Fuel oil conversion 32:1? How many ounces per gallon.
Does anyone know or have a conversion for 32:1.
2 stroke oil in (ounces ?) to 1 gallon of gas. Thanks! |
4 oz to the gallon. Good conversion chart for 32 to 1 all the way up to 100 to 1 on the BME website.
Ed M. |
What are some of the best 2 stroke oils for gas engines? What do some of the rest of you use?
I use Honda 2c oil in my hobby motors and all of my home equip. (chainsaw, weedeater, etc.) Never had any problems even after leaving gas in tank all winter long. (not aircraft tanks)
Any good name brandoil is fine. Esso etc.
stl pilot,..............to get the fuel-oil mix right, just divide the ratio number,.....32, into the number of ounce's in a gallon,.....128. the answer will be the ounce's of oil reguired for that ratio. good luck mixing,.......bill
128.00 ounces is 1 US gallon of water weight at sea level at the equator.
does gas and oil have the same density? i'm just foolin' with ya ... it's close enough. thanks for the tip! |
Originally posted by STLPilot 128.00 ounces is 1 US gallon of water weight at sea level at the equator. does gas and oil have the same density? If you want to get some good oil go to a motorcycle shop or boat shop, either will have several very good blends of high performance oils. Even so, plain ol' 2-cycle oil will do just fine for a 32:1 ratio. It's when you get to the 50:1 and 60:1, etc., ratios where you need the primo oils. |
Originally posted by MILDBILL stl pilot,..............to get the fuel-oil mix right, just divide the ratio number,.....32, into the number of ounce's in a gallon,.....128. the answer will be the ounce's of oil reguired for that ratio. good luck mixing,.......bill |
Sport_Pilot, that's not right. The engine manufacturers don't make it that complicated. 32:1 is a RATIO, 32 parts gas to 1 part oil. So, in an empty can, you place 32 ounces of gas, and one ounce of oil.
For a gallon of gas, you have 128 ounces of gas, and 4 ounces of oil, for a total of 132 ounces. There's always a bit of air space in a gallon container, easily enough for 4 ounces of oil. If you want EXACTLY a gallon of liquid, then you divide 128 ounces by 33 ounces. In that case, you end up with 124.21 ounces of gas, and 3.79 ounces of oil. This is what those pre-measured bottles are for. You dump the oil into an empty can, then add enough gas to make exactly a gallon. Where did 20% come from? |
You are right. I screwed up. The 20% came from the 4:1 example. Each part is 20%.
