Some general four stroke questions
#51
MI
RE: Some general four stroke questions
ORIGINAL: Nikolas K
Gkamysz, you 're right. If OS is using shielded rear bearings, then it makes even more sense why they cross drill the crankshaft. But why are they using sealed rear bearings???
I just got an new Enya 1.55. I'm going to tear it down and install a Bowman ring before I put a drop of fuel in it. If I find the rear main bearing is shielded you know what I'm going to do.
Bill
#52
My Feedback: (19)
Bill it doesn't matter if the rear bearing is shielded or not in the Enya. The valve train is behind the cylinder, so the bearing has no influence. The Enya probably has an open bearing.
This thread has become a lot of worrying about nothing.
#53
MI
ORIGINAL: gkamysz
Edit: Damn your good. I have been concerned about getting lubrication into the cam box on my .46. Solution? Plug the crankcase breather hole in the bottom of the crankcase and force the crankcase to vent through the cambox thus lubing the cam drive gears, bearings, cam lobes etc. Sweet. Uh, what size tap is required to cut threads for the breather nipple?
Bill
#54
My Feedback: (19)
ORIGINAL: Ram Jet
Bill
Bill
#55
MI
ORIGINAL: gkamysz
That's a tricky question. I'm not sure what Enya uses. I think OS uses 3.5mm thread on theirs. I would just buy a Dubro fitting, then you know what tap to use.
ORIGINAL: Ram Jet
Bill
Bill
Bill
#58
My Feedback: (102)
Bill, be very careful of the rocker arms on the 1.55, they split real easy when tightening the jam nut after adjusting the lash. They are hard as flint.
#59
MI
ORIGINAL: Hobbsy
Thanks again,
Bill
#60
ORIGINAL: Ram Jet
Oh, a snob huh?
Bill
ORIGINAL: Campgems
Woops, posted to the wrong thread.
Don
Don
Bill
Don
#61
KS
Remember the diffrence between shielded and sealed. Shielded will allow oil to flow through; just keeps the junk out.
L
L
#63
MI
ORIGINAL: Cherokee Flyer
L
L
I'm hip.
Bill
#66
Hey fellas,
I am having a problem with my Magnum .52 4 stroke. It had been sitting in storage for a long while. The engine is brand new. Its got part of a flight on it. I cleaned it up and and got it running the other day, but as soon as I took the glow igniter off it dies. I didn't fool with it very long. It sounds good with my glow stick on the plug. The high end sounds right. I don't know if I should try the low end. I have also moved 3000 feet higher and not sure if that has an effect on the engine.
Any help would be greatly appreciated
Ben
Ben
#67
My Feedback: (264)
MD
ORIGINAL: DAKOTANOVASS
First is when you mount the engine inverted, should you put the vent line outside of the cowl or can you leave it in the cowl or fuse? Being it is inverted their really shouldn't be any oil coming out of the vent line.
You forget that the internal parts of the engine are spinning at up to 10,000 rpm whipping the oil around everything. Never aim the vent line at amything you don't want sprayed with lots of oil.
I just replied to a post that is 11 months old..................Okay, I'm a dummy today, and I haven't had my coffee yet[&:]
#70
I recently bench tested a new ASP 52AR four stroke and no oil was ejected through the breather tube on the bottom of the crankcase. Is this something to be concerned about?
#72
My Feedback: (14)
ORIGINAL: Ram Jet
Bill
ORIGINAL: Nikolas K
Bill
Enya is "good enough" to make your engine, but not good enough to make its piston ring? Don't get me wrong, I have tremendous respect for Mr. Bowman. And you, come to think of it.
I'd break the engine in with the Enya ring and then pack the Bowman ring away safely for a rainy day. Run the engine sufficiently rich and I'll bet you'll never get to use that Bowman ring. (wink)
Ed Cregger
#73
My Feedback: (14)
ORIGINAL: w8ye
Try to run it rich and see if it has oil coming out the vent
But first, unscrew the nipple and then make sure you can see through the hole. If clear, then reinstall and procede as Jim advised. Can't get no oil through a blocked hole! (smile)
Ed Cregger
#74
CA
Now I'm confused. I just replaced the bearings in my Saito .80 and the rear bearing I got sure appeared to be sealed, as is the front. Or is it just shielded, and I'm a doofus? Here's a link: http://www.advantagehobby.com/produc...roductid=26469
$60 worth of parts, want to make sure it's in good shape for its re-entry into the flying world.
#75
That bearing is a shielded bearing, at least the side showing. All metal is a shielded bearing. It is designed to keep big chunks of crud from getting into the race and balls. The Sealed bearings have a red, green, blue, black or some other color rubber like lip that rides on the inner race. It prevents liquid from migrating past that point, as well as serving the functions of the shielded bearing. Bearings come in all combinations of open, sealed, or shielded. IEopen one side shielded the other. THis is common for the main bearing. Shielded one side or Sealed one side are common for the nose bearing. As some Saitos don't circulate oil through the cam housing, they would use Sealed two sides for the nose at least.The seal is effective in keeping fluid from entering the bearing, not the other way around. Some oil/grease escaping is normal as the bearing heats up.
If you need an open ball bearing, and you can only find a shielded or sealed one, you can carefully, using your pocket knife pick out the shield or seal. Just make sure you don't dig into the ball keeper and nick it or you have destroyed the bearing.
The Saito, Magnum, and O.S bearings are over priced. Some of the aftermarket bearing suppliers have much less expensive prices, but some times you get what you pay for. I've been using a couple bearing suppliers on Ebay, not the skate board bearing guys, but big bearing houses that found a market on Ebay in addition to their brick and mortar stores. Their prices are generally around 10% to 20% of what you would pay for O.S, or Saito parts. Their quality is better. Some of the after market bearing sellers quality isn't always OK, but is generally good. Look closely at the bearing shield or seal or sometimes on the race to get the number. I'm a little rusty, but a ZZ suffex indicates shield on both sides. A Z would indicat a Shield on one side. Sealed both side bearings rely on the grease from the manufacture. Shielded both sides do to some extent, Open one or both sides rely on lubercation being supplied internally to the bearing, IEpiston blow by.
Don
Don
