If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 5 of 15 FirstFirst ... 34567 ... LastLast
Results 101 to 125 of 353
  1. #101
    Bone's Avatar
    Join Date
    Mar 2002
    GraftonNSW, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Bent crank ? I'll fix it for free.
    As always, concise & relevant information backed up by clear & illustrative photos - great work Dave. We do appreciate it [8D]
    Saya mencintai aero memperagakan
  2. #102
    Moderator
    Join Date
    Mar 2002
    Pinon Hills, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ....thank you, Bone. [sm=wink_smile.gif]
    I've been slowed by a bad cold.....The parts are in. I'll get that bent crank straightened tonight.
    FBD.
    An engineer says.... "That will not work".
    A mechanic says..."Oh yeah, watch this".
    Old age and treachery will overcome youth and skill.
    Revver Bro #4.
  3. #103
    Join Date
    Mar 2002
    Arvada, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hang in there FBD. Hope ya kick that cold soon.
    This entire thread is a great example of modelers HELPING other modelers. Far too many guys are willing to take advantage of and steal from their fellow modelers--over stupid toys.
    FBD is to be commended for his generous offer to help out complete strangers. If I HAD a wrecked engine, I'd send it to him in a heartbeat. Be patient buddy--spring is a comin' and you may just get one outta me yet!!
    Airplanes have expiration dates. Its just not printed anywhere on them.
    Im not really an airplane pilot; but I did stay at a Holiday Inn Express last night.
  4. #104
    Moderator
    Join Date
    Mar 2002
    Pinon Hills, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    .....thank you for the kind words, Rcpilot....
    I'm finishing up the 3250 right now....it had the bent crank, and has a new case. I guess
    it was in a bad wreck.
    FBD.
    Revver Bro #4.
  5. #105
    Join Date
    Jan 2002
    Littleton, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Dave. Re. your comment about the 3250 you were just finishing up. I suspect that may be mine and yes it was in a hellava wreck. Had just bought it on e-bay and mounted it on my 18lb. Ultra Hots to replace the 3000 I had on it(same 3000 I finally found the backplate for DUH!). There was a notable differance in power. I was on my downwind leg when I no longer had control and straight in went the hots. That broke one of the lugs off and split open the crankcase. Postmortem: Transmitter battery died. After the plane went in I looked down at my tranny and the needle was on its way down to zero. If I had another minute I would have been on the ground rather than in it.
    Dick
  6. #106
    Moderator
    Join Date
    Mar 2002
    Pinon Hills, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OK, Dick.....it's interesting to note the 3250 had noticeably more power than the 3000.
    They are bascially identical, except the 3000 has a 35mm bore, and the 3250 is 36mm.
    Here's the report on the 3250 with all the details so you'll know....
    The crank came out great.
    2. the zero dial indicator
    3. the total run out came out about .00025
    4. I put a light hone on the cylinder to re-seat the ring
    5. Heated the new case and installd the liner.
    I heated the front housing and installed the new bearings. The front bearing has both shields still
    on it, so it is lubed for life. The front end of the engine is sealed with a proper rubber seal anyway.
    The rear bearing is open on both sides. I blew out the grease with compressed air but did not wash
    the bearing, so the residual grease will keep the bearing protected and lubed.
    I reinstalled the rod and piston. The cylinder wall, ring and piston and rod are oiled with Mobil 1
    synthetic so no worries there. The front seal is greased on the inner lip, and I used some of my parts
    and snugged down the prop collar onto the tapered collar so it is tight to the engine. Basically the
    engine is totally massaged and ready to go.
    FBD.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	896238   Click image for larger version.
ID:	896239   Click image for larger version.
ID:	896240   Click image for larger version.
ID:	896241   Click image for larger version.
    Revver Bro #4.
  7. #107
    Moderator
    Join Date
    Mar 2002
    Pinon Hills, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The 3000 is massaged and ready to go....same story on the preperation, except I removed
    the inboard shield on the front bearing just like it was stock. The ring tension is good, as well
    as the fit in the bore was perfect contact. The head is torqued down.
    I put a glow plug in it, and the compression is excellent. Both engines turn over perfectly and
    the cranks are straight....they're ready for a great season of flying. I'm gonna package them
    up and post them back today. I'll send back all the old parts as well.
    Is this fun, or what ?
    FBD.
ID:	896306   Click image for larger version.
ID:	896307   Click image for larger version.
    Revver Bro #4.
  8. #108
    Join Date
    Jan 2002
    Littleton, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Dave, you are a most astounding individual. I won't say more because the more you do for all us guys who need your kind of expertise the more you are going to hear it. Just accept it. My fear is you have opened Pandoras box. In a couple of months we may hear that you changed your name, moved and left no forwarding address in order to escape all us dumb thumbers with bent cranks. DON'T ANYONE SAY ANYTHING ABOUT NON ENGINE BENT CRANKS.
    Seriously my friend,thank you so much. And give me a total on the parts.
