Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
Reload this Page >
would an os46fx with a muffler based smoke system (pumpless) do the work??
Old 04-19-2003, 09:48 PM
assaf
Default would an os46fx with a muffler based smoke system (pumpless) do the work??
i want to put a pumpless smoke system (using the engines pressure) to create smoke, would it produce enough smoke which will be visble and look good from the ground??
Assaf.
Old 04-19-2003, 10:09 PM
edge_fanatic
Default Hmmmm
Well...It might be visible, but not what I personally would consider adequate. Remember that you need to be able to draw from a smoke oil tank *and* heat the oil to burning point.
I have a pump system in my 3.2 gasser, and it is what I consider "adequate"...not great, not marginal, but in between....And the .46 is likely to pull much less oil through the system, especially since there is no pump.
I welcome the view of the experts...Maybe I'm wrong...
Old 04-19-2003, 10:50 PM
ZAGNUT
ZAGNUT's Avatar
a crankcase pressure tap with a one-way valve will give you more pressure than you need, the problem with small glo engines is finding enough heat to vaporize the smoke fluid.
dave
