Magnum XL 52 FS needle settings?
MO
I bought a new Magnum XL FS 52AR a while back but misplaced the manual. Does anyone know the factory needle settings or know where I can find a manual on-line? Maybe I missed something on Global Hobby's site...
RE: Magnum XL 52 FS needle settings?
My manual shows 2 turns out from fully closed on the high speed needle. Doesn't say what the low speed factory setting is, unfortunately.
My Feedback: (16)
Here is a copy of the .61 four stroke which is the same engine with the same settings. Side by side you cannot tell them apart except for the number on the side.
http://media.hobbypeople.net/manual/210985.pdf
I have the Magnum 61 fs, I`ll go and check out what my needles are at, be back in a moment
My engine is at 1.5 turns out on the high speed needle and only 0.75 turns out on a closed carb on the low speed needle. This is what I fly at, on my fuel in my ambient conditions after running in, and propably far from factory settings. If you start at about 2 turns on the high speed needle and 1-1.5 turns on the low end needle you should be fine and lean in as desired from there
