Help with info on this Super Tigre engine
LA
I need help with some specific information on the Super Tigre engine in the photos. On the exhaust side of the cylinder it says "Series X G.60". On the other side it says "Made in Italy by Super Tigre". It has a crankcase vent but it is plugged and not being used in the old Aeromaster Biplane in which it is mounted. I can recall years ago that it hauled that old "heavy" Aeromaster around the sky with quite a lot of authority. I would like to get some idea as to the vintage of the engine and whether it is anything special as Super Tigre engines of that vintage go. I have looked on-line but all of the similar looking "Super Tiger .60 Bluehead" engines I could find had a large, rather conspicuous bypass port running up the side of the cylinder. This one has nothing of the sort. Since this one has a bolt-on front end, I would like to get it running, rotate the front end 90 degrees so it will run in "reverse" and use it in a pusher aircraft. Any information you guys can give will be greatly appreciated.
My Feedback: (9)
RE: Help with info on this Super Tigre engine
The "X" series are later than the old blue heads you are thinking about . The x's are Super Tigres first schnerle ported engines & made in the 1980's if I remember right . Why mess with the engine just buy a reverse pitch prop. Max H.
