fuel question
RE: fuel question
My instructor ran nothing but synthetic oil fuels. I hadn't learned to tune my Mag 52 four stroke yet and I had a lot of stalls on the way to the flight line. I was running Omega 15% and he would grumble about "smelling Castor". The next comment would be about the engine. Finally I told him "what I have is what I have". Several planes later, I am still flying Omega 15%. Still smells like castor when I start my engines, but there is nothing like pulling one out that hasn't run in a year, didn't have a drop of after run in it, ever and puttting it on a new plane and have it kick off with less that a second of starter.
I tried Cool Power, made by the same company that Omega is, and I just didn't like it. I burnt about 1/3 of a gallon and the rest sets on my shelf. This is me talking, but I believe the castor give you a better lube, especally if you are running a little lean.
THere has been a number of threads on the qualitys of synthetic vs castor lube. More than you will ever want to read. When the day is done though, the differences between Cool Power and Omega is about wherether 4%, or there abouts, of the fuel is synthetic or castor. Oh yes whether it is green or pink. Color asside, for all practical purposes they are the same. I still like the pink one thuogh.
Don
Don
RE: fuel question
ORIGINAL: w8ye
If it is all synthetic, put 2-4 oz of castor oil in the fuel and you can run it in either engine.
Some Cool Power four stroke fuel already has castor oil in it. But it will say so on a little sticker on the shoulder of the jug.
http://www.morganfuel.com/omega_blends.htm
http://www.morganfuel.com/cp_blends.htm
Don
My Feedback: (16)
RE: fuel question
I agree with you about what the web site says about Cool Power. But I've seen 4 stroke Cool Power jugs at the hobby shop with the little sticker on them that talks about a synthetic/castor blend. I think there is also 4 stroke Cool Power that is all synthetic.
I'm wondering if the Cool Power 4 stroke fuel with the multiviscosity is the one with castor?
I've never used Cool Power myself.
RE: fuel question
w8ye, Like I said, I tried a gallon of the Cool Power and 1/3 the way through, my engine was running really bad and one day, attempting to fuel the plane, the pump seem to have gone nuts. Turns out the pickup line in the Jug had rotted from the clunk to the fuel line. It was crumbling and took me for ever to get the clunk out of the jug. I replumbed my fuel pump and switched back to the Omega and haven't looked back since.
A couple years back, I bought a bunch of kits, wood and "stuff" from a guy getting out of the hobby. Included was a case of Tower 15% Pink fuel. The stuff must have been close to six years old best I can figure from or club membership and the lables. Checking around, I was told the Tower and the Morgan fuels were one in the same. I burnt the whole case with only a slight drop in performanc on the last couple tanks from each jug. Nothing bad, just a llittle slugish. I've pushed another case through my planes since. All Omega. Hey, this should get me some kind of discount for all the advertising I just did for them.
Don
Don
RE: fuel question
OK what manufacturers use weight and not volume to determine their percentages? If you use weight you are getting less oil than volume. And why don't they list it on the jug?
My Feedback: (102)
RE: fuel question
Check this out, I've been a WildCat customer since 1991 and have never lost a bearing to rust or wear since.
http://www.wildcatfuels.com/specs.htm WildCat, Coopers, PowerMaster and S&W are very open about what's in their fuels.
OH
RE: fuel question
ORIGINAL: Hobbsy
RE: fuel question
ORIGINAL: jeffie8696
..what manufacturers use weight and not volume to determine their percentages?
RE: fuel question
G'day Someone here is Oz was selling fuel mixed by volume. I can't remember who it was. So I did some sums and it turns out that if you mix by weight and not volume (as is more normal, or what most people expect) because of the higher specific gravity of Nitro (1.14 kg/l, and lower SG of Methanol (0.79 kg/l) and with oil being approx 1 kg/l, a 10 nitro, 20 oil, 70 methanol mix made by weight is actually (in volumetric terms) approximately 7.5% nitro, 17.1% oil and 75.3% methanol. There is a rounding error in there of 0.1%. Moral of the story - don't buy fuel mixed by weight unless you do the sums and know what you are really getting.
RE: fuel question
That is my point exactly! Methanol is cheap so if you mix by weight you are making a cheap fuel that is low on nitro and oil (the most important parts) but
"by law" you are labeling it correctly. . I just think we should all know what we are getting. I use SIG fuel and all castor at that. I KNOW I am getting good fuel.
WI
RE: fuel question
Hello to everyone who responded, and thanks for the info. My question was answered, and so I will burn up the castor synthectic blended Coolpower fuel and switch over to Wildcat fuel after that. I also have added 2 more oz. of castor oil to the blend of fuel. It has 17% of castor already so now i figure the blend should be aleast 18%. Thank again
RE: fuel question
Gotta love Castor. You just can't go wrong with it. Unless you ignore your engines for months at a time. A little squirt of after run oil and forget it. I use inexpensive spray can Liquid Wrench.
RE: fuel question
ORIGINAL: madmanmikie
We run coolpower blue straight synthetic oil in every engine we own, so YES you can run coolpower without any fears at all, have done for over 15 years.
The only consideration IMHO is climate, we fly at sea level, humid hot climate.
This is the % of Coolpower used: (Nitro 5%)
Saito 60, 91, 120, 150, 180 - 16%
Enya 53's (Twin) - 15%
2 strokes < 20cc - 20%
Big 2 Strokes >20cc - 10%
Bearings last about 10 years with no afterrun added.
Hope this helps.
Cheers
Paul
