Ben Shereshaw's Mercury
pick up a short kit for this on rcg,orginal plans show 72" span and Ignition engine.want to do it r/c with 3 channels.rcommendations for glow power and electric power would be welcome.thinking soething in to .19-.25 size glow and maybe a power 25 brushless for electric.
AR
RE: Ben Shereshaw's Mercury
This one is rated for a .40 4-stroke. A .19 two stroke could be a little light weight, but the .25 might do it. If I was doing it (and I do have the very same plans here on my build list), I would go with something in the .30 range. Mine will either have an O.S. .40 4-stroke or a Saito .45.
The electric option, in my case, is a Hacker A30 14L. My guess is about 2.5 to 3 lbs. when built. Start yours first and be my guinea pig, please!
ORIGINAL: aerowoof
For what ever its worth I power my 80 inch playboy with a modern OS .35AX that is absolutely superb on that airplane. I choose the modern engine also because of it outstanding idling characteristics after very long idle periods.
I can make a launch and then go to full power for the vertical then back to a low idle and it remains in idle's up to 36 minutes long which is when it runs out of fuel on a three ounce modern Hayes tank.
http://www.youtube.com/watch?v=6C6ow...3&feature=plcp
John
[youtube]http://www.youtube.com/watch?v=EpRYvH_34RE&list=UU4HLk42VM0CCjglQ2KPcYdA&index=2&feature=plcp[/youtube]
You might like to see some video of my friend's Shereshaw Commodore in action. Footage was taken a couple of weeks' back in East Yorkshire. There's a Glenelg and an Alert, too.
Or, you might care to see a "Bigger Stuff" and "Madcap".
[youtube]http://www.youtube.com/watch?v=Zj3BUQajDbw&list=UU4HLk42VM0CCjglQ2KPcYdA&index=1&feature=plcp[/youtube]
