Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
Fleet Brotherhood
Reply
Old 10-08-2012, 06:33 PM
  #151
retransit
retransit's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Fleet Brotherhood
I can get 6061 aluminum for you if you want. I used 1/4" thickness and had to file a bit off so it would go into the receivers. My source may have some other thicknesses. I can check.
Bob
retransit is offline
Old 10-09-2012, 05:05 AM
  #152
Fleet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the offer Bob.  I have several sources for alumnium and steel plate but just don't cherrish the idea of grinding off a few thousenths with a hand file.
The wood ply may still make the cut as I've some treatments in mind and I remember that I flew my 1/4 scaler with the stock spars with no problem for 5 years.   The screw holes rounded out a bit but some CA tightened them up.   This time I'm looking at  a good soak with thinned epoxy and some embedded nut plates.  We'll see.
Those pix are great.  Very red on one of them.
Ray W.
Fleet is offline
Old 10-10-2012, 07:31 AM
  #153
Hot Rod Todd
Hot Rod Todd's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just listed a 1/4 scale Concept Fleet kit on Ebay. It looks like new, donated by one of our club members.
[link=http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=261111318973#ht_82wt_1129]Concept Fleet Kit[/link]
ID:	1809895   Click image for larger version
Hot Rod Todd is offline
Old 10-10-2012, 08:37 AM
  #154
retransit
retransit's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I could have used that six months ago.
Bob
Old 10-12-2012, 03:32 PM
  #155
MX240
MX240's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is a picture of my Fleet Biplane.
Power is a Satio 5 cyl
A good flyer
MX240 is offline
Old 10-13-2012, 04:28 AM
  #156
Fleet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very nice angle for the photo.   Looks like the vegitation is beginning to go into winter mode in Podunk.
Further info on your cockpit combing if you will.
Ray W.
Fleet is offline
Old 10-13-2012, 05:53 AM
  #157
retransit
retransit's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ray, that looks like Foremost brand coaming.
http://www.fourmost.com/index.cfm?fu...id=68&id=98060
Bob
Old 10-13-2012, 06:18 AM
  #158
dabrown
dabrown's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Aircraft Spruce has 2024 alum bar stock for about $8/ft for 3/16". I measured my ply joiners and they are 0.200". The next thicker they have is 1/4". Probably will check with my local machine shop to see if they can make them and possibly mill 1/4" to .200". But I know I won't like what they'll charge. Maybe just go with the 3/16" even if a bit loose - it'll be strong enough.
I'm just about done with the basement guest room project so hoping to get back to work on the Fleet. Soldered up the cabanes and landing gear. Next to finish the elev rudder pushrod install and do some reinforcing in some places in the fuselage.
Dave
ID:	1810770   Click image for larger version
dabrown is offline
Old 10-13-2012, 06:36 AM
  #159
MX240
MX240's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Fleet
Ray W.
Thanks for the comment.
Because of the terrible drought we had this year all the grass looked like this most of the summer. No rain over a inch since June 20th.
Yep, fourmost!
MX240 is offline
Old 10-13-2012, 06:43 AM
  #160
Fleet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is what I sorta expected (Foremost). I've some I purchased sometime back (not near enough) but still looking for something different. RCAF motif is my expected scheme in 1/3rd scale.
I may have to drive down to Boca Raton and fetch some rat skins.
Ray W.
Fleet is offline
Old 10-13-2012, 02:02 PM
  #161
retransit
retransit's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave, while the structure is open you may want to reinforce the fuselage spar tongue receivers so that they do not come apart later.
Bob
Old 10-14-2012, 02:40 AM
  #162
gordon_mcln
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Guys,
Just a quick fyi on the T6 aluminum which you can get from Tower Hobbies made by K&S. Y The part # for strut material is K&S 3070.
Gordon
gordon_mcln is offline
Old 10-14-2012, 07:54 AM
  #163
retransit
retransit's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is aluminum sheet (.064"), not at the thickness that is required for the tongues.
Bob
Old 10-15-2012, 05:42 AM
  #164
gordon_mcln
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys,
Quick question on the fuselage taper into the firewall on the Concept Fleets. I'm building the Ron Weis Fleet scaled down to 1/4 scale. The fuselage does not taper from the front wheels mount into the firewall. From what I see on the Concept Fleets, this area appears to taper somewhat....I don't yet have the cowl, which may give me that answer, but I thought I'd ask ahead of time. Framing up the sides at the moment.
Thanks in advance.
Gordon
Old 10-15-2012, 05:53 AM
  #165
Fleet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes , there is a taper that is hogged out of the thick fwd sheet.   The fuse sides have the stringers up to about the fwd cabane strut then meet and fair into the solid sheet that will be sanded to taper to the plywood firewall.   I'd wait for the cowl to be more difinitive.
The fiberglass cowls of my 1/4 and 1/3 scale Fleets fit snuggly over the plywood but are held on with screws into maple blocks epoxied to the firewall.
Hope this helps.
Ray W.
Fleet is offline
Old 10-15-2012, 07:27 AM
  #166
retransit
retransit's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Agreed!
Bob
Old 10-15-2012, 07:32 AM
  #167
Fleet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I found some suitable cockpit combing and some rigging componets at Proctor. So much yellow now with a little black. Top wing done and ready for paint while the lower wing problem resolved and now onto filling the weave with dope. I love plinking the finished wing fabric.
Bob... can people leave their trailers overnight at the flying field? I've reservations for a local motel but thought , with the proper locking features, the trailer and equipment should be safe?
I'm heading down to Daytona this weekend to see the new Grandaughter and her family. Here's to hoping the weather is nice to travel. 5.5 hours last time I did the trip.
Ray W.
Fleet is offline
Old 10-15-2012, 08:35 AM
  #168
retransit
retransit's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For the Giants, yes. We will have someone on the field Friday and Saturday nights.
Bob
Old 10-15-2012, 08:41 AM
  #169
retransit
retransit's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gordon, wait until you get the cowl before you taper the front of the fuse. The image below shows the difference on the original 1/4 scale Fleet plans, but the cowl has to be fitted, as the taper changes top to bottom.
Bob
Old 10-15-2012, 08:44 AM
  #170
gordon_mcln
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bob,
Thanks for the snap shot...That helps a lot....
Gordon
Old 10-15-2012, 08:54 AM
  #171
retransit
retransit's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gordon, I edited the picture.
Bob
Old 10-15-2012, 09:00 AM
  #172
retransit
retransit's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Actually the larger (lower) dimension is supposed to be 7 1/2".
Bob
Old 10-18-2012, 08:17 AM
  #173
smkrcflyer
smkrcflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just picked up a built ΒΌ scale one of these with a Saito 325 5 cylinder on it. It needs some work and all new electronic but it looks like it has not been flown. I will load some pictures when I get time.
smkrcflyer is offline
Old 10-18-2012, 10:34 AM
  #174
retransit
retransit's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Look forward to seeing them. It will be a great combo.
Bob
Old 10-18-2012, 11:06 AM
  #175
smkrcflyer
smkrcflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Its missing the N struts are there drawings available for these? What material should I make them out of?
Reply
Display Modes
