Has Anyone built and flown this plane ???
My Feedback: (28)
PA
Hi-- After opening a bunch of boxes in my basement, looking for my wood supply, I cam across this old biplane called a StarHawk, from a Co. called Thorpe. It's sort of an old ARF, from back in the early 80's. Pretty much requires the same general type of assy as the newest stuff. The wings are sheeted foam cores, and the fuselage is a completely sheeted unit, and the whole plane is painted. Looks like a nice paint job, very smooth and shiny. This kit calls for a 2 stroke .60 size motor. Is there anyone who built and flew this model, and how did it fly?? Do u have any recommendations as far as motor requirements, and setup ?? Any other comments are welcome- good, or bad- I just want to know-- Thanks - Dean
PA
C/G
I had the same plane there were no instruction when I bought it . but I put a sato 91 in it thinking that would be good wrong. I crashed landed it . it was very tale heavy and the landing gear weak and once you get the wheat right its to fare back . so I needed to put more wheat up front so reinforced the fuse just in front of the wing and installed a dobro landing gear .witch is stronger and ads wheat and also added 3oz right on the engine mount . and it flow great . especially inverted all most no input inverted if you have any ???? call 267 431 5574
VT
bird
