Enya 60 Model 7032 Instruction Manual?
Unfortunately, I do not have a copy of that one on my computer. If you e mail me with your name and address, I can make you a copy and mail it you.
RE: Enya 60 Model 7032 Instruction Manual?
Ask your questions better on the club Enya, people there have gathered some important knowledge about those engines, better than what you get in a instruction manual.
As per Estradajae's instructions I posted this in the Club Enya board........
"I am a newbie to Gas engines well RC in general. I was given a Enya 60 model 7032 almost NIB(New In plastic Baggie that is). The original owner bought the engine test run it for 30mins. Then put it in a baggie and never built a plane to put it on. That was 1967. Fast forward to couple of weeks ago, I get a really good deal on a Tiger Trainer 40 with a Thunder Tiger Pro 46 already on it for $70. Just had to bind and fly. Well I got that in the air and verified that I could fly. I had never flown previous to last weekend, I had just learned and practiced in RealFlight G4.5. It was just like the real thing using the PT-40. I had no problems getting the plane up flying it or landing it. Well I was talking to this guy about it and said I was building something more acrobatic but was needing a bigger engine. He said he had just what I needed and pulled out this Enya 60 and said I could have it so long as I put it up in the air. There is no manual, but more importantly no muffler. I had no problems starting the Thunder Tiger motor. But I haven't been able to get the Enya going well enough to fly yet. How should I set the carb?? I read somewhere about a JE300 muffler that could strap on to the case???? If I get this muffler and hook up the vent line will it improve reliabilty with the constant fuel pressure. If add the muffler do I remove the exhaust flapper thing attached to the carb???? I just not for sure what to do. I live really far out in the boonies and not any other RCers close by to ask for help."
I would like to find a copy of the manual just so I have a better understanding of the motor and it's settings. I did figure out part of my problem and while I haven't test flown it yet I did get it running pretty good. The exhaust flapper thingy screw had loosened and the flapper was open when at idle and closed at WOT knowing real engines I knew that couldn't be right so moved it 90* so it was closed at idle and open at WOT. Fired up and ran much easier had a lot of power. I am guessing 2stroke carb tuning is all about the same???? On the Tiger Thunder manual said to turn out needle valve 2 1/2 turns to start it. After starting and a little warm up go WOT adjust for maximum RPM then richen back up till there is a slight drop in RPM. Test by pinching fuel line. RPMs should increase. Still not for sure on the adjustment of the air screw though.
Hi Cub Boy, here are the Enya´s 60 manuals that i have, from the 60_II and the 60_III. Hope that´ll be useful to you
cheers
cheers
