Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
Reload this Page >
Will you prefer the crock pot method or ultrasonic cleaner?
Old 10-08-2008, 11:11 AM
liquid_TR
liquid_TR's Avatar
Default RE: Will you prefer the crock pot method or ultrasonic cleaner?
can I use antifreeze diluted with water in an ultrasonic cleaner apart from dish washer detergent?
The one I bought came with a "special" detergent which turned out to be very powerful but also very corossive to aluminum.
so now im trying to de-oxidise two 160 fx heads with hot water + dish washer detergent + vineger + lemon juice.. its coming on slow..
thats when the AF idea came to my mind.
Old 10-08-2008, 04:22 PM
Motorboy
Motorboy's Avatar
ORIGINAL: liquid_TR
I has not tried then i can not answer at this question..
It is worth to try a lot of difference stuff to use in the ultrasonic cleaner and see what you get good or bad results. No neccesary to add much stuff in the water to wash the engine parts, it is the ultrasonic waves who are cleaning the engine parts.
Never add flammable stuff in the ultrasonic bath, the gas in the bubbles can develop up to 5000 degree celsius/9032 F, possible enough to ignite the flammable stuff [sm=eek.gif] ... But the temperature in the bubble last in very very short time, not enough to warm up the water since the water has good cooling effect.
Old 10-08-2008, 07:15 PM
gkamysz
My Feedback: (19)
gkamysz's Avatar
I was thinking about trying antifreeze too. It might not have the properties for ultrasonic cleaning. And I like to clean my machined parts so I'd be changing the bath often.
Old 10-10-2008, 12:49 PM
Patxipt
Bought an ultrasonic cleaner today. It has 50W max power and a 0.5L bowl.
I have tried the muffler from my Enya SS40BB and the results are posted on the last attached photo. The bath consisted of diluted dish washer (Fairy brand) and a nick of window cleaner. The parts were cleaned for 5 minutes at 50W.
Then I tried antifreeze - using the same time interval and power the result was nil. The ultrasonic bath using antifreeze did nothing to clean the parts.
I'm gonna try the crockpot method this night, the engine and muffler are already cooking on an old cooking pan and an electric heater plate.
ID:	1049104   Click image for larger version
ID:	1049105   Click image for larger version
Old 10-25-2008, 02:51 AM
Ram Jet
Ram Jet's Avatar
Ok, I'm sold. Where do I get an ultrasonic cleaner? eBay? Yep, eBay "Buy It Now" $17.99. I don't have any dirty engines right now but I'm always fiddleing and cleaning something. How about antifreeze IN the sonic cleaner? Hey now!
Thanks.
Bill
Old 10-25-2008, 04:01 AM
  #31
Motorboy
Motorboy's Avatar
ORIGINAL: Ram Jet
Bill
Did you read this in last post #29?: "Then I tried antifreeze - using the same time interval and power the result was nil. The ultrasonic bath using antifreeze did nothing to clean the parts."
Old 10-25-2008, 07:01 AM
  #32
liquid_TR
liquid_TR's Avatar
Well its been about a month now since I bought my ultrasonic cleaner, and Ive tried everything from all kinds of house detergents to all polisher liquids and antifreeze types I could find; to heavy solvent trichlorethylen and alcohol.. nothing works as the stuff I got yesterday from an industrial ultrasonic cleaning company - a magic white powder.
I have told them that I needed a ultrasonic bath solution that will wash the oils, oil burns, carbon deposits and other marks off of my delicate aluminum engine parts and at no cost cause any kind of oxidation to the aluminum and cause no harm to any o-rings, plastics and rubber parts.
you know what? It finally worked! I was on the verge of giving up ultrasonic cleaner.
I'll be getting the MSDS on monday so I can put it up here.
Old 10-25-2008, 08:35 AM
  #33
gkamysz
My Feedback: (19)
gkamysz's Avatar
That's interesting. The chemicals are very specific. I look forward to seeing what's in it. I was going to end up buying the stuff I mentioned earlier, made for ultrasonics.
Old 10-25-2008, 11:59 PM
  #34
mike early
mike early's Avatar
http://www.harborfreight.com/cpi/cta...emnumber=93035 Has stainless steel holding tank. Does not specify whether it has heat or not.
http://www.harborfreight.com/cpi/cta...emnumber=95563 Does not specify stainless, but might be. Has a heater.
Has anyone tried either one of these items?
The best thing about Harbor Freight is buying stuff when it goes on sale. Just need to be patient sometimes. Since there is one local to me, I can take stuff back for replacement when/if it breaks.
Old 10-26-2008, 12:04 AM
  #35
mike early
mike early's Avatar
ORIGINAL: liquid_TR
e.
How about a link?
Old 10-26-2008, 01:20 AM
  #36
Julian537
My Feedback: (9)
Here is the MSDS sheet for ALLOSIL the product motor boy used in the video.
http://my.nilfisk-advance.com/webfiles/225.pdf
From the chemical make up on the MSDS sheet, it looks like it is just a base. 9.5ph.
TSP or tri sodium phosphate is probably the white magic powder stuff??? it also is a base that dissolves well in water. It can also be purchased in a high strength liquid at the local BORG. Big orange retail Giant!
Old 10-26-2008, 06:03 AM
  #37
liquid_TR
liquid_TR's Avatar
mike, I bought the one in the second picture. Its got a 2.5lt stainless steel tank and very effective heater. But its transducer is most powerful where its located only - the middle. Its power seems to drop at the edges of the tank. I havent bought the powder online, so I cant give a link.
