Forest 29 Ignition Question
AZ
I have a Forester 29 ignition engine in great condition What size (wing area) RC assist Freeflight would be suitable for this engine ??
Would appreciate any suggestions
Jim Whitney
Jim Whitney
My Feedback: (9)
RE: Forest 29 Ignition Question
Jim: What I can find you need a minimum of 625.5 sq. in. & R/C assist with a minimum weight of 44 oz. This is from the Klarich Kit List , they have several planes that will fit this for you, just depends how wild you want to get . E-mail [email protected]
Good luck , Max H.
Good luck , Max H.
NC,
This engine is considered a class "B" size so any of the old designs that called out class B should be suitable. The actual weight and wing area depends on the type of flying that was intended.
I've got a Forster .29 myself that will be going into a Brooklyn Dodger kit designed by Sal Taibi. That's the engine he used originally in this model.
I have a Forester 29 in good condition. Do you know what it is worth? Also have a Phantom gas ignition motor with points. Are you familiar with it? I can't fine any info on it
My Feedback: (9)
You almost need to post pictures as there are several different years & models of both engines . You can put them here or send them direct to me at [email protected] I can most likely fix you up . MAX H.
