vintage r/c recievers
I am looking for a reciever that will work with my Citizen ship single channel Tx. Model TTX transister tone transmitter (27.045 )I know they used to make a brick( batt. pak. reciever, excap. all role up in one) but I would take any thing that will work. call or email Bob Mann 425 775 4892 or [email protected] thanks.
Location: Brotherton, UKNorth Yorkshire, UNITED KINGDOM
RE: vintage r/c recievers
Its an ideal candidate for a conversion to 2.4g Bob. Much more reliable, lighter airborne weight and exactly the same S/C experience.
Check the "2.4 Conversions" page of http://www.singlechannel.co.uk
Cheers
Phil
Cheers
Phil
I no i dont want one with a relay ,one on 27mh I dont want to change the cystal if i can help it call 425 775 4892 if any buddy can help some of this is a little greek. Bob
According to the manual, that transmitter is relatively low power, meant for park fliers that don't get too far away. I personally don't like the button setup on it. There's better single-channel transmitters like the Ace Wee One.
Are you really attached to that transmitter in particular for sentimental reasons? If not, consider taking your time and shop the bay for a system you can use, then turn around and sell that one.
Have just viewed the forum , see that you are looking for a reciever , Citizenship SSH Superheterodyne on 27,045 also have an Onterion 021 on the same It is 1/2 the size of the ssh call if you are intrested
Steve
912-531-0220
Steve
912-531-0220
You are better off in any case with a superhet, but like mentioned, if you are flying in a small area, and the plane stays close, and you are not near a major metropolis and interstate (CBers) a regen relayless receiver could be OK.
If you use a superhet, be sure to replace the Tx and RX crystals, or at least get their frequency checked as all these vintage radios have old crystals which typically have drifted at least 2 kilohertz or more and cause them to not have good range and glitch.
I sell a reproduction ACE Pulse Commander Receiver that can be modified to drive an escapement, or a 100 ohm relay, it works on 2.4 volts.
