Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
Kraft 2.4 ghz conversion help needed
Reply
Old 01-23-2012, 02:53 PM
aerowoof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Kraft 2.4 ghz conversion help needed
Trying to do a Frsky comversion on a 1980 5c and a 1979 7c.where to pick up the ppm signal from the encoder board as well as the +v and -v,alot are using the trainer port on other systems which the 7c has but the 5 c does not.Anyone have any suggestions .
aerowoof is offline
Old 01-23-2012, 05:23 PM
glasair
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Kraft 2.4 ghz conversion help needed
Check http://groups.yahoo.com/group/MP8K/ and ask that question.
glasair is offline
Old 01-23-2012, 05:32 PM
aerowoof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
not a member
aerowoof is offline
Old 01-25-2012, 08:31 AM
Michaelj2k
Michaelj2k's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Search in here. http://www.rcgroups.com/radios-135/
Michaelj2k is offline
Old 01-25-2012, 10:39 AM
modeltronics
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have done conversions on 2 Kraft radios. Please look at the info here.
http://www.rcuniverse.com/forum/m_10...m.htm#10097051
I found that I had to modify the signal on the PPM line. The 2 radios I did the modulation went to almost the + battery voltage and the Frsky wants to see a modulation swing of 5 volts. Also I inverted the modulation signal before feeding into the Frsky module. This is simple to do and will only take a 5 volt regulator, an NPN transistor (2N2222) and a couple of resistors.
I don't know for sure if you will have to do this. It worked for me. As far as finding the PPM modulation point, it is easy with a scope.
I didn't tell you what you wanted but I hope this may help.
Pete
modeltronics is offline
Old 01-28-2012, 06:11 PM
aerowoof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that is what I was looking for thanks
aerowoof is offline
Old 01-28-2012, 07:51 PM
aerowoof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
modeltronics,
if you leave the 72mhz Kraft rf module in place and just solder the frsky hack module to the encoder board or trainer port
won't their be rf transmision on the 72 mhz band as well as the 2.4 ghz band? I have seen the frsky hack module used on
jr 6102 and 7202 tx with the all in one board,rf board is part of the encoderboard.doesn;t the same thing happen where the 72 mhz rf section is still live as well as the
2.4 ghz module ?haven't seen this asked before or brought up before.
aerowoof is offline
Old 01-29-2012, 03:07 AM
ukengineman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Removing the crystal will stop transmission on 72MHz
ukengineman is offline
Old 01-30-2012, 09:56 AM
smallrc
smallrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
aerowoof,
For both the 7C & 5C, if you look at the wires at the RF module, the red wire is +9.6 V (switched batt +), the black wire is 0 V (ground) and the yellow wire is PPM (modulation, neg pulses at or near batt voltage). You can also find these wires at the encoder on a 4 wire plug along with an orange/blk wire. To convert PPM to 5V positive pulses, connect the yellow wire through a 47K resistor to the base of a 2N2222 or 2N3904 transistor. Connect collector through 4.7K resistor to 9.6V and emitter to ground. Connect a 5V or 5.1V zener diode (1N5231 or similar) directly across emitter and collector, cathode (stripe end) to the collector. PPM output for the FrSky module is at the collector. If you need more detailed info, PM or email me - smallrc@yahoo.com. To disable the 72 MHz RF, simply remove the module. Hope this helps...
smallrc is offline
Old 01-31-2012, 05:24 PM
modeltronics
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry. Some how I timed out on RCU and it double posted for me
Old 01-31-2012, 05:26 PM
modeltronics
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry to take so long to get back to you. I have been away from a computer for a few days. The way smallrc talks about should work very well. I did not have a zener diode so I used a regulated 5 volts on the collector of the NPN I used and inverted the signal at the same time. If I had to do it over again I think I could do it with a 741 op-amp to invert the PPM signal and limit it to 5 volts. On the Kraft Spectrum I pulled the module out. On the '74 Kraft it did not have a module and I just removed the crystal.
Pete
Old 02-01-2012, 06:18 PM
aerowoof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
trying to find parts at radio shack they don't seem to carry the recommended number but did find this,would it work?
NTE5010A 5.1V 0.5W Zener Diode
aerowoof is offline
Old 02-20-2012, 11:11 AM
aerowoof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
found these schematics for the 5c and 7c an posting them in order to help others
File Type: pdf
aerowoof is offline
Old 02-20-2012, 11:18 AM
iflyj3
iflyj3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: aerowoof
Where did you post them?
Got it, Thanks again.
iflyj3 is offline
Old 02-20-2012, 11:25 AM
aerowoof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
post above yours kept getting an error message finally went thru.
aerowoof is offline
Reply
Display Modes
