RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Glow Engines (http://www.rcuniverse.com/forum/glow-engines-114/)
-   -   OS 40 FSR (http://www.rcuniverse.com/forum/glow-engines-114/10811008-os-40-fsr.html)
Bladejunkie 11-13-2011 09:45 PM
OS 40 FSR
Hey all,am wondering if anyone could point in the right direction as to where to find parts for my old OS MAX 40 FSR.This engine was my first brand new store bought engine(1984).I've got new bearings,but I need a gasket set and possibly the o-rings for the carb.I'm restoring my first trainer,a Bridi Krafty 60,and this engine is it's powerplant.
Thanks in advance Jim.
vpresley 11-13-2011 09:52 PM
RE: OS 40 FSR
Hi
Not making those any more, to old. The gasket you can make your self. The O-Rings you can buy. Might check your local hobby shop, should be able to find an o-ring from a newer engine that will fit. Some times Ebay and RCU has the parts for sale. Just have to watch for them.
Vince
TFF 11-14-2011 09:10 AM
RE: OS 40 FSR
Mine was a .40 FSR on a Jensen Uglystick. Gaskets show up on RCU and Ebay. Some Magnum/ thundertiger clones might also fit. Rings are only available from Bowman unless you get lucky with a NOS one. I still got my old stuff too; Hmmmm.
Bladejunkie 11-14-2011 07:51 PM
RE: OS 40 FSR
Thanks guys when you said clones I remembered that I had an old TT42 and its rear crankcase gasket is just what I needed.Now I have a couple other problems which way does the arrow on top of the piston point towards the exhaust port or towards the intake port?Also the flat sealing side of the head has a machined "dimple"on it does it have a certain way it goes?I took this engine apart about twenty years and one move ago so the old memory is kind of foggy.
Thanks again Jim.
fiery 11-14-2011 10:27 PM
RE: OS 40 FSR
Arrow to exhaust port
Dimple at rear.
Nice little engines the FSR's.
Bladejunkie 11-14-2011 10:47 PM
RE: OS 40 FSR
Thanks fiery,I'll button her up Tues night.Now anybody have a 743 silencer they'd like to sell or know where I might find one?
Thanks Jim.
fiery 11-14-2011 11:04 PM
RE: OS 40 FSR
Silencers made for the Magnum 40 and 45 PRO and Royal 40 and 45 (FSR copies) will fit, as will silencers made for the Irvine 40 Mk II (same construction pattern as the 40 FSR) and ASP/SC 40 (series 1 with bolt on silencer).
They all come up regularly on the famous internet auction site.
Bladejunkie 11-17-2011 10:13 PM
RE: OS 40 FSR
Just an update guys,started my engine yesterday,and it ran great!!!Ran it with no muffler,very loud but a good loud.I'll probably buy a Mac's adapter plate and muffler.It started on the first flip(hand start)with the original plug that was installed in 1984.
Thanks for all your help Jim.
fiery 11-18-2011 07:24 PM
RE: OS 40 FSR
1 Attachment(s)
Found my OS 40 FSR ring. It had been laid up for many years. Spun it up on FAI (nil nitro) home brew fuel. 80% methanol, 20% Fuchs Castorene R40. Taipan broad blade orange composite 10x6 propeller. Idle RPM steady mid 2,000's. Top RPM 13,200. OS 8 medium reach plug first, then a long reach Firepower F6, which picked up 100 rpm's and offered lower idle. Clean pick-up even after prolonged idle. The OS 4 BK carb is superb. Exhaust note is nice and loud - no baffles in the muffler.
A nice sports .40 engine when released over 30 years ago. It still is.
blw 11-18-2011 07:56 PM
RE: OS 40 FSR
"nice and loud" is just right.
Roary m 11-18-2011 08:09 PM
RE: OS 40 FSR
I'm curious; is the carb the 4D or the 4BK?
NoOneFlysAtMyClub 11-19-2011 12:07 AM
RE: OS 40 FSR
My .45F has the 4BK carb, my SF .40 has the 4D carb.
