Inverted Enya 90 4-C
ON, CANADA
I have a 4 cycle inverted engine in a scale plane. When I run the engine the first time it runs fine, but after the first flight I can't keep it running at low spped if I remove the glow driver it starts failing until it stops, the fuel tank is a little higher.
Any one can helpme with this one, I tried with differents glow plugs OS F and Enya #3 with not success.
Bar98
Bar98
