If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 115 of 756 FirstFirst ... 1565105113114115116117125165215615 ... LastLast
Results 2,851 to 2,875 of 18895
Thread: WACO YMF
  1. #2851
    mrdhud's Avatar
    Join Date
    Nov 2003
    Bartow, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    damifino
    Jay sent you PM
    Dan Hudson WACO Brotherhood #45
    GIT-ER-DUN \"Build a WACO\"
  2. #2852
    skylarkmk1's Avatar
    Join Date
    Sep 2004
    Festus, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Whoops, forgot a couple more Cabin Waco’s; a 1936 ZQC-6 (Dk. Green/ Cream trim) NC 16203, a 1936 YKS-6 (Lt Grey/ Lt. Blue trim) NC 16246 and a 1931 QDC (Red/Black Gold Stripe) NC 11470.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	707104   Click image for larger version.
ID:	707105   Click image for larger version.
    John F Howard (aka skylarkmk1)
    AMA 10955, WACO Brotherhood #26, AWC, NWC
  3. #2853
    skylarkmk1's Avatar
    Join Date
    Sep 2004
    Festus, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Here are the UPF-7s that were present; a 1940 (Blue/Lt. Blue) NC173E (based at CCA), 1940 (Grey/Yellow Military Scheme) NC 29927, 1941 (Brown/Yellow Cream) NC 32158, 1942 (Dk. Green/Yellow) NC 39727, 1942 (Red) NC 39743, 1942 (Vermillion Red/Cream) NC 39748 (Ken’s and mine ride plane thanks to Joe Norris, WB-54) and a 1946 (White/Dk.Blue trim) NC 29303. The last shot is from NC 39748 of CCA. You can see the Main runway with parallel grass strip (left of the left taxiway on the side opposite the hangers) and the 2 parallel grass strips at right angles to the Main.
ID:	707113   Click image for larger version.
ID:	707114   Click image for larger version.
ID:	707115   Click image for larger version.
ID:	707116   Click image for larger version.
ID:	707118   Click image for larger version.
ID:	707119   Click image for larger version.
  4. #2854
    Join Date
    Sep 2002
    St. Catharines, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    To Stickbuilder - I've been building "stick models" for more years than I care to admit. I have just run across the plans for the Waco WMF 1/5 scale Pica model and a friend and I intend to scratch it into two beautiful flying machine! I have a number of questions about the plans which I will not take up space with now. But I do have a Zenoah G23 which I would like to use as the power for this aircraft. Since I do not see any mention of weight I'm wondering if this will be suitable power. My first thought was for a Quadra 35 but I would rather not use that old clunker!
    I notice the dihedral is given as 2 degrees which I have computed to be 15/16"!! We plan to order cowl and pants from Fiberglass Specialties as they seem to do beautiful work.
    I started to read through this long thread and got worn out after 20 or 30 pages. In time I will get through it, so I apologise if these questions have been asked before. I am a biplane lover and have watched the beautiful yellow WMF that's stationed at the St. Catharines Airport here in Ontario Canada, with love and envy. I just met a chap in our R/C flying club who is close friend of the owner - so maybe a hop in the real thing one day!! I will probably model my aircraft after his since it is so handy to have the actual aircraft sitting in front of me!
    I notice a lot of 5/32" dimensions in the plans. I find it hard to obtain balsa in that measurement although Balsa USA said they would special-cut some 3" X 36" sheets for me in 100 lots. Do you all build with this dimension wood or do you adjust to 1/8"?
    I notice on the plans that the ribs are listed as 1/8" balsa but the outlines you have kindly provided call for 5/32". Any reason?
    Many thanks for your help
    Jim
    Jim, MAAC #5343
    WACO Brotherhood #56
  5. #2855
    Stickbuilder's Avatar
    Join Date
    Nov 2005
    Leesburg, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Jim,
    The actual wood that was supplied in the kits for the ribs was 5/32" I would, and do substitute quite a bit of 1/8 wood instead. Lone Star and Sig will supply 5/32 balsa in lots of less than 100. In fact, i think that you can order it in any lot size that you want. The dihedral is 2 degrees per panel, so your plans are on the money there. Stan's Fibertech makes great parts, but the cowl that they offer is not for the YMF, but is in fact the UMF cowl (blister placement). Personally, I run the OS 160 twin in all mine since the engine fits within the cowl where the gasser's require cutting the cowl. Good luck with your project, and let us know where you might require some assistance. Please pay attention to the mods that we make, since they make for a more durable model (especially the wing spar ties)(joiners).
    Bill, AMA 4720
    WACO Brotherhood #1
    Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
  6. #2856
    Join Date
    Sep 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Thanks for that Bill - Since I already have the Zenoah and do prefer gas, do you think the G23 would be sufficient power? It looks close to fitting inside the cowl with maybe a cutout for the plug! It's rated at 8100+ rpm with an 16 X 8 prop. Do you have a rough weight for the model?
