O.S. 120 AX Bearing Upgrade?
TN
The bearing retainer on my engine came apart today and ended up on top of the piston. It locked it up but also collapsed the ring groove and stuck the ring. I was very lucky with the that it did not do any damage to the sleeve. I don't even have 5 gallons of fuel through it yet. Is there a better bearing that some of you are using? Also an upgrade to the ring?
