Digimite conversion
Digimite conversion
Here are a couple photos of the Bonner Digimite 8, circa 1965, that I receintly converted to standard AM PPM operation on 27 MHz by replacing all the electronics. The original Digimite encoder used a weird scheme of sending two pulses per channel, this was later simplified, but Larson did not think of that originally, prooving once again that hindsight is always 20/20! The original board had 35 transistors and must have been very expensive to produce, given that most radio after that had half the amount of transistors.