    I have read the accompaning manual and noted the mods on the plans. Thanks for all that work!
    Jim
    Jim, MAAC #5343
  7. #2857
    Join Date
    Nov 2005
    Leesburg, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    It was a labor of love..... The G-23 should pull the model with good authority, since it was originally designed for a .60 to .90 2 stroke. The 16" diameter prop won't look large enough, but should fly the model well. Most of the models that I have built or seen come in at about 14 1/2 pounds or more. They will fly well at 18 pounds though, so don't worry too much about it. Yoou should be under power on your landings and shoot for a wheel landing and then cut power and let the tail settle. Don't get too slow when you are close to the ground. It is very easy to run out of altitude, airspeed and ideas at the same time.
    Bill, AMA 4720
    WACO Brotherhood #1
  8. #2858
    Join Date
    Sep 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Thanks Bill - that's what I hoped. I have a fat and heavy Supercub that has an old wheasy Quadra 41 in it. At 20lbs. it flies just like a cub should and loves wheel landings under power. Also have it on B-USA floats and ditto. A friend is running a G26 with an 18 X 6 prop and it moves his ARF (ugh) Super Stearman quite nicely so I will probabl;y put an 18" prop on this. Makes it a little more scale too as you suggest.
    Thanks for the info - now to work on the wood list!
    Jim
    Jim, MAAC #5343
  9. #2859
    Join Date
    Jul 2003
    newton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Jim---to add to Stickbuilder's reply, I have a G-26 in mine, and it flies great, plenty of power at 18 pounds flying weight (that was probably my plane he was talking about) It's solid as a rock in the air, and glides like one when you cut the throttle. All I had to do to fit mine was two holes in the bottom of the cowl for the spark plug and plug wire, and a small cutout along the Slimline Pitts muffler. The Quadra 35 is much bigger, and you'll have to make a big hole for the cylinder head. The G-23 should fit fine, about like the -26. You have to use the short insulator block between the carb and cylinder, and there's no room for a velocity stack. Here's a few pics of my installation, with and without the cowl:
ID:	707339   Click image for larger version.
ID:	707340   Click image for larger version.
ID:	707341   Click image for larger version.
    Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
  10. #2860
    Hughes500E's Avatar
    Join Date
    Nov 2002
    Armstrong, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Replied to your PM, sorry for the delay!
  11. #2861
    skylarkmk1's Avatar
    Join Date
    Sep 2004
    Festus, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    All,
    Since this is an YMF thread, figure I will get started posting YMF pictures. These pictures are of a 1987 YMF Classic, built by Waco Classic Aircraft Corp, NC 14081, Owned by Robin Williams of Traverse City, Michigan. The YMF Classic is most similar to the original YMF; the YMF Super has many more changes.
    The subject of lower wing fairings keep coming up so in this installment I will show what I have, other sections I will cover later.
    Picture 1 – Rear view showing the wing walk on the left.
    Picture 2 – Lower Cowl, exhaust ports, Landing Gear Center mount, and general underbelly with landing gear fairings.
    Picture 3 – Top view of the right wing fairing with notch.
    Picture 4 – Rear view of the left underside of the wing fairing
    Picture 5 – Leading edge of wing, trailing edge of landing gear fairings. Note the lower Red light and antennas
    Picture 6 – Low shot of the same area. This joint on many models is neglected to facilitate mounting of the lower wing.
ID:	707706   Click image for larger version.
ID:	707707   Click image for larger version.
ID:	707708   Click image for larger version.
ID:	707709   Click image for larger version.
  12. #2862
    skylarkmk1's Avatar
    Join Date
    Sep 2004
    Festus, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Jay,
    Here's proof that we wore our WACO Brotherhood shirts proudly. A shot of Ken checking out the the "Skybolt". UPF-7 NC 39748 in the background just finished refueling.
  13. #2863
    Join Date
    Sep 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Thanks khodges that's great! Those pix will go a long way to helping me with the motor mount. I have ordered a G26 muffler a minute ago for the G23 I will use. (G23 pipe points back?? - G26 pipe points down!) I do have a "wraparound" style like you have used, but I think the stock muffler will fit inside the cowl and I'm going to see if I can do some creative welding for the pipes to approach a scale look and thus avoid cutting out for the muffler.
    Great shots skylarkmk 1. Thanks
    Jim
    Jim, MAAC #5343
  14. #2864
    Join Date
    Sep 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Stickbuilder - what's the drill for getting a Waco Brotherhood number? And Damifino - any Tee Shirts left?
