OS-Model 1901/FS-90 PARTS NEEDED!
Augered in my Robbe PA-18 today and dinged my vintage FS-90.
I'm in serious need of pushrods, cover tubes and the mounting bracket that secures the carb body to the crankcase. A needle valve assembly is also required.
I've reaqd that OS and the Stateside distributor do not have parts for pre-1990 engines so I'm pleading my case here in the forums.
Appreciate the assist!
Pointmagu
[email protected]
Pointmagu
[email protected]
NE
RE: OS-Model 1901/FS-90 PARTS NEEDED!
Give this guy a call. He might or might not have what your looking for.
http://stores.ebay.com/ROBAIR-HOBBY-...34Q2ec0Q2em322
TX
Have you found what you was looking for? Ive got this very engine and need parts to but havent been able to locate what Im needing. I had run to large of an prop and shered the three screws that mount the timeing gear to the rear bearing (not sure what its called) area. Is there anybody that works on these older engines? I really would like to get mine fixed and running again.
