Go Back  RCU Forums > RC Airplanes > Golden Age, Vintage & Antique RC
Reload this Page >
Need help with twist in fuselage after cover with solartex
Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
Reply
Old 02-08-2018, 11:37 AM
sw74gls
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Need help with twist in fuselage after cover with solartex
Hi guys I'm absolutely gutted I have spent a long time building a tomboy 36 for my daughter having never built a open frame model before I got everything perfectly straight and level before covering, then after covering with solartex I've noticed a considerable twist in the fuselage towards the back where the horizontal stab sits??? I thought I'd been extremely careful when covering but obviously not.
please tell me this isn't a throw away? ? I would really appreciate your help many thanks Simon.
sw74gls is offline
Old 02-08-2018, 01:01 PM
Truckracer
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Probably not a catastrophe! First, can you twist the fuselage back in shape with the covering in place? If so, you can probably just over twist it a bit and re-iron the covering while holding the reverse twist. This may take another pair of hands. This will allow the covering to reform to a new shape and hold the fuselage straight. You may have to repeat this process several times to get things where you want them to be.
If you can't twist the fuselage to a straight position, try removing one panel of the covering. This should allow the twist. First follow the above directions then add back a new piece of covering where the one was removed.
Absolute worst case, just remove the covering and be more careful when recovering. Many structures are actually held in place and straight by the covering so warps are easily introduced during the covering process. When covering, check, check and recheck during covering. When you do something on one side, follow with the same on the other side so the pulling forces counteract each other. Be thankful you used an iron on covering that is easy to removed with a bit of heat. A real catastrophe is when you have the same problem with silk and dope or an equivalent painted covering.
Truckracer is offline
Old 02-08-2018, 01:49 PM
daveopam
My Feedback: (9)
daveopam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As said above it can be fixed. Just twist till it wrinkles then hold that and heat out the wrinkles. It may take a few times before it will stay but it's an easy fix. I've straightened many a wing this same way.
David
daveopam is offline
Old 02-08-2018, 01:52 PM
UStik
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Maybe you mean like in
UStik is offline
Old 02-08-2018, 02:18 PM
daveopam
My Feedback: (9)
daveopam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'd ask for a royalty but I use a gun :-)
David
daveopam is offline
Old 02-08-2018, 03:41 PM
sw74gls
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you so much guys for all your advice I will take this on board and see how it goes let you know soon, Thank you once again, simon.
sw74gls is offline
Old 02-09-2018, 12:50 AM
UStik
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
David
Well, that's just "a little bit more dangerous". :-) (Thanks for the joke, made my day.)
UStik is offline
Old 02-09-2018, 07:56 AM
sw74gls
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys I followed what you said while twisting and holding fuselage I applied heat to one side and when it cooled I let go and everything was perfectly aligned, I would never have believed it you certainly learn something new evert day!!!
All sorted now thank you all so much for your help, Simon.
sw74gls is offline
Old 02-09-2018, 07:57 AM
sw74gls
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sw74gls is offline
Old 02-09-2018, 08:41 AM
Truckracer
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So glad it worked for you! We've all been there before and this is just part of learning new skills while building our projects.
Old 02-09-2018, 11:48 AM
daveopam
My Feedback: (9)
daveopam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's great!! Happy flying.
David
daveopam is offline