    Jim
    Jim, MAAC #5343
  15. #2865
    kestrel0222's Avatar
    Join Date
    Mar 2004
    Milford, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Damifino,
    I received my tee's today....The first word that came to me was...... AWESOME!!!!!!!!!!!! Thanks again for taking the time and effort to make these tee's available to all of us!!!! I, for one, am VERY impressed with the quality of the artwork!!!
    Tom - AMA Member Since 1973
    WACO Brother #39
  16. #2866
    damifino's Avatar
    Join Date
    Jul 2003
    Winston Salem, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    SuperCubMan- Speaking for Stickbuilder, you just asked for and will receive a number. PM me with your shirt size(s) and I'll see what I've got left. I'll also include payment info in the reply.
    Thanks to our 'roving reporters' for the fantastic pictures. You guys.............!
    Everybody knows you can\'\'t make a time machine out of a Tilt-A-Whirl.........-:WACO Brotherhood 25:-
  17. #2867
    skylarkmk1's Avatar
    Join Date
    Sep 2004
    Festus, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    All,
    Some of the other Waco’s present; 3 UBF-2s, NC 2091K (Tan/ Brown trim), NC 12002 (Red/Silver w/Black trim) and NC 155Y – TEXACO 17 (Red/White) all based at CCA, NC 155Y was flown a couple of times. QCF-2, NC 9220J (Cream w/Red trim) proves you can get 2 people in the front cockpit, but it’s cozy. ASO NC 662Y (Blue/Silver w Red trim) #26 on take off, is part of the Air Tours Group (note the under camber of the wings). A static replica of WACO #1, the β€œCootie” was built full size (22’ wing span) and brought to the Museum by Roger Teagarden. Plans are to cover the wings, finish the fuselage and put the correct prop in place (the prop shown was put on as a joke).That is the Museum’s JYM to the right. ASO (Black/Silver) NC 701E was flown in from Ft. Worth, TX and is headed back to California. The pretty Red w/Black trim Taperwing, NX 149TW, was actually built by the owner, Robert Patrick, in 2005 and flew in from central Idaho. This pretty well covers the Wacos that flew in; the museum has about 14 more that were on display in the museum hanger. The 2008 AWC Fly In will again be held at Creve Coeur Airport about the same time next year.
ID:	707821   Click image for larger version.
ID:	707822   Click image for larger version.
ID:	707823   Click image for larger version.
ID:	707824   Click image for larger version.
  18. #2868
    Join Date
    Oct 2002
    Park Falls, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    John, what a great job of photography!, it is very evident you knew what you wanted to shoot. Also, a great job explaining your every shot. You have answered many Brotherhood questions I'm sure. I have saved every picture you have posted. Thanks again.
    Skinny Bob
    Skinny Bob - AMA 713081
    WACO Brotherhood #10
    I'm back in God's Country, Northern Wisconsin
  19. #2869
    Join Date
    Jul 2003
    newton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Here's some more bits and pieces of what we saw this past weekend. In most of the pics I have collected on WACO's from the 'net, most have had wooden props. Not so this weekend; only one WACO showed up with a wood prop, and only after he had been there, left, and returned. There were a couple of variable pitch jobs with the counterweights, and several more that are ground adjustable for specific pitch, but the most popular (and desired by all who don't have one) was the Curtiss-Reed propeller. It is polished steel, and the cross-section of the prop is very thin. They are made flat and then formed to the desired pitch. Most who used them said they will "flatten out" with full power, lowering the effective pitch and making it into a good pulling prop, and then, when power is reduced to cruise, the blades return to their nominal set, making a good "speed" prop. I asked a couple of people about it, both said they weren't sure if it was an intended design characteristic, but it sure did work well.
    John had the much better camera for action and telephoto shots. Mine worked fairly well for static and interior because it was wide angle. The interiors and instrument panels on these planes were also works of art, excellent examples of form following function, with a little art deco thrown in. The cabin WACO's reminded me of the interior of a 40's era Hudson, or Studebaker. Wood trim galore, tweed and wool fabrics, and even leather in the SRE. The windows had cranks to roll them down, just like a car. Even the DH-4 had a simple elegance to its business-like panel. And on the other end of the spectrum, the Curtiss Robin in the museum was the essence of spartan simplicity. Below are, left to right, the VKS interior, the SRE interior, the DH-4, and the Robin: Below that are the different props we saw, variable, ground adjustable, wood, and Curtiss-Reed:
ID:	707936   Click image for larger version.
ID:	707937   Click image for larger version.
ID:	707938   Click image for larger version.
ID:	707939   Click image for larger version.
ID:	707941   Click image for larger version.
ID:	707942   Click image for larger version.
