Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
WACO YMF
Reply
Old 06-21-2007, 06:12 AM
  #2876
Skinny Bob
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: WACO YMF
Ken, sorry I left you out. I apologize. Your close ups will help us all with scale detail. I am very envious of you guys. What a treat to be able to see all those beautiful aircraft.
Thanks for all the great pictures.
Skinny Bob is offline
Old 06-21-2007, 07:18 AM
  #2877
Stickbuilder
Stickbuilder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: SuperCub Man
Stickbuilder - what's the drill for getting a Waco Brotherhood number? And Damifino - any Tee Shirts left?
Jim
Jim,
If you will look back to page 110, you will find that you are WACO Brother #56. I used to update the roster when a request was made, but now I only move the roster to the current page every 10 pages. The size of the thing almost wipes out the entire page for posts, and so that is how I do it. Welcome to the Brotherhood. I hope you derive some good from it.
Jay,
Great job on the shirts....Mine came yesterday, and they not only fit well, but they look great. How about a second edition?????
All,
Jay and I have been talking about different editions, and not using the same colors twice. That way one would be able to recognize which edition of shirt that you are looking at. Janelle has already requested a shirt with her Red Waco, so I'm trying to talk Jay into doing that one next. I would like a windbreaker as well, so Jay, the ball is in your court.
Bill, AMA 4720
WACO Brotherhood #1
Stickbuilder is offline
Old 06-21-2007, 07:54 AM
  #2878
SuperCub Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bill - Thanks very much for accepting me into the Brotherhood. I have contacted Jay and will have a couple of shirts in a few days to wear with pride and proudly promote this noble interest. My buddy and co-WACO lover - who is now away on a well deserved holiday - will probably contact you on his return.
Regards
SuperCub Man is offline
Old 06-21-2007, 09:42 AM
  #2879
mrdhud
My Feedback: (48)
mrdhud's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ALL
I have run in to a bit of a problem with my wing tip. The pics not to good but I think you can see the w-13 T.E does not line up with w-7 & w-8 rib. I have checked to be sure the wing rib are the proper size. I don't see how the covering will work out if this is left as is. Is this a common problem?? At this point I can recut another one to match the ribs ends but don't know.
On a different subject I've been playing around with how to do the corrugated cover for the ailerons and have come up with this see what you think it is vary thin aluminum.
ID:	708207   Click image for larger version
ID:	708208   Click image for larger version
mrdhud is offline
Old 06-21-2007, 10:59 AM
  #2880
Hughes500E
My Feedback: (16)
Hughes500E's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks like you're already glued! I would just leave it and shape it when you pull the wing up. Even if you were confident, there is still a lot of shaping in that area when you're finished.
ALL:
I found this in my search to do scale panel lines. I thought I would share it on here!
http://www.tompierce.net/SBD/html/paint.htm
Hughes500E is offline
  #2881
skylarkmk1
skylarkmk1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dan,
Take a look at the full size wing tip pictures I posted back on page 110, post 2728, they may help you visualize your situation. The plans show the Ribs W-7 and W-8 attached to W-13 in the rear and the Big Tip Block in the front. W-13 should project past W-8 slightly to blend in with W-9 Tip piece. The wing tips taper slightly on top from the last W-6 to the tip and much more on the bottom. The taper on the bottom (of W-13) of the real wing starts about halfway between the last 2 W-6 Ribs and continues to the tip. It seems to give that section washout as the bottom of the ribs taper up towards the rear more than at the front.
The aileron skins look very, very good, what thickness of aluminum are you using? Roof flashing I think is too thick but would be good because it can be obtained in small rolls for a continuous surface. You may need to make the wood core of your aileron a little smaller for the skins to meet at the trailing edge like they do on the real ones.
skylarkmk1 is offline
Old 06-21-2007, 01:30 PM
  #2882
trlambsr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys
About Jackets and shirts. I would also like Short and long sleve shirts. How do we go about this.
TR
Waco Brotherhood # 69
trlambsr is offline
Old 06-21-2007, 02:21 PM
  #2883
tomcraig
tomcraig's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I received my shirts last night - GREAT job Thanks a million for your efforts
tomcraig is offline
Old 06-21-2007, 03:02 PM
  #2884
mrdhud
My Feedback: (48)
mrdhud's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All
John, Thanks the pics will be vary helpful with my problem I haven't glued that piece in yet I wont to be sure it's right first.
The aluminum I used came from my local news paper shop I cant remember what its called they use it in printing news papers some how. I buy it used for a buck a piece. It's the same size as a news paper page. Its vary light the piece in the pic is 0.5 oz the same size 3/32 balsa is 0.2 oz (according to my scale)
The hardest thing was cutting the gig (in the pic) this is the forth one I cut. Doing the math was easy I found it on the thread somewhere about 3/8 spacing transferring that to a piece of wood however was not so easy[:@]. I couldn't have done it with out a table saw. After the gig was cut I clamped the aluminum on one end and with a piece of wire and my 13 oz hammer I went to pounding in the saw groves one at a time. Its not a perfect system but I really like the way it looks.
The piece in the pic is just a test piece If any one would like to see it first hand I will be happy to mail it to you to get your opinion. There are still some bugs to work out but I think it will work and look good when finished.
mrdhud is offline
Old 06-21-2007, 04:02 PM
  #2885
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dan,
That stuff is called lithoplate, and it should work out well for your application. The aileron piece is the correct shape, so you will need to shape the ribs and the spar to match. If you think that this is a bear, wait until you have to shape the leading edge tip blocks....
Just read my signature line at the bottom of the post. With this type of model, it is a true statement. You will need to sand off everything that does not look like a WACO YMF.
Bill, AMA 4720
WACO Brotherhood #1
Old 06-21-2007, 04:07 PM
  #2886
zig
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Jay, Received shirts today and thanks for a job well done. High quality shirt with great graphics.
