If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 108 of 756 FirstFirst ... 85898106107108109110118158208608 ... LastLast
Results 2,676 to 2,700 of 18895
Thread: WACO YMF
  1. #2676
    Join Date
    Mar 2007
    duncanville, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Hey guys, I need some help. Without going all the way through what has now become this online book, can someone tell me the best type of hinges to use on the ailerons, and suggest how to install "invisible " control horns on said control surface? Please remember mine is the 1/4 scale version. Thanks
    Scott
    Waco Brotherhood #49
    I buy, I build, I fly, I crash. I buy, Ibuild, I fly, I crash. I buy, I build,................
  2. #2677
    skylarkmk1's Avatar
    Join Date
    Sep 2004
    Festus, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Mango,
    The full size Wacos use top hinge ailerons (piano hinge) and the control horns on the lower ailerons are ball links. The full size control rod is totally exposed from th bellcrank to the control horn. The upper ailerons are driven by the aileron conecting rod attached near the trailing edge of the ailerons.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	694875   Click image for larger version.
    John F Howard (aka skylarkmk1)
    AMA 10955, WACO Brotherhood #26, AWC, NWC
  3. #2678
    Join Date
    Oct 2004
    Richmond, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Bill,
    Do you make sure every inch is covered with fabric?
    I have a couple spots where it would be impossible to cove the entire wing with one piece. These are the corners of the aileron pockets where I had to slit the fabric to allow it to wrap around the trailing edge of the hinge surface and still extend down to the knife edge portion of the trailing edge. I was thinking about either leaving them without fabric or just doping on a bit of scrap fabric to cover these areas.
    Either way, the top wing really is starting to look like something now that it has fabric on it.
    I plan to start the bottom wing tonight using some of the knowledge I got from doing the top wing to change how I apply the fabric.
    The main difference is I plan to finish the trailing edge of the bottom of the wing with a finished edge then wrap the fabric aroud the front and back to the trailing edge and do the lap joint then. On the top I just tacked it down to the top surface of the trailing edge and then wrapped the wing and tacked it down to the bottom surface which meant I had to do both final trailing edge wraps at the same time which was not fun triming and sticking the fabric down like that.
    Robert
  4. #2679
    Stickbuilder's Avatar
    Join Date
    Nov 2005
    Leesburg, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    That will work as well. On the aileron pocket, I do cover the pocket first with a seperate piece, and seal to the edge with the main covering. (forgot that part[:@])
    Bill, AMA 4720
    WACO Brotherhood #1
    Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
  5. #2680
    mrdhud's Avatar
    Join Date
    Nov 2003
    Bartow, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Hello all
    I'm making an order for balsa. Question the main wing spars should they be balsa or hard wood. Can't find any thing on plans that say.
    Bill
    I read your post on using 1/8 sheeting insted of 5/32 Good for me I read all the posts thanks I will use the 1/8
    Dan Hudson WACO Brotherhood #45
    GIT-ER-DUN \"Build a WACO\"
  6. #2681
    Join Date
    Jul 2003
    newton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ORIGINAL: Nightstalker
    Oh, and you might want to draw up a set of those rubber baby buggy bumpers for a certain former Air Force Lt.
    I resemble that remark. the only other "fix" I could come up with was to do a "Jimmy Franklin" to it, and mount a jet engine between the wheels.
    Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
  7. #2682
    Join Date
    Oct 2004
    Richmond, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    A good 28 pound thrust engine would really get it moving so you don't have any loww air speed lift offs.
    Might have to pickup the wings off the tarmac though.
  8. #2683
    Nightstalker's Avatar
    Join Date
    Sep 2004
    Glendale, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ORIGINAL: ag4ever
    He's been there...done that
    Todd
    WACO Brotherhood #47
  9. #2684
    skylarkmk1's Avatar
    Join Date
    Sep 2004
    Festus, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Dan,
    According to the Long Manual parts listing, the spars are Balsa.
  10. #2685
    Live Wire's Avatar
    Join Date
    Nov 2002
    Sterling , CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    I think I would use fur or spruce.
    Larry K
    Sig Brotherhood # 1 Sig Kadet Brotherhood # 4 WACO Brotherhood #34 Cub Brotherhood 14
  11. #2686
    Join Date
    Jul 2003
    newton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ORIGINAL: ag4ever
    Todd
    Yeah, but I'm still gettin' the T-shirt
  12. #2687
    tomcraig's Avatar
    Join Date
    Dec 2005
    Tavares, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Two bundles of 5/32 on the way - Oh what have I done to myself
    Tom Craig, AMA 33857, IMAC #5042
    WACO Brotherhood #77, Club Saito #536
  13. #2688
    damifino's Avatar
    Join Date
    Jul 2003
    Winston Salem, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Speaking of tee shirts. We are tentatively scheduled for printing on Tuesday June 5th. Looks like I'll be getting almost 80 shirts printed. That in itself speaks highly of the people who make up the Brotherhood. 98% of those who requested shirts sent in their payments.
    KHODGES- I really hope I can get those shirts to you all to take to the WACO Fly-in. I'll send them to your hotel if you want me to. PM me with your schedule and hotel info so we can make it happen if it comes to that.