  20. #2870
    skylarkmk1's Avatar
    Join Date
    Sep 2004
    Festus, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Bob,
    Thanks. There was so much going on it was hard to keep up everything going on. I did have one goal in mind and that was to get good pictures of an YMF and I believe I accomplished that. My second goal was to get a few shots of each Waco that flew in for the weekend and I managed to do that. The rest was a bonus.
    Besides the Wacos and the DH-4 with Desmond Penrose (a highlight in my opinion), there were many other aircraft that flew demo flights. Everything from a J-3, an L-4B, an L-16, a Fairchild 24, Fairchild 71, the numerous PT-17s, 3 Ercoupes, a Travel Air 4000, A Monocoupe, 2 Cessna 195s, a Pete-N-Paul, a Swallow, a few Pitts, Christen Eagles, an Acro Sport and then the heavy metal military aircraft. An AT-6 painted all yellow β€œYahoo”, an F-51D Mustang (painted as β€œPetie 2nd”), the big 6 man Skyraider all decked out with rockets and finally a Russian L-29 Jet Trainer. Plus wandering around all the hangers and seeing what was inside each one. Planes just sitting, planes in pieces, planes being restored and planes were being polished. I am not forgetting all the modern metal skin General Aviation Aircraft, just ignoring them for now.
    I think one of my best memories will be of watching Ken trying to take it all in as well. He was like a big kid in a candy store not knowing which way to turn or what to grab first, he was practically jumping up and down with excitement. Thanks for coming out to the Fly In and palling around with me, I know you enjoyed it as well.
  21. #2871
    Join Date
    Jul 2003
    newton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Bits and pieces, redux. There was some model cabin WACO in a hangar for restoration; the wings were in process of re-covering. I shot a couple of pics from the tank well of the top wing, into the interior of the structure. The wing had been covered, ribs stitched and taped, and the cover shrunk, but not yet doped or painted. The stitching is fascinating. Another plane in a different hangar being restored a little at a time was a GeeBee R-2. Reminded me of a bumblebee, no way the thing can fly That's a P&W Wasp, Jr hanging on the front:
ID:	707955   Click image for larger version.
ID:	707956   Click image for larger version.
ID:	707957   Click image for larger version.
  22. #2872
    Join Date
    Jul 2003
    newton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    The one unchanging, universal attitude about the people we met this week was their absolute passion for their aircraft. One couple epitomized this with their "build book" they brought along with their beautiful YKS-7. The restoration took place in their house, from the living room to the garage, to the driveway. They had pictures of covering the wings and control surfaces in their living room; the fuselage resided in the garage. And when it came time to mount the engine, they hired a tow truck to lift it into place. He had been furloughed at work, so he rebuilt while she worked to support the family, as well as diving in on the weekends to help with the restoration.
    The front view shows the much desired Curtiss-Reed prop.
ID:	707977   Click image for larger version.
ID:	707978   Click image for larger version.
ID:	707979   Click image for larger version.
ID:	707980   Click image for larger version.
  23. #2873
    Join Date
    Jul 2003
    newton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    John is right, I was like a kid at the zoo, pointing, oohing and ahhing. I've been to many airshows and museums, primarily warbirds from WWII and later; this was my first exposure to so much Golden Age and earlier stuff.
    My last entry for the night: more interiors and instrument panels. I'm afraid I wasn't as good at writing down what was what as John was. No matter, they're all beautiful.
ID:	707997   Click image for larger version.
ID:	707998   Click image for larger version.
ID:	707999   Click image for larger version.
ID:	708000   Click image for larger version.
ID:	708002   Click image for larger version.
ID:	708003   Click image for larger version.
ID:	708004   Click image for larger version.
ID:	708005   Click image for larger version.
  24. #2874
    damifino's Avatar
    Join Date
    Jul 2003
    Winston Salem, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    I have several XXL's and a few L's left. Get these while you can. PM me with your inquiries please.
  25. #2875
    skylarkmk1's Avatar
    Join Date
    Sep 2004
    Festus, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Ken,
    You gave me a bit of a challenge with the interior shots but here goes:
    1- WACO UPF-7 NC39727
    2- Fairchild 71 NC 9727 (photo1)
    3- WACO UBF-2 NC 2091K
    4- Swallow NC 979 (photo 2)
    5- WACO UBA NC 13041
    6- Stinson SR-6
    7- Travel Air
    8- Russian Shavrov-2 Seaplane (photo 3)
    9- Stinson SM-8A
    10- WACO QCF NC 12428
    11- Russian Antonov AN-2P N 147AS (photo 4)
    The shots of the wing interior are of the WACO YKS that I posted wing tip pictures before.
    The Gee Bee will become an R-1/R-2 when completed as was done in 1933 after both the R-I and R-2 had crashed and they were put together.
ID:	708062   Click image for larger version.
ID:	708063   Click image for larger version.
ID:	708064   Click image for larger version.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
