Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
Reload this Page >
Anyone used a Tettra bubbless fuel tank?
Old 01-09-2009, 12:08 PM
5150flyer
Default Anyone used a Tettra bubbless fuel tank?
I was thinking of trying one with my new OS 160 FX. I have heard that they put some pressure on the fuel, eliminate air bubbles and lessen the leaning of the engine as the tank lowers throughout the flight.
I have also heard they are a pain to fill and cause as many problems as they solve.
Thanks for your input.
Old 01-09-2009, 12:21 PM
ChrisAttebery
My Feedback: (15)
ChrisAttebery's Avatar
Default RE: Anyone used a Tettra bubbless fuel tank?
The Tetras are great. The tetra tank will virtually eliminate air in your fuel line until you're down to the last 1/2 oz or so.
As far as filling goes, you can set the tank up with a pressure line, fuel pickup, and a vent line that is only used during filling. you will wind up with a small amount of air in the bag using this method, but it is still much better than a standard tank.
Good luck,
Chris
Old 01-09-2009, 12:23 PM
djlyon
I use them in my pylon racers and 3D planes. They work great. They don't provide any more pressure. The pressure is provided by the engine. They eliminate all the problems associated with having a volume of air and increasing and a volume of fuel and decreasing in the same container. Examples: foaming and air bubbles from the pickup flopping around looking for fuel in a half empty tank. It lessens leaning by not allowing air in to the fuel supply. I have never heard of a Tettra tank causing a problem.
Denis
Old 01-09-2009, 03:16 PM
Super Splatter
Super Splatter's Avatar
you can get tettra tanks from 4 to 24 oz. Once you try one, you'll never go back
Old 01-09-2009, 04:48 PM
5150flyer
Appreciate the feedback. I just bought a 18oz tank and will give it a go.
The directions are a bit weak. Any hints on the best setup. I hear you need to notch the fuel intake tube in the bladder.
You have been very helpful.
Old 01-09-2009, 05:52 PM
ChrisAttebery
My Feedback: (15)
There really aren't any secrets, just follow the directions on the box. You can cut a small V in the end of the carb line to ensure that it doesn't suck on the bag and get plugged, but I doubt it would actually happen in normal use.
Old 01-09-2009, 07:48 PM
togatoga
My Feedback: (42)
They are great tanks, designed more so for YS engines.For engines that use muffler pressure, they work too but a lot of gunk gets in between the bag and tank.You'd have to periodically clean them out even with a inline filter. Good for serious competition, not for sport flying. Plus point is that the fuel in the tank is pristine and you can defuel and reuse.
Old 01-10-2009, 01:12 AM
crispyspa
crispyspa's Avatar
ORIGINAL: Super Splatter
Where are yo seeing this? The largest I found on their website is 6 oz. would love to have a 12 oz.
Old 01-10-2009, 06:37 AM
jaka
Hi!
Largest Tettra "Bubbleless" tank is 24oz!
Which web site??
Old 01-10-2009, 08:39 AM
Super Splatter
where? why on the Interwebz of course
http://www.centralhobbies.com/Fuel/fueltnk2.html
Old 01-10-2009, 12:17 PM
djlyon
Jan on your side of the pond Bruno might have the big tanks.
http://www.stukerjurgen.de/
Denis
Old 01-10-2009, 07:06 PM
crispyspa
crispyspa's Avatar
Thanks!
Here is what I was looking at.
http://www.darrolcady.com/Tettra_Tan...tra_tanks.html