    Looking forward to making some real progress on the WACO in the coming weeks. I have another kit project to throw into the mix later on. A Balsa USA Der Jager 1/3 scale kit is soon to be mine. I've been wanting one for at least two years and they are very, very difficult to find. A fellow in NY dug up an old, old RCU post of mine in which I asked if any NIB kits were out there. We made a deal and I should have it by the end of June. Makes a good lookin' bipe with 80" top wing.
    STICKBUILDER- Did not recieve an e-mail from you. If you sent it from your work it may have been blocked.
    Everybody knows you can\'\'t make a time machine out of a Tilt-A-Whirl.........-:WACO Brotherhood 25:-
  14. #2689
    Join Date
    Sep 2004
    Glendale, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ORIGINAL: khodges
    ORIGINAL: ag4ever
    Todd
    2 T-shirts, Sir... 2 BRAND NEW WACO T-shirts... to match your wing tips
    Todd
  15. #2690
    damifino's Avatar
    Join Date
    Jul 2003
    Winston Salem, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Sorry, I can't help myself- What kind of fur would you suggest......maybe....some BEAVER! Damn off topic posts........
  16. #2691
    mrdhud's Avatar
    Join Date
    Nov 2003
    Bartow, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    skylark
    John
    balsa is ok by me is that what you would use?? ( kind of like that beaver )
  17. #2692
    skylarkmk1's Avatar
    Join Date
    Sep 2004
    Festus, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Dan,
    I was just stating what the original Pica Manual (long version) for the 1/5th WACO indicates in their parts identification list, all the spars are 5/16 x 5/16 Balsa. I' will be building the 1/6th size WACO. If I can find good Balsa, I'll use that, otherwise I'll use spruce or quarter sawn fir or white pine.
    Stickbuilder - Did you replace your spars? If so, what did you use.
    I will be sending the Revised Long Manual to Chris in about a week to be converted to PDF and posted on the House of Moy website.
  18. #2693
    flyguy888's Avatar
    Join Date
    Nov 2004
    coon rapids, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Warning to scale Waco builders: don’t look at this mod, it will only make you cry, and any whining from you will not change my evil ways.
    Anyway, my flying leaves a lot to be desired. I was flying my hog the other day (8lbs) and did one of my occasional bouncy landings that slightly bent one of my piano wire gear legs. That incident made me take a closer look at the gear on my Pica Waco. The gear was just hanging out there with little support, and it had plenty of spring and flex in it. I was worried what this wiggly gear would do when this 15 lb bipe took a darn good bounce in the grass (Sure, I could just improve my flying, but I try to fix what is possible).
    Here are some pics of the (non-scale) cabling on my gear by just using the existing pica gear design. I drilled two small holes in the steel wheel pant plate and just looped a cable through that and around the upper gear leg by the fuselage and crimped the cable in the middle. I was surprised how rigid it is, you can’t move it a bit. Of course, with such rigid gear, now it will bounce even higher, but at least I do not have to worry about the gear flexing and splitting the support blocks inside the fuselage. I might redo it and allow some slack in the cables, I’ll see how this works
ID:	695329   Click image for larger version.
    If you love to build you have to pay the price
    Waco Brother #7
  19. #2694
    flyguy888's Avatar
    Join Date
    Nov 2004
    coon rapids, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    two more pics
ID:	695331   Click image for larger version.
    Waco Brother #7
  20. #2695
    Join Date
    Nov 2005
    Leesburg, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    I have used the supplied stock in the kits, and have also replaced them with Spruce (from the hobby shop). The spruce or Fir is the way to go. You build strength, and don't build much weight. Hard balsa is hard for me to find. If I could get that, I'd use it.
    Bill, AMa 4720
    WACO Brotherhood #1
  21. #2696
    mrdhud's Avatar
    Join Date
    Nov 2003
    Bartow, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    stickbuilder
    Thanks Bill,
    Would you use spruce on the 5/16x5/8 only or on the 5/16x5/16 also. I have checked with all balsa supplyers and cant find any 5/8 stock I gess I'll go with 3/4 and sand to 5/8.
  22. #2697
    Join Date
    Nov 2005
    Leesburg, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Dan,
    I would use the spruce on both...The most important thing is to do the modifications on the wing joiners. If you make the spars from spruce and join them with the little bitty joiners, they will still fail.
    Bill, AMA 4720
    WACO Brotherhood #1
  23. #2698
    mrdhud's Avatar
    Join Date
    Nov 2003
    Bartow, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    stickbuilder
    Thanks Bill
    With that information I can order the wood for the wings. I did see the up date on re cutting the spar braces with 1/8 ply. If I would have done my school home work and studied like I have with the WACO I mitt have been???????? LOL !!!
    Thanks again for all the help.
  24. #2699
    Join Date
    Oct 2004
    Richmond, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ORIGINAL: damifino
    Speaking of tee shirts. We are tentatively scheduled for printing on Tuesday May 5th. Looks like I'll be getting almost 80 shirts printed. That in itself speaks highly of the people who make up the Brotherhood. 98% of those who requested shirts sent in their payments.
    I don't think you will have any problems getting him the shirts in time since you have mastered the art of time travel and plan to have the shirts printed on May 5th. Or was that Tuesday may 5, 2009?
  25. #2700
    Live Wire's Avatar
    Join Date
    Nov 2002
    Sterling , CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ag4ever
    He was thinking about the fur for spars
    Larry K
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
