Saito FA 120 help needed
RE: Saito FA 120 help needed
I'm thinking the best thing to do is replace the cam, the shaft it is on, the two thrust washers, and the two cam followers as a complete set since they all wear in together. I have the split type valve retainers, are they supposed to be replaced periodically?
A little dissapointed in Horizon's service policy for Saito engines, as they offer no replacements. Other engine manufacturers in the past would offer a replacement engine to you if your engine needed excessive repairs, at a reasonable price. Horizon just turns you away and tells you to go buy another engine.
I am new to 4 strokes and i recently bought a used saito 120 for my showtime 4d 90.I am not sure how old it is or how many times it has been run.My problem is at half throtle and above it does not gain any more rpm.It,s like my half throtle is full throtle.I,m running a zinger 18 6.10 prop on 20 percent coolpower heli fuel.I don,t know if it is my prop or just a problem with the engine itself.I have not flown this plane yet but have run the engine and runs and sounds great.Any ideas whould be greatly appreciated.
CT
That is way too much prop for that engine. I'm not sure of what prop you need, but I would guess no bigger than a 16x6 or 15x8.
#32
ORIGINAL: w8ye
Here are some pictures of a very early plain Saito 120 ABC with the low cam courtesy of Kmot. It has the air bleed carb with mid range adjustment.
Sincerely,
Richard/SPACEWORM/Saito Club Member #635.
#33
My Feedback: (16)
They originally had gold rocker covers.
The one in the quote had the rocker covers replaced with silver
The needle without the A was more like what was in it? Either should fit?
The exhaust shown on the quoted engine is a currently available replacement