    Dick
  9. #109
    Join Date
    May 2007
    Rison, AR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: corcguy
    Dick
    Let me be the FIRST one to second that statement !!
    If there is EVER anything I can do for YOU just ask,I have a long memory
    Craig
  10. #110
    vicman's Avatar
    Join Date
    Dec 2002
    Valdese, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ol man Dave lives so far back in the hills he doesn't need to change an addy. He just forgets to run the rod into town to pick up his mail for a month or three.
    Don't worry guys, helping you get your engines running again is like a new woman to him.[8D]
    Hang in there Pappy!
    A guy who used to live on this site and now is rarely here due to the "upgrade".
    Most likely fading away till the My Forums is fixed. Too bad.
  11. #111
    Kmot's Avatar
    Join Date
    Jun 2003
    Northridge, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    LOL Vic! I think you nailed it!
    ~Tom~
  12. #112
    proptop's Avatar
    Join Date
    Oct 2002
    Rome, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Dave's a pretty cool guy...and maybe he's channeling the spirit of Bill R.?[8D]
    < Wrongway Feldman's Kreider-Reisner KR-21...(on Gilligan's Island)
  13. #113
    Moderator
    Join Date
    Mar 2002
    Pinon Hills, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Dick.....It was 10 bucks for the ring (good price from Bowman) and 18 bucks for the brgs.
    The engines are already on the way back, I mailed them (insured) two days ago.
    I think I have a Saito crank coming, and a rod to stress relieve coming as well. Maybe I'll
    fix up a couple engines I have laying around here till something comes in.
    BTW, those Boca bearings are sweet, and economically priced....very smooth too. [sm=thumbup.gif]
    Thanks for the kind words, Felas....
    FBD.
    Revver Bro #4.
  14. #114
    Join Date
    Jan 2002
    Littleton, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Dave
    Received the engines today, they look and feel just dandy. Gotta finish up one project and then take a drive down past your stamping grounds to S.D. to see the zoos and the Midway. Going to put the 3000 in a Big Bee I just finished. The 2300 I have in it does not cut it. I'll let you know how it works out.
    Regards, Dick.
  15. #115
    Moderator
    Join Date
    Mar 2002
    Pinon Hills, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Good news, Dick....[sm=thumbup.gif]
    I'm happy you were satisfied with the quality of the work. Now I need to get busy
    and fix up my two S.T. 3000's while I wait for some more work to come in. I should
    have a Saito crank to straighten soon.
    FBD.
    Revver Bro #4.
  16. #116
    PlaneKrazee's Avatar
    Join Date
    May 2002
    Gales Ferry, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Dave,
    Nice work.
    I've used a well worn and plugged up brake hone on my engines. A little less aggressive but it did the trick.
    a never-ending battle for truth, justice and the American way
  17. #117
    Moderator
    Join Date
    Mar 2002
    Pinon Hills, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ....yep. Removing the old glaze and preparing the cylinder wall for a new ring is the key. Almost
    any small hone will work....you can even prepare the surface by hand.
    FBD.
    Revver Bro #4.
  18. #118
    MetallicaJunkie's Avatar
    Join Date
    Sep 2006
    Donna, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Fly Boy Dave, my saito .91 has a slightly bent crank, are you still repairing bent cranks? i sent you a pm
ID:	905421   Click image for larger version.
    \"Propellers are notorious for inflicting serious bodily harm while vigorously defending their space\" George Aldrich
  19. #119
    Moderator
    Join Date
    Mar 2002
    Pinon Hills, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: MetallicaJunkie
    Yes, I will fix your crankshaft. Just send it with return postage, and I will repair it for free.
    I will go to the PM.
    Revver Bro #4.
  20. #120
    Join Date
    Sep 2006
    Donna, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    awesome Dave i cant wait to run my 91 again it was sweet
    *edit ill send it to you in my lunch break
  21. #121
    Moderator
    Join Date
    Mar 2002
    Pinon Hills, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ....no problem, I should have it coming back your way within 48 hours.
    FBD.
    Revver Bro #4.
  22. #122
    Moderator
    Join Date
    Mar 2002
    Pinon Hills, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ....send the block as is....I will remove the front stud with a puller....
    Revver Bro #4.
  23. #123
    Join Date
    Sep 2006
    Donna, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    awesome will do that
    edward r.
  24. #124
    speedster 1919's Avatar
    Join Date
    Dec 2004
    Martinsville, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Dave ... My ST 90 slightly bent crank (1/4") is on the way. US mail charged me $1.98 to ship it and would not sell me a pre printed postage . They would only sell me a $1.98 in stamps so I sent them in box. This way you don't have to go to post office.
    Thanks Randy---Oh it is probably the worst bent crank you have seen without snapping off..........
    Hey Buddy -That was the most spectacular crash I\'ve ever seen , That rolling cart wheel with parts slinging out was cool...
  25. #125
    Join Date
    Apr 2006
    London, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    FBD ...legend in the making!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
