Magnum XL-15A BB ABC
Does anyone no if there is a venturi that will fit this engine?Would like to replace carb for c/l flying.I know you can just wire it open but that is weight i would like to get rid of.
Thanks guy's
Read more: http://www.rcuniverse.com/forum/m_97...#ixzz0pdCvrgEG
Thanks guy's
RE: Magnum XL-15A BB ABC
ORIGINAL: jayseas
Thanks guy's
Thanks guy's
if you can't find a venturi for it, you could simply tie and loop a piece of wire or even a rubber band over the carb in such a way as to lock it in the WOT position.
