Old OS Max 45 F
Old OS Max 45 F
Old OS Max 45 F with removable front housing. Anyone have a ring that I can purchase? The engine is down on compression but otherwise OK. I want to run the engine backwards in a pusher application otherwise another engine could be used. Does Bowman make rings for the smaller engines?
Thanks.
Bill
Forgot to ask if a ring from another manufacturer might work? Bore is 21.79 mm.
Thanks.
Bill
RE: Old OS Max 45 F
In the last list Frank Bowman emailed me, he had these OS rings in stock:
OS .20 FS 4C, .26 4C, .28 FH Dykes (pin), .32 (pin), .37 H (pin),.40 H Dykes & Standard, .40 H (P) Pylon, .40 FS 4C, .40 SR (pin), .807 bore, .40 FSR 835 Bore, .40SR Dykes, .45 (pin), .45 Dykes (pin),
45 RSR Dykes, .46 Dykes (pin), .46FX (pin), .46SF (pin), .48 Surpass, Max 50 old, .50 FSR Dykes (pin) ,.50 H (pin), .50 SX & SXH (pin), Surpass .52 4C, .58, Max-H .60 FGR .60 4C, .60FSR (pin) .9445 Bore - older or SF.9055 Bore, .61 FS 4C, .61 SX & SXH (pin), .65 (pin), .70 & .75 Surpass, .80 H,.80 Dykes (pin), .90 & .91 4C, .90 & .91 Glow, .91 FX (pin), .91 SX H (pin), 1.08 (pin), 120 4C, 120 AX(pin),160 FX (pin), BGX-1 3500 (pin)
Frank Bowman
1211 N Allen Ave. Farmington, N.M. 87401-3568
ringmaster46 "at" msn.com
Frank Bowman
My Feedback: (21)
RE: Old OS Max 45 F
.....'yer right....what happened to the .45 ???
http://www.osengines.com/parts/discontinued.html
I believe it has a Dykes ring. I am running a .45 fsr at the present. Those engines don't have
a lot of compression at rest. If the engines idles correctly, and runs good, the ring is probably
in good shape. I haven't thought about getting a spare ring for mine, but it might not be too bad
of an idea. I searched, and found nothing. []
RE: Old OS Max 45 F
The engine has a conventional ring. I have other engines with Dykes rings and understand low compression at cranking speeds. The piston and ring has been cooking all day in antifreeze hoping it will free up.
Bill
Bill
RE: Old OS Max 45 F
ORIGINAL: Flyboy Dave
....good deal, I hope it will free up. I searched for about an hour and couldn't find a ring for sale. []
FBD.
FBD.
Bill
RE: Old OS Max 45 F
Dave,
I receive an email from Frank Bowman indicating he had the ring and that it was OS 45H. Monday I will order the ring.
Thanks for your help.
Bill
Bill
RE: Old OS Max 45 F
Hello,
i received from a person a plane with an OS 45 F. I am putting this engine back in good shape but the ring is broken. I have found your thread in this forum, hopefully. Could tell me how to contact Frank Bowman as i would like to order him a ring from my engine.
Thanks a lot for your help, i didn't find here in France any supplier that could do this.
Pierre.
Pierre.
RE: Old OS Max 45 F
I received the ring from Frank Bowman today along with a ring for another engine. It was a pleasure doing business with Mr. Bowman.
Frank C. Bowman
1211 N. Allen Ave.
Farmington N. M. 87401-3568
[email protected]
Bill
Frank C. Bowman
1211 N. Allen Ave.
[email protected]
Bill
