watch?v=L0-LXM8acEQ[/youtube]
Old 10-11-2012, 08:32 AM
  #1281
retransit
My Feedback: (18)
retransit's Avatar
Not to get off topic, but this should warm your hearts:
http://www.youtube.com/watch?v=6_AchBjjVSM&feature=player_embedded#!
Bob
Old 10-11-2012, 09:12 AM
  #1282
Kmot
My Feedback: (24)
Kmot's Avatar
Check out my review of the Rogeau Intake Manifold for the FS400 engines!
http://www.rcuniverse.com/forum/m_11259030/tm.htm
Old 10-11-2012, 10:04 AM
  #1283
retransit
My Feedback: (18)
retransit's Avatar
Tom, do you have any idea as to the cost of the manifold?
Bob
Old 10-11-2012, 11:07 AM
  #1284
Kmot
My Feedback: (24)
Kmot's Avatar
I am not certain what the current pricing is, best to contact Olivier for the price and shipping details.
Old 10-11-2012, 11:17 AM
  #1285
SrTelemaster150
ORIGINAL: Kmot
Did you see any power loss/gains from the manifold?
Old 10-11-2012, 12:06 PM
  #1286
Reverend
Reverend's Avatar
tom,
great review. just a little dissapointed that you dont have any numbers (rpm, fuel consumption, etc...) in it. You did change a LOT after all. new intake, new fuel, ...
Rev
Old 10-11-2012, 02:29 PM
  #1287
Carosel43
Im loving the WW1 stuff, especially the hilarious noises!:P as for the P39 i was working on it just now and shes ready for engine tests tomorrow. I had to track down a fault in the radio (a cheap inline servo reverser) and had the big job of tidying up all the wires and pipes! if all goes well with the ground runsi hope to fly saturday morning.
Old 10-11-2012, 03:03 PM
  #1288
Kmot
My Feedback: (24)
Kmot's Avatar
Well, I did not compare apples to apples. Last time I ran the engine I used an 18x8 prop. This time I used a 20x10 prop.
Yeah, I suppose I did change a lot. One part, lol.
And actually running less nitro, about 6% versus 15%.
My purpose was to see if the engine would grenade on 7% oil fuel. And it did not. It ran happy. This further proves the concept, and what Olivier Rogeau already has said it will do. Run well using less oil. Keeps your airplane cleaner, which I can now vouch for, and by studying the way it works I can certainly see how it lubricates the rotating mass far, far better than the stock design manifold.
I will do further testing in the future, for my own curiosity. In the mean time, I imagine Mr. Rogeau has all the answers to questions like yours since he did tons of development and testing with it, and has installed several on customers engines. I strongly recommend you contact him for more information. He is a very nice man, very friendly and easy to talk too.
[email protected]
Old 10-12-2012, 01:27 AM
  #1289
Carosel43
Hey guys, I know this is a radial thread, and i dont know if this link will work, but... its Merlin time!
http://www.facebook.com/#!/photo.php?v=478031088885517
Old 10-12-2012, 02:33 AM
  #1290
Reverend
Reverend's Avatar
ORIGINAL: Kmot
Ok, I meant to say you chaged a lot on the intake. completely different way the air/fuel mixture has to take, more turbulence in the crankcase instead of the direct canal to the cylinder, more fuel loss due to the stuff that stays in the crank case, different fuel, ...
If you concider how much 1/8th on the low speed needle can change the running characteristics of an engine I am sure these changes will effect it too.
Rev
Old 10-12-2012, 11:34 AM
  #1291
Carosel43
Ok guys, i got the cobra going. As stated in the video description i have a few issues but nothing to major. You dont have to watch the whole video as i spend most of the time playing with the low end (still not right, i think the tank position is the issue).
http://www.youtube.com/watch?v=mS-F9...ature=youtu.be
Old 10-12-2012, 12:45 PM
  #1292
Kmot
My Feedback: (24)
Kmot's Avatar
Oh, that sounded lovely!!
I dunno Phillip. Olivier claims better fuel economy. I noticed my engine ran just as long on the 20 ounce tank as it did before. After the run, I removed the plug from the breather/drain nipple and recovered all the fluid left inside the engine. It amounted to 1cc of oil. I am not an authority on this new intake manifold, I only tested it to see if it works. And it does.
Like I said earlier, contact Olivier for more in-depth details.
ID:	1810611   Click image for larger version
Old 10-12-2012, 01:32 PM
  #1293
SrTelemaster150
ORIGINAL: Kmot
I wonder how on outlet check valve would work to drain the oil?
Just run a tube to convenient location & let it drain on it's own. after the engine is shut down.
Old 10-12-2012, 02:57 PM
  #1294
Kmot
My Feedback: (24)
Kmot's Avatar
Are there check valves that small? Oh wait, you mean run a tube from the nipple to a check valve located inside the cowling, and then drain from there. In that case a larger check valve would be fine. I don't know of any check valve that would screw in, in place of the nipple. Is there one?
Old 10-13-2012, 08:24 PM
  #1295
Kmot
My Feedback: (24)
Kmot's Avatar
Framed 16x20 picture on the wall.
Old 10-14-2012, 03:54 AM
  #1296
Reverend
Reverend's Avatar
Gentlemen, new numbers and a confession...
Went to the field just for some engine runs with the 450 and the 400
My new Fuel: Rapicon 10% Nitro, 18% Oil
FS400AR
20X8 Menz S @ 6450 Noisy and not impressed.
20X8 APC @ 7320(!) thats 3.6bhp and I measured 24lb of thrust.
20X10 APC @ 7020(!!!) thats a whopping 4bhp and 22lb of thrust.
dont forget, I fly @ 2000ft so the air is a bit thinner than on your beautiful isle carousel
I am putting this baby into my SiSt Focke Wulf.
The confession? I am beginning to like nitro... did the check with my old fuel, BIG difference. Back to the old numbers @300rpm less.
Old 10-14-2012, 03:55 AM
  #1297
Reverend
Reverend's Avatar
ORIGINAL: Kmot
looks great! I am getting one of my stearman in XXL form my workshop :-)
Old 10-14-2012, 04:41 AM
  #1298
SrTelemaster150
ORIGINAL: Kmot
5mm X .8 thread, same as the standard breather nipple on a saito, not sure about ASP threads.
Old 10-14-2012, 04:47 AM
  #1299
SrTelemaster150
ORIGINAL: Kmot
I have several framed PIX of my 2006 Charger taken @ drag strips W/camears tripped by the timing lights They get a shot of the car from a low frontal angle @ the precise moment that the car comes out of the hole. You get to preview the PIX & select ones that you want enlarged.
My wife keeps putting them "away".
Old 10-14-2012, 08:26 AM
  #1300
Kmot
My Feedback: (24)
Kmot's Avatar
Those are impressive numbers Rev! There's no doubt APC props make thrust. That is why they seem to be the most popular prop in use worldwide.
Dan, I like that little check valve! But in further thinking I realize it would not be appropriate for use on the FS400 with the RIM manifold as the crankcase needs to be closed during operation.