Ken Chikasuye (zig) Waco Brotherhood#51
zig is offline
Old 06-21-2007, 05:18 PM
  #2887
damifino
damifino's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Trlambsr and all- I plan to work out the details for embroidered clothing, jackets and hats. This will take some time so bear with me.
I do not know yet if demand will warrant a second printing of the current shirt/colors. That is up to the Brotherhood.
It is not feasible or cost effective to produce less than 6 dozen screenprinted shirts. On the other hand, once embriodery designs (approx.$500.00 to digitize) are on file at the supplier, small quanities of embriodered pieces are no problem.
Out of 98 shirts printed I only have some XXL tees and a few Large tees on hand now.
Thanks again for all your comments and support!
These 'earthy colors' on neutral shirts will age gracefully. I'm wearing mine as I write this. Enjoy them and stay tuned.
damifino is offline
Old 06-21-2007, 05:25 PM
  #2888
Jim Henley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jay,
The shirts were here when I got home, what a fantastic job!
Thanks again for all your effort, they will be worn with PRIDE !!
Jim Henley is offline
Old 06-21-2007, 05:36 PM
  #2889
Didg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Damifino
Did you get my PM?
If you have no XL's left then I'm a 42" Chest, so I don't know if I'll fit L or XXL.
Let me know, I defo want a couple.
Cheers,
Didg.
Didg is offline
Old 06-21-2007, 06:07 PM
  #2890
ctflyboy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jay,
I received my shirts today GREAT JOB, & THANK YOU AGAIN FOR ALL YOUR EFFORTS,
WHEN WE GET AN EYEBALL ON ONE ANOTHER, THE COFFEE IS MY TREAT
AGAIN, THANKS
GEORGE
WACO Brotherhood # 5
ctflyboy is offline
Old 06-21-2007, 07:20 PM
  #2891
Live Wire
Live Wire's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just wondering how these TEEs were shiped I am in the middle of a big mess and don't want to miss them[:@]
Live Wire is offline
Old 06-21-2007, 08:23 PM
  #2892
damifino
damifino's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tees were shipped via US Postal Service, Priority Mail.
damifino is offline
Old 06-21-2007, 08:39 PM
  #2893
funkymusic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got mine today. Looks and fits great; the shirts are top of the line, very nice job Jay. I'm sure I'll be the envy of all the guys at the field. Thanks again!
funkymusic is offline
Old 06-21-2007, 09:22 PM
  #2894
Live Wire
Live Wire's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks buddy I am cleaning up a big mess and did not want to miss them. Looks like you have done a great job and thanks from the Out Law
Larry K
Old 06-22-2007, 07:09 AM
  #2895
Jacque
My Feedback: (22)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jay ,the shirts arrived yesterday great job. Thanks
Jacque AMA 587585
Waco Brotherhood #27
Jacque is offline
Old 06-22-2007, 11:07 AM
  #2896
Skinny Bob
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got my T's today, look great. Can't wait to prowl the flight line wearing one. Thanks Jay.
Old 06-22-2007, 10:32 PM
  #2897
Hughes500E
My Feedback: (16)
Hughes500E's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have not scene too much in the way of overlapped panel lines and rivets yet so here goes!
Take it easy on me, its my first scratch build! I'm learning as I go!
ID:	709075   Click image for larger version
ID:	709076   Click image for larger version
Old 06-22-2007, 10:34 PM
  #2898
khodges
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Too bad we can't all get together for a group photo, all wearing our new shirts.
I had an interesting conversation today with a guy named Aaron Silk; he is the current owner of Ikon N'West. They sell a 1/5 scale UPF (as well as a Model 10 and a Taperwing). I've heard both good and bad about Ikon over the last year, and was sort of hesitant to try dealing with them. Aaron has a full-time job with one of the railroads in Washington State, maintaining and repairing crossing gates, so he stays pretty busy. One of the things I've heard about Ikon is their failure to return calls, etc, but Aaron called me today (I was at work) and I returned the call this evening. The time difference between here and there and his work schedule makes convenient times to call difficult for him.
He said he has purchased a laser cutter and is gradually revising the kits and will eventually have all of them laser cut. Fortunately for me, the UPF-7 is a recent conversion to laser cutting. I asked him about the scale fidelity; he told me that the plans designer was the former owner of Ikon, and had been a design engineer for Boeing. I think I can take that to mean that the plans should be true to scale. he orders his balsa from Balsa USA, so that speaks for the wood quality. He said that there are several being built right now by customers, and the ones he's seen completed look very good. I am going to order a kit for the UPF this week; he said it should take two to three weeks for him to get it cut and shipped to me. This should make a great companion piece to my UMF.
khodges is offline
Old 06-23-2007, 01:35 AM
  #2899
old git
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: khodges
I bought an Ikon N'West 1/4 scale kit for a Beaver/Otter (senior moment) but it's at the back of a heap of "TO DO's". I was rather disappointed to find that there were numerous vacuum moldings to give the model its shape. They were very flimsy and that's why it's at the bottom of the pile. If you are happy with that, go ahead; me I have an attitude towards vacuum moldings, it probably goes together with my careless model storage and poor flying skills.
About a group shot complete with T shirts, how I wish. I would love to see Creve Coeur and Oskosh etc, now I can afford the trip I couldn't survive the flight. All the best to the Brotherhood.
WACO Brotherhood No. 14.
old git - - - - - - aka John L.
old git is offline
Old 06-23-2007, 06:35 AM
  #2900
mrdhud
My Feedback: (48)
mrdhud's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hughes500e
Looks pretty darn good to me. I started my wings first thinking they'd be easyer this is my first scratch to.
Keep the pics coming.
mrdhud is offline
