ASP/MAGNUM FS400AR Rebuild/Overhaul
Reply
Old 10-24-2012, 11:36 PM
  #1351
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
They look very similar to the menz, i wonder how they perform. Can you pop some rpm figures up if you run them on the 400 or the 300v
Carosel43 is offline
Old 10-25-2012, 07:18 PM
  #1352
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone using RealFlight simulator?
I have uploaded my FS400 engine sound profile to the swap pages.
http://www.knifeedge.com/forums/down...=file&id=17566
Kmot is offline
Old 10-25-2012, 11:26 PM
  #1353
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My glow thingmabob arrived!!!! its all installed and the plugs go a nice orange not a slightly pathetic fading red! even though its gone rly cold and windy i think it would rude not to try the radial later! unless i get really cold and hide in the building shed
Old 10-26-2012, 08:27 AM
  #1354
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, i ran my engine and am happy with the glow driver as its am improvment over the old one..the engine however is still an issue at idle. Anything below 2000rpm and it will slowly run down and stop. its also a nightmare to start half the time needing the choke closed while running the starter with glow on. As soon as it fires let choke off keep cranking until revs come up a bit then off starter and ready to throttle back before you loose your arm. Not friendly. Hot restarts are often just as bad. Thing is it never used to be like this, i may have to take the tank out and see if i pipe is kinked or something. Sigh
Old 10-26-2012, 10:14 AM
  #1355
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Which glow driver have you bought ?
Have you checked your valve clerance on all three lobes on each cylinder ?
SJN is offline
Old 10-26-2012, 11:29 AM
  #1356
Reverend
Reverend's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Carosel,
Thats awkward. My 400 has NEVER seen a starter. It is always handstarted, five turns at the max.
I am generally not a fan of using brute force because as soon as the cylinders kick in you are dictating a differnt rythm which cannot be good for the bearings and bushings. Lasers dont need a starter anyhow, Saito was more work but started well in the end too.
FWIW, I am back to the original carb and it works fine, actually 150rpm better than the OS... Go figure. But your problem really sounds like a fuel issue. No leaks in the tubing? What happenes if you put 2-3ml of fuel directly in the carb and start it?
Rev
Reverend is offline
Old 10-26-2012, 12:09 PM
  #1357
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine wont start without a starter as it just will not fire strongly enough on one cylinder to turn it over. And i hate using starters, i only use them if i cant prime the carbs or its really cold and they wont go. In any case my engine has always done this but its gotten really bad just recently. the valves are as ok as they can be with the total hopelessness of my engines tolerances,and if i prime it as usual and try to start it will often fire up and then die or will only fire on one pot. you can do what you like with the slow run and it makes no odds. I even port primed each cylinder through the exhaust and that helped but was not instantly a success. it sounds to me like a suction issue but its only gotten this bad since i put it back in the model, it was starting ok before in the model and in the test stand. but if a pipe was kinked or something then full power would also be a problem and its not, also when its running its fine, no problem, its just getting it started thats the issue. I am so frustrated by it, i will see how it restarts tomorrow having been run today
If its no good i am sorely tempted to just buy a new one and throw this one in the ali skip at work for recycling
Old 10-26-2012, 12:11 PM
  #1358
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
oh and my glow driver is a unit from glowswitch.com. cheap at 65 quid and it came with a 6600mah 2.4v battery. Should give plenty of runtime
Old 10-26-2012, 12:48 PM
  #1359
Reverend
Reverend's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Carosel43
Mine wont start without a starter as it just will not fire strongly enough on one cylinder to turn it over. And i hate using starters, i only use them if i cant prime the carbs or its really cold and they wont go. In any case my engine has always done this but its gotten really bad just recently. the valves are as ok as they can be with the total hopelessness of my engines tolerances, and if i prime it as usual and try to start it will often fire up and then die or will only fire on one pot. you can do what you like with the slow run and it makes no odds. I even port primed each cylinder through the exhaust and that helped but was not instantly a success. it sounds to me like a suction issue but its only gotten this bad since i put it back in the model, it was starting ok before in the model and in the test stand. but if a pipe was kinked or something then full power would also be a problem and its not, also when its running its fine, no problem, its just getting it started thats the issue. I am so frustrated by it, i will see how it restarts tomorrow having been run today
Just to be clear, before recycling comes rev-cycling my engine was rubbish when I got it and now its running. my saito was rubbish and now its running. I am sure theres not noo much wrong with your 400... Its usually one small detail. If its the idle that is bugging you, check for false air somewhere along the line. I'd put my cash on false air.
rev
Reverend is offline
Old 10-26-2012, 02:30 PM
  #1360
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the problem is that every seal, every valve, every gasket andevery Oring leaks like a seive. some of the rockers can move sideways almost enough to clear the valve stems. The bearings are such a poor fit they fall out of the housings and had to be glued in with locktite, the valves wobble and have been eroded by the valve seats as they are made from monkey metal. none of the pushrod tubes seal and they all vibrate up and down and rotate when running. The piston rings loose all ability to do anything when they are hot....Honestly its a heap of crap. But, when its actually working, i love it!
