Thunder Tiger 130 Four Stroke
Reply
Old 03-15-2019, 04:31 AM
  #151
Zabriel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Any spares?
Hi,
This is a very old thread. But you are actually my last hope:
I have also a tt130fs, and I am (was) very happy with it. But the thread for the needle holder stripped and unfortunately I lost it. Was not able to find it anywhere. I need a carburetor assembly. Has any one of you an old, or no more working engine left? Practically I need only the carburetor...
Zabriel is offline
Old 03-19-2019, 03:16 AM
  #152
Jesse Open
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by cymaz View Post
Drilled a 1.6mm hole on the rear bearing seat to the cam box. Some evidence of more oil on the valves now so it is showing signs of getting through.
Old thread but, The hole should help. Better still, move tge vent to the cam chamber if possible and plug the rear vent. I always run 2% castor as bolsters the synthetic providing extreme pressure qualities that synthetics alone do not provide. The main objection some folks have with castor is sticking or gumming at times. It does not take much castor to get the barrier protection. At 2% TO 5% or even a bit more, gumming is not a problem.
If there is no oil there, of course, the cam will probably turn colors and wear out quickly as mentioned. Not enough oil or oil that doesn't provide higher levels of barrier film, it may take proportionally longer. It is all relative. Klotz® rates their Super Techniplate® anti-wear qualities at 20% better than the Original Techniplate®. The difference is, Super Techniplate® has castor added. Same oil, with castor, 20% better film strength.
I also pack the rocker boxes of Saitos with Bel-Ray® synthetic grease. No sticking or wear problems there! (Not needed with YS as they lubricate all areas very well!)
Jesse Open is online now
