Irvine 53 Prop Sizes
Reply
Old 08-31-2008, 10:42 PM
dasintex
My Feedback: (10)
dasintex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Irvine 53 Prop Sizes
I have a Irvine 53 without a munual, great engine, but I need to know the prop size range; I now run a 12X4, and it works great but I want to run the engine on another plane without tearing the engine up because of the wrong size prop.
Thanks Doug.
dasintex is offline
Old 09-01-2008, 07:47 AM
Hobbsy
My Feedback: (101)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Irvine 53 Prop Sizes
Doug, a 12x6 is the smallest recommended prop for the .53. I have two .53s I'll look for a manual.
Hobbsy is offline
Old 09-01-2008, 08:52 AM
My Feedback: (17)
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a 53 on a very fast airplane and it took me a number of tries to get the best prop for good performance. I tried 11 – 7 cut down 11 -7, etc. and I ended up with a 10 – 7 that gives great high speed performance and unlimited vertical. Here is a video http://media.putfile.com/Kaos-40-Kit
8178 is offline
Old 09-01-2008, 03:26 PM
mk1spitfire
mk1spitfire's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Im running the irvine53 in a Delta Tigershark with a weton uk genesis tuned pipe and have good speed on a 10x6
ID:	1023973   Click image for larger version
mk1spitfire is offline
Old 09-01-2008, 03:42 PM
My Feedback: (17)
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: mk1spitfire
The 53 does seem to do better at higher RPM.
8178 is offline
Old 09-01-2008, 05:38 PM
mk1spitfire
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yer, i'd like to try a 10x7 like you. Do you think the engine fully unloaded it?
Old 09-01-2008, 08:03 PM
dasintex
My Feedback: (10)
dasintex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Now I'm confused; someone said the smallest prop for the 53 is a 12X6; I run a 12X4 and its pulls like crazy; now guys tell me they run any thing from 11X7, 10X7 to 10X6; does anyone have a manual? what does Irvine actual recommend?
Doug.
dasintex is offline
Old 09-02-2008, 01:49 AM
SpeedBoy
SpeedBoy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think will help if you say on wich airplane are you going to run it .
SpeedBoy is offline
Old 09-02-2008, 06:00 AM
mk1spitfire
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I can not see it in the manual or ripmax site.
The price has dropped to about £60 for the irvine 53 now!!!
Old 09-02-2008, 06:50 AM
greyfoxx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Doug - The Irvine 53 manual says the prop range should be from 10 X 9 to 12 X 8.
And remember, "Experience is a hard teacher. She always gives the test first, and the lesson some time later!" - Phillip
greyfoxx is offline
Old 09-02-2008, 06:53 AM
dasintex
My Feedback: (10)
dasintex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
GreyFoxx; Thanks a bunch; thats the info I was needing.
dasintex is offline
Old 09-02-2008, 08:56 AM
My Feedback: (17)
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The data sheet shows 10 x 9, 11 x 8, 11 x 9, 12 x 6, 12 x 7 and 12 x 8. It depends on what type of aircraft but none of their recommended props worked for me. The big props loaded my engines down too much and I tried two different engines. I was looking for speed and unlimited vertical.
8178 is offline
Old 09-08-2008, 06:02 PM
rhatcher1
My Feedback: (31)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You will find this type of feedback on proping your irvine 53.. What you need to know is that the manual calls for those type of props in the UK because of noise pollution laws,,the props like 11-9 11-10 etc give off less noise..This is true info... so what i have done is prop for the kind of flying im doing and the type plane AND WEIGHT.. Pattern style plane, i use the 11/5 for 3d type flying the 12/4 is good,, hope this helps...
rhatcher1 is offline
Old 09-09-2008, 01:12 AM
DarZeelon
DarZeelon's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: 8178
The Irvine.53 does seem to do better at higher RPM.
ORIGINAL: 8178
The data sheet shows 10x9, 11x8, 11x9, 12x6, 12x7 and 12x8.
8178,
From the prop recommendations in the manual, this engine; at least as it comes from the manufacturer, with the normal muffler, may be much better off loaded down with a relatively large prop...
But, since Irvine engines are now made by OS (ABL, Etc.) and OS are known for their 'quiet' prop recommendations (like a 12x7 for the OS.46AX), one can never know for sure...
The best you can do is to 'plot' this engine's actual HP curve, by taching various props sizes and using [link=http://mvvs.nl/prop-power-calculator.xls]the Pé Reivers PropPower calculator[/link], drawing the curve...
Best performance will be put out by propping the engine to about 1,000 RPM below peak-power, in ground static conditions...
As the propeller 'unloads' in flight, the engine will be around peak-power most of the time.
Using the advertised HP number from the manufacturer will prove to be totally stupid, since they are just lies in disguise... not information.
Plotting the HP curve will show this to you. Tell us what you got!
DarZeelon is offline
Old 09-09-2008, 09:33 PM
ajcoholic
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
prop recomendations are just that... recomendations.
You will always get the best results by testing various props in the airframe you intend to use it in. You wont hurt the engine going over or under the "recommended range"... within reason.
I have run mine (old pre OS stock) on an APC 2.25x3.75 fun fly prop in a fun fly plane for years now. Runs GREAT! Easily hovers the 5.25 lb plane and pull it out with authority on 10% WIldcat fuel.
For a "regular" model, I would start with an 11x8 or 12x6 and work from there.
AJC
ajcoholic is offline
Old 11-05-2008, 03:18 PM
pilot4ifr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had a plane and ran a 11 X 7 .. It seemed to do very well ..... ( They plane was very heavy custom built Bi Plane.) I bought it because it was cheap with great Servos and a Never Run Irvine .53 ...
Well the plane had structual failure in flight (to much of a G load on the wing)
So to get back to my case The prop I had was doing fine. The plane was fast , but the motor sounded like it was topped out ( No I didnt tach it).
I now have the Irvine .53 on a Seagull 540-.46
My question is what prop should I use ,,,,, Does anyone have a suggestion
My understanding is to hang it on the prop I could use a big prop but low pitch to keep the rpm in the upper range,
Or do I go with a smaller dia prop and a bigger pitch ?
OH I HAVE A HEADACHE NOW >........
I gave the model .(pictures).. No who can answer the question .... LOL
Sorry Camera Phone pics= Crappy Photos
ID:	1066162   Click image for larger version
pilot4ifr is offline
Old 09-17-2019, 05:44 AM
propstar
Location: Llandysulceredigion west wales, UNITED KINGDOM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
whilst on the subject of irvine 53, what 3 blade pusher would you use for a fast-ish 4lb-5lb scratch built KR84 TORTUGA type plane.
propstar is offline
