G90 exhaust mounting hole distance
What is the distance between the mounting holes for the exhaust on a g90 as looking for a manifold and don't have the engine handy cheers
RE: G90 exhaust mounting hole distance
Oes anyone know of any manifolds for tunes pipes that will fit as all the ones I can find at 45 mm spacing what gives?
NM
noginblue; you might need to make an aluminum adapter from 47 to 45mm, the only 2 disadvantages would be that it would move the new manifold 2mm forward or backward, the other disadvantage would be it will extend out a quarter of an inch from the engine..
