Copper fuel tanks - any alternatives?
I'm looking at anew build and am thinking of a custom made fuel tank. I'm thinking of soldering one up from thin copper sheet.
I was wondering if glow fuel prodused any reactions with copper. Would I be better off using the 'tin' (im pretty sure they are steel since a magnet sticks to them) sheets that are sold in hobby shops?
1 Post
RE: Copper fuel tanks - any alternatives?
In my control line days we used tin sheet to make tanks.
We recycled the big dried milk tins but I think nowadays they have some kind of coating on the inside that does not solder well. So hobby shop tinned sheet it is.
Copper would work as well but be heavier and I think may be attacked by nitro.
You can easily solder the steel that is used for the manufacture of biscuit tins and such-like.
I should imagine that this material would likely outlive any model in which you care to put it.
I'd be inclined to modify a commercial container, such as an aerosol can; or a can that has a screw-top into which you can fit your connectors.
Most folks who make tanks use "tin", maybe 10 thou steel. Copper would work but would be heavier and softer. Copper works fine with nitro. It is brass which has problems. I've had the old Acme brass tanks corrode and leak.
AL
ORIGINAL: w8ye
The Acme company used to make brass control line tanks back in the good old days
Have any of these metal tanks ever used for RC airplanes?
If so, being closed, what the solutions have been for the flexible pick up tube and for the contact of the metal clunk with the tank walls?[sm=confused.gif]
Hi!
Tin tanks can of course be used where ever you want.
I have made two 110cc tin tanks used in my DC-3, powered by two OS .26 four strokes.
Tin plate is much lighter then copper and stronger than brass.
But why solder a tin tank if it isn't necessary?? I made my own tanks for the Marutaka DC-3 because I needed at least 100cc volume for each engine (at least 10min flight time) and at the same time I had very little room inside the engine nacelles.
AL
ORIGINAL: jaka
Hi!
Hi!
jess
The best part is the throttle pushrod that goes thru the tank!!![sm=thumbs_up.gif]
Allow me to ask again:
Being closed, what the solutions have been for the flexible pick up tube and for the contact of the metal clunk with the tank walls?
Any radio interference produced by that big area of metal?
My Feedback: (16)
I always started out with a new tank on a new model.
The old tanks were potential trouble with dirt and trash in the lines.
I do remember the old clear plastic fuel lines would turn milky and hard after a couple months and have to be replaced
Most metal tanks have no flexible pickup. For most RC they are not good for aerobatic flight. Some however use the same clunk system as with plastic tanks, I think they just solder a collar over a hole and use the same stopper, tubing, and clunk they use for plastic.
Hi!
As in a plastic tank you can use a flexible (silicon) clunk in a tin tank too. No problem!
There is however one thing to keep in mind when soldering a tin tank...and that is never ever use "Stay Bright" silver solder and its acid flux.
When I soldered my tin tanks for my DC-3 half a year went by before mounting the tanks in the engine nacelles. Luckily I tested the tanks prior to mounting them and one leaked! I noticed that one of the tanks had lots of microscopic holes in the sides. Closer inspection revealed that the tank had severe rust inside and that the rust had corroded the sides of the tank thin as paper...
The second tank was not affect by any rust at all. Why?? That tank had been filled with fuel after I soldered it, for checking any leaks, and the fuel (synthetic oil) contained anti oxidation chemicals.
Made one new tank and now used rosin core flux instead of the "Stay Brite" flux variety.
Very interesting, Jaka; thanks.
What about the contact of the metal clunk with the tank walls?
The reason I want a big tank is because I'm planning on running a Wankel. These things drink glowfuel like Barney drinks Duff. And I want more than a 2-3 minute flight. So I'm hoping to make a tank that takes maximum advantage of the space available.
BTW - I've always loved the DC-3. I went for a flight in one a few years ago and it was one of those experiences that you remember for the rest of your life. Even got to go up to the cockpit. But they wouldn't let me take the controls