Old 10-26-2012, 02:56 PM
  #1361
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, when i last ran my engine in the test stand it was fine. It would run down slowly but it started no problem. This issue has come about since it was put back in the model. the tank is the same (but plumbing may be kinked) and the only onther difference is the exhausts. as it looks too cold nasty to fly tomorrow i will have a look at the tank and the rest of the install and see whats what. i will also put a cable tie around each rubber 'boot' onthe intake manifolds to make sure there is no leak there. The other issue it could be is a leaking inlet valve thats leting air into the system in the wrong direction. I will see tomorrow. It might just restart, if so im leaving it well alone!
Old 10-26-2012, 08:28 PM
  #1362
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My engine has never been able to be started by hand either. I have seen videos on YT of guys hand starting theirs and now Rev saying the same thing.
I can try to flip mine till the cows come home, and it won't light off. But all I have to do is bump it for a nano second with my starter and off she goes!
Kmot is offline
Old 10-27-2012, 01:50 AM
  #1363
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
before the detonation it would hand start if well primed but it was never 100%
Old 10-27-2012, 01:54 AM
  #1364
the pope
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Carosel43
the problem is that every seal, every valve, every gasket and every O ring leaks like a seive. some of the rockers can move sideways almost enough to clear the valve stems. The bearings are such a poor fit they fall out of the housings and had to be glued in with locktite, the valves wobble and have been eroded by the valve seats as they are made from monkey metal. none of the pushrod tubes seal and they all vibrate up and down and rotate when running. The piston rings loose all ability to do anything when they are hot....Honestly its a heap of crap. But, when its actually working, i love it!
Thats pretty funny . Sounds like a woman I know . Cheers the pope
the pope is offline
Old 10-27-2012, 03:12 AM
  #1365
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well i tried to get it going and eventually it started. it then stopped for no apparent reason and will not restart. so, its out of the model and every valve is leaking, and all the leaking inlet valves are most likely the cause of the issue. but its always had leaky valves so i dont know why its suddely decided not to work at all. from experience however i know that the valves cannot be made to seal correctly as they are too badly made. if i cant figure out another way im binning it. im just too fed up with it
Old 10-27-2012, 05:04 AM
  #1366
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
plane all back together and replumbed. Starter working well as i got fed up with the 12v supply and hooked up a 6s lipo at 24 volts. Spins at about 2000 just on the starter! anyway i primed it up and nothing, not even a fart out of it. turns out the glow driver battery has died. so, i tried a normal glow driver on one cylinder thats always the last to fire and it was firing strongly. So, we will see what happens when i get glow power back on all 5
Old 10-27-2012, 07:49 AM
  #1367
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I dont know what i did, but i think i fixed it
http://www.youtube.com/watch?v=s0UYY...ature=youtu.be
Old 10-27-2012, 08:21 AM
  #1368
Reverend
Reverend's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Carosel43
yep, sounds like it should. piece of debris maybe that clogged somewhere...
off to the field!
Reverend is offline
Old 10-27-2012, 08:39 AM
  #1369
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
its cold and windy and dark, so no fly today. tomorrow its cold and windy and raining! might be another week or so i hope its soon though or th engine will break again
Old 10-27-2012, 09:35 AM
  #1370
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Carosel43
It's just teasing you, like that woman 'the pope' mentioned.
Kmot is offline
Old 10-27-2012, 11:04 AM
  #1371
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the sooner i build my own the better
Old 10-27-2012, 11:14 AM
  #1372
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
engine that is not woman!!
Old 10-27-2012, 11:32 AM
  #1373
AeroFinn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Carosel43
Hi Jon
Good evening!
I think you mentioned sometimes you had been planning an engine of your own design..? Any news?
I think there are many of us that are very curious to know how you proceed with that engine project..
Artto
AeroFinn is offline
Old 10-27-2012, 11:55 AM
  #1374
Carosel43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am working on many things, one of which is ready for air testing but you guys will just have to wait
Old 10-28-2012, 01:20 AM
  #1375
Reverend
Reverend's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Carosel43
ummm, yes, I can relate to that...
my back yard this morning
Reverend is offline
Reply
Display Modes
