WACO YMF
#3026
RE: WACO YMF
All,
170 Radial Engine report. Over in the ARF Section under the Top Flight Staggerwing (page 29, post 578), there is a report of it flying (at 22.5 lbs) with the 170, should anyone be interested on using the 170 for their YMF. Wing Spans are the same.
#3027
RE: WACO YMF
Mitch,
Here you go; from NC 14081, a 1987 YMF Classic. The Main Instrument panel does not have the Burl Center Panel as in TRs photos, but the rest the instrument panel is similar (avionics differ as the pilots prefer) and the interior is finished with padding and carpet.
P-1 – Rear seat throttle quadrant with stabilizer trim crank, parking brake (yellow striped handle), left fuel tank on/off (red handle) and lower left instrument panel.
P-2 – Rear seat right side with right fuel tank on/off (red handle), lower right instrument panel and the “keyâ€.
P-3 – Front seat throttle Quadrant with stab trim crank in front of the quadrant, scuff pads below rudder pedals, door opening and warning placard, and locking glove box. You can also see the carburetor heat lever better.
P-4 – Front seat instrument panel, right side padded trim. Lower center placard (under Instr. Pnl.) reads “REAR SEAT FOR SOLO FLYINGâ€.
As all of the pictures show, all kinds of finishes for each plane and pilot.
#3029
My Feedback: (16)
BC, CANADA
RE: WACO YMF
Does anyone have a large picture of the Waco emblem for the top of the vertical stabilizer (fin) ?
I cannot find a picture large enough to use to make one!
Thanx
Thanx
#3034
ON, CANADA
1 Post
RE: WACO YMF
ORIGINAL: Hughes500E
Many thanks on two accounts! My stitching looks just like that
Got my shirts too Jay, very nice, thanks!
Notice the first stitches in the rows at both ends anywhere on a fabric covering like this are half spaced, in other words there are 3 stitches in the span of the usual 2 without exception wherever there is lacing if done to proper procedure.
I have seen many flawless models, except for this little detail. Albeit cosmetic on a model it, without it you won't get a C of A on a 1:1.
Edit:spelling
#3035
My Feedback: (16)
BC, CANADA
RE: WACO YMF
My next one is going to be much better [:@][:@]
Forgive me guys, I am young!
All this talk about building has been great. There is a scale event I will be flying at with my Waco on July 20,21 and 22. I have to ask, What are some of the scale manuvers a guy should expect to see with the Waco? Seeing as it is a civilian sport plane I'm thinking a scale loop would be good, a wing over, descending circle, maybe a stall turn??
Anyone care to try and educate me a little? [:-]
#3036
ON, CANADA
1 Post
RE: WACO YMF
Hughes, do not reproach yourself for something I learned yesterday. It just seemed like a good bit of info to add to such a comprehensive thread. The photos of those who can contribute are priceless. I'm going to guess that very few know about the stitching technique or use it if they do. I've stitched a bit. I have a complete set of NIT A+P mechanics manuals that I read as novels.
Cheers, John
Cheers, John
#3037
NC
RE: WACO YMF
Let me throw this into the conversation. Often the pinking and stitching on models too obvious. Look at it this way: Stand 60 feet away from a full size fabric covered aircraft and take note of how much stitching and pinking tape can be easily seen. Now you've got an idea of how much should be seen from 15 feet away on a 1/4 scale model or 12 feet away on a 1/5 scale. Just an observation.
#3038
RE: WACO YMF
damifino
Boy have you got that right. When we build one this size we are looking at how close we can get it to look like the real thing. The information we recieve here is a great help to achieve what we are looking for when we are building and achieving our goal.
One thing they all look the same after a crash at any distance[:@] have fun with what ever your goal and be proud of what you have
Not every one in this hobby has the big buck to fulfill their dream
#3039
ON, CANADA
1 Post
RE: WACO YMF
ORIGINAL: damifino
A good example of perspective is the number of rivets on a high quality plastic model that make it look "Right" even though there are actually ten?? times as many on the real aircraft. Is the term "Scale effect" correct for the eyes rationalization of detail on a subconscious level?
#3040
NC
RE: WACO YMF
Yes, 'scale effect' fills the bill. We want an illusion of the real thing. IMO there can be too much detail, or should I say the details can end up as an overpowering element of the finished model.
#3043
RE: WACO YMF
Hughes500E
I kow right where you are coming from , when you build for hours and can not see where you have made any headway[:'(] Only thing I build for other people and the project is a Ziroli P 38
When will I have time for my WACO
Larry K
Larry K
#3044
RE: WACO YMF
Get some pics at the fly-in, maybe some video.
#3045
RE: WACO YMF
Hughes,
Just to add a little to Ken's post, if you check the Aerofiles listing of the Waco History by model, the UMF was the forerunner of the UPF-7. When the UPF-7 was used as a Primary Trainer (YPT-14/PT-14), it was reported to turn better (inside the PT-17) and basically out perform the Stearman PT-17, so similar maneuvers are appropriate. As Ken mentioned, the control authority, especially the aileron, was/is much less than today’s Caps, Extras, Edges, Pitts, Ultimate Bipe’s and the like
#3046
My Feedback: (16)
BC, CANADA
RE: WACO YMF
Nice, thanks for the input. I have narrowed my choices to this:
5 Mandatory
Take Off
Figure Eight
Fly Past
Landing
Overall Flight Realism
5 options
barrel roll
360 degree descending circle
stall turn
vintage loop
touch and go
Now I just have to get the Waco finished []
5 Mandatory
Take Off
Figure Eight
Fly Past
Landing
5 options
barrel roll
stall turn
vintage loop
touch and go
#3049
RE: WACO YMF
Sounds like a good performance coming up. My favorite maneuver with my little UPF (haven't tried it yet with the UMF) is a barrel roll; it looks really good with a WACO. Hope I'm not talking out of school here, but remember, on your stall turn, the plane should pivot at the c/g. If it turns at a point out on the wing, it's a wingover.
There was one point of "flight realism" I used to have down pat with my DR-1; that was a ground loop and/or flip at the end of my landing Let's not go there
Speaking of UPF's, I got an e-mail from Aaron at Ikon. He said he's finishing up the kit and should be shipping it on Monday. Can't wait to see it, I'll give a full report.
