OS 55AX
RE: OS 55AX
ive had that happen to me before....i got some long 6-32 bolts....dremeled a bit off muffler to accommodate for some nylon lock nuts...worked well...
so you mean the muffler threads are stripped out of the muffler...or the socket heads are stripped?
TX
RE: OS 55AX
Thanks for the link.....but the problem is how do I remove them safely without damaging the engine? They are on there tight..........which is probably the reason they are stripped out....
My Feedback: (47)
IL
RE: OS 55AX
What I have used are called "screw out" by craftsman/sears. There may be an easy out type that is made the same way. They are very sharp and they turn to the left (CCW). the smallest really digs in and will normally bring the messed up screw right out.
Fred
Fred
My Feedback: (264)
MD
RE: OS 55AX
You will need to use a very sharp drill bit to cut down (carefully) through the center of the socket head. When you have cut deep enough, the head will pop off.
My Feedback: (264)
MD
RE: OS 55AX
ORIGINAL: fredscz
What I have used are called ''screw out'' by craftsman/sears. There may be an easy out type that is made the same way. They are very sharp and they turn to the left (CCW). the smallest really digs in and will normally bring the messed up screw right out.
Fred
Fred
My Feedback: (14)
RE: OS 55AX
Or - clean up the socket heads and a fitting Allen wrench. Put a dab of CA into the socket head bolt, insert the Allen wrench, then give it a squirt of CA accelerator. Voila! You can now remove the muffler bolts. Yes, I've done this one. It's not just theory. It works.
Ed Cregger
Ed Cregger
ID
RE: OS 55AX
I have tried most of the suggestions thats been mentioned here myself and all have worked to a extent with good to poor results. One option that I didn't see mentioned though was to take a dremal with a cut off blade and actually cut slots in the head of the screws so a flat bladed screwdriver can be used to remove the bolts. As a rule thats what I try to do first and if that fails I then proceed to drilling the heads off. The secret there is to make sure you use a drill bit thats just fits inside the hex W/O touching it, the inside of the bolt is easily drilled out with a good quality drill bit. Hint once you have one removed a person should be able to just turn the muffler by hand to loosen the other one and be able to remove it.
My Feedback: (264)
MD
RE: OS 55AX
ORIGINAL: MinnFlyer
Read post #10
ORIGINAL: Cyberwolf
TX
RE: OS 55AX
Ok got it off.....thanks to my LHS. He used the dremel tool approach like some of you suggested. Thanks to all of you who replied....I learned some VALUABLE INFO.I installed the Jett muffler and this thing really SCREAMS!