But It may very well be what Julian is talking about. It seems like a heavy detergent but wont foam much. Its gotta be a light base otherwise it will oxidize the aluminum which it didnt at all. Usually this stuff needs to be a strong base to clean well, but even this powder is a weak base, it cleaned the oils, dust, dirt and metal corrosion with a single bath.
Old 11-22-2008, 03:14 AM
  #38
NM2K
My Feedback: (14)
ORIGINAL: rainedave
Nice results. I especially like how it cleans gummy bolts. I have been pricing them at different places. We have a discount tool chain in the US called Harbor Freight. They have one for $30 that might be worth trying.
http://www.harborfreight.com/cpi/cta...temnumber=3305
David
Like a dummy, I bought their more expensive $100 ultrasonic cleaning tub. What I got was a fancy timing chip that won't let the cleaner stay on for longer than five minutes at a time. I'm going to rewire it so it uses just a toggle switch. I hope the motor is up to running for twelve hours continuously. If not, it hits the trash can (or eBay) and I buy the $30 unit. <G>
Ed Cregger
Old 11-22-2008, 03:19 AM
  #39
NM2K
My Feedback: (14)
ORIGINAL: flyingbells
this is better for the environment!
antifreeze fumes makes me sick, even when I did it outside the house.
Ethylene Glycol is a very commonly used chemical. The little bit that we modelers use will have a neglible impact upon the environment. Besides, you can use this stuff over and over and over again. The only real concern is the toxicity of the liquid and the vapor.
If you want to waste your time, use the environmentally safe antifreeze, or mistakenly by the 50/50 version of ethylene glycol. Neither will do a good job and will result in being discarded. That is environmentally careless.
Some of the new ultrasonic cleaners come with a heat function in addition to using soundwaves to clean. Now to get the manufacturers to install timer circuitry that provides more than five minutes of operation at a time. That would be the perfect solution for we modelers that wish to clean smaller engines (not gasoline sparkers - too large).
Ed Cregger
Old 11-22-2008, 05:33 AM
  #40
Motorboy
Motorboy's Avatar
ORIGINAL: Ed Cregger
Ed Cregger
There are not necessary to run ultrasonic cleaner longer than 2-5 minutes, it is the cleaning stuff in water and temperature who make ultrasonic cleaner very effective to clean the gummed model engine in short time.
Disadvantages with long running ultrasonic cleaner: the ultrasonic cleaner can eat up the aluminium parts in case the ultrasonic cleaner has high watt per litre!
If in doubt the cleaner has hi watt per litre (mostly industry ultrasonic cleaner has hi watt per litre) , take a aluminium foil and add in ultrasonic cleaner to test the cleaner are suitable to clean the aluminium parts or not.
Old 11-22-2008, 12:29 PM
  #41
NM2K
My Feedback: (14)
Thanks, Jens. I hadn't thought about that aspect of the process.
Ed Cregger
Old 01-01-2009, 12:43 PM
  #42
krayzc-RCU
My Feedback: (31)
kewl
Old 01-01-2009, 01:27 PM
  #43
chashint
Seems like a ten dollar crock pot and a gallon of antifreeze is a lot easier and more reliable.
I have used it many times and it works perfectly.
Old 01-01-2009, 02:23 PM
  #44
proptop
My Feedback: (8)
proptop's Avatar
ORIGINAL: chashint
And substantially cheaper in the long run...(I think )
(disclaimer: I don't have an ultra sonic cleaner though...not yet anyway been wanting to get one for years, but...)
For example, I put half a gal. of undiluted antifreeze in my 3 qt. slow cooker, and that will clean at least a couple dozen engines.
An old flyin' buddy gave me his collection of engines shortly before he passed away...3 shoe boxes heaping full of dusty, varnish covered engines that had been sitting un-covered in his basement machine / woodworking shop for a couple decades. I cleaned at least 2 dozen in the same batch of antifreeze before replacing it. Figure maybe 50 engines (or so ) per gallon...that aint bad...
Old 01-01-2009, 02:48 PM
  #45
w8ye
My Feedback: (16)
w8ye's Avatar
A Ultra sonic cleaner is $40-$50 and on up
Old 01-01-2009, 03:23 PM
  #46
rainedave
rainedave's Avatar
You could call all the local jewelry stores and ask if they have an old one sitting around they'd be willing to sell cheap. If it's a good shop it will be a professional grade unit.
David
Old 01-01-2009, 04:43 PM
  #47
NM2K
My Feedback: (14)
ORIGINAL: w8ye
Ultrasonic cleaners are cool beans, as the kids say, but I haven't found them to be as good as good old antifreeze (lukewarm) in an old crockpot at cleaning varnished glow engines.
Granted, I don't know what I'm doing with the ultrasonic cleaner. Undoubtedly, there are tricks to master, which I haven't as yet.
Ed Cregger
Old 03-20-2009, 02:22 AM
  #48
kenhiraihnl
kenhiraihnl's Avatar
just cooked an os1.60fx in antifreeze with a walmart $12.50 crock pot...works better than i expected...ken
Old 03-20-2009, 03:52 AM
  #49
Ram Jet
Ram Jet's Avatar
ORIGINAL: N2ECW
ORIGINAL: w8ye
I've gotten pretty fond of lacquer thinner.
Bill
Ed Cregger
Old 07-16-2011, 09:21 AM
  #50
mrhp
My Feedback: (49)
i have some powdered chem that i put in hot water or ultrasonic that takes the caramel coating off in no time and will not harm alum. and leaves it bright alum color as new and works as good or better than alosil