Both carbs are the same internally. All parts interchange.
jeffie8696 11-19-2011 05:11 AM
RE: OS 40 FSR
Ithink the FSR engines are tuned for more power at higher RPMs than most modern engines, my FSR 40 was amazing. Ihave a nice 45FSR that Ineed to test but have been to busy. Ithink Iwill end up selling it anyway since I have no current use for it and have a ton of 40 size engines.
Bone 11-19-2011 01:21 PM
RE: OS 40 FSR
ORIGINAL: fiery
Found my OS 40 FSR ring. It had been laid up for many years. Spun it up on FAI (nil nitro) home brew fuel. Taipan broad blade orange composite 10x6 propeller. Idle RPM steady mid 2,000's. Top RPM 13,200. OS 8 medium reach plug first, then a long reach Firepower F6, which picked up 100 rpm's and offered lower idle. Clean pick-up even after prolonged idle. The OS 4 BK carb is superb. Exhaust note is nice and loud - no baffles in the muffler.
That's one seriously good looking engine - I have a handful of OS 40's released before & after the FSR series, but no actual FSR's....... [:o] weep, moan, weep
I do however have a Royal 45 "FSR look-a-like" engine, with a very similar looking carb & bolt on front housing. Impressive performance on the bench & now looking for a suitable pusher model to take advantage of that bolt on front housing to reverse the rotation scenario ;)
fiery 11-19-2011 01:47 PM
RE: OS 40 FSR
Hi Bone
I have a NIB Royal 40 FSR as well. Very nice looking engine, pretty much a clone of the OS 40 FSR ABN. I will give it run one day. The only thing I have done is to trial fit RJL diesel head on it. Bolted up perfectly. The 40FSR engines have the same bore as the OS 40FP.
Mikejetboat 07-13-2013 06:17 PM
RE: OS 40 FSR
I recently found a never used .OS.40fsr ,and a old brand new in the box top flite HOT KANERY, same combo I had 35 years ago. Those engines ," in my opinion" , are the best ever made of that size of all companies.Have anybody tried that screaming ,gold head, .48 that K&B made 18 years ago?
Roary m 07-18-2013 10:54 PM
RE: OS 40 FSR
Hi Mike; I'm curious about where your balance point is on your Hot Kanary. I ask because I have one and would like to get him back in the air again(I built him back in 1988). If I remember, he was tail heavy.
Mikejetboat 07-19-2013 03:37 PM
RE: OS 40 FSR
I just unroll the plans, it has three points, the best according to the plans is right in front of the top wing. the other two are 1/2 in in front of that, and the other 1/2 behind, I flashedbacked and remembered I made mine alittle nose heavy . MIKE.  The kit I found  has every thing in it including the building booklet ,monocote ad with sample, and a order form for a Topflite jacket. Let me know if you need anything else.
iskandar taib 07-20-2013 10:48 AM
RE: OS 40 FSR
Hey! Orange Taipan prop! I've got a few of those lying around, too, don't see them much any more.
Iskandar
jeffie8696 07-20-2013 12:39 PM
RE: OS 40 FSR
You guys are gonna make me put new bearings in my 45FSR and fly it now aint ya.
fiery 07-21-2013 01:40 AM
RE: OS 40 FSR
Iskandar
The Taipan composite props were a great prop in the '70's when first released, and are still seen occasionally in flying fields around Australia. They pull your ship out of tight turns like no other.
The C/L combat guys still use the nylon versions 40 years on.
Jeffie, put new races in your FSR and fly the thing. It will put a smile on your dial :D. Truly one of the best performance sports engines ever made by OS.
jeffie8696 07-21-2013 08:55 AM
RE: OS 40 FSR
I gave an OS40FSR to a flying buddy , it was one of the best running engines I have ever tested. I have the 45 and will install new bearings in it and fly it on my Escapade. I like those Taipan props on my 4 strokes , the wide blades really dig.
