Stand up starter
Stand up starter
An old flying bud built this in 1974 for a lot of Free flight work which was usually out in the boonies with none of the amenities we are so spoiled with at the fields today worked great the forward legs were articulated and the rear leg was telescoping with a micro switch. Folded partially.
He passed on several years back and the widow had a yard sale so his stuff disappeared but this recently surfaced at a local swapmeet and I just had to get it back to refurbish just because I always liked it for certain types of airplanes. Not really useful for a lot of what we fly today but thats OK.
John
John
RE: Stand up starter
It may well be Trisquire for certain sizes of airplane. Now originally he had used a large garden type lead acid and I simply used a small 18volt drill battery after rewiring and bypassing the power panel as I use for most of my starters now and I had emptied the drawers. Its likely he had those drawers filled and the heavy battery as it was also probable that the largest engines he had used was around oh up to .25. So it would be fine on the ground.
What I found with my .35AX powered old timers and the box sitting on cement that it was difficult to use. The triggering of the microswitch was not problem but you had to push pretty hard to get a good seal on the driver cup to prevent slipping of the rubber. After possitioning with the box backed up to an immovable object it worked great. Perhaps in the past that immovable object could be the wheel of your car.
Another thought occured to me that shovel like blade on one end of the boxes feet could prevent the box from moving when on a dirt surfacel.
At any rate its a cool bit of modeling history and been fun.
John
John
