If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 152 of 756 FirstFirst ... 52102142150151152153154162202252652 ... LastLast
Results 3,776 to 3,800 of 18899
Thread: WACO YMF
  1. #3776
    Big_Bird's Avatar
    Join Date
    Dec 2001
    Arlington, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ORIGINAL: r/c John
    Been reading the posts here, and maybe my suggestion will work for you. To replicate the metal parts on the Waco you may try using some aluminum flashing you can purchase in just about any hardware store, it is thin and it is strong. Also a hint as to the corrugated covering on the ailerons instead of pounding out litoplates, which by the way may also be used for metal parts Sig sell corrugated plastic for their Morrissey Bravo stock numbers SIGRPCP .010X8X17 $2.50 per sheet. SIGPPCP .010x6 1/2x13 1/2 $1.99 per sheet!
    Hope this helps someone.
    John, do you know what the spacing is on the SIG corrugated sheets? I am building the Pepino 1/4 scale YMF-5.
    Ken
    WACO Brotherhood #70, Arlington TX home of the Dallas Cowboys, SupBowl45, Texas Rangers, World Series 2010, 2011
  2. #3777
    skylarkmk1's Avatar
    Join Date
    Sep 2004
    Festus, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Ken, Jim,
    This John (skylarkmk1) does not know the spacing of the SIG corrugated sheets
    Here are a couple of close ups of the ends of the aileron, rivets and rib spacing. A full scale aileron is 67-1/4” long. This aileron is from a YKS and is the same as those used on the **F series Wacos.
    P1 Tip end – note the first rib is about 1-3/4” from the tip and the rivets have been inserted from different sides depending on what stage of assembly. (bottom side of aileron shown)
    P2 Root end – note the first rib is about 1-1/2” from the end and that the ribs are just under 2” apart. (bottom side of aileron shown) Aileron horn ball link in lower right corner can be seen.
    P3 Rib spacing – Using the 1/64” scale, you can see the ribs are just about 1-15/16” apart.
    P4 Tip end top view
    P5 Center section view, not quite as close, rivets are even spaced and not as noticeable as they are closer up. Silver area is where the aileron connecting strut attached on the YKS.
    On a ΒΌ scale model, the rib spacing would need to be just under ½” (.4844” ),
    On a 1/5th scale model, the rib spacing would need to be just over 3/8” (.3875” )
    Jim – go with the even spaced rivets and don’t rush it
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	774224   Click image for larger version.
ID:	774225   Click image for larger version.
ID:	774226   Click image for larger version.
ID:	774227   Click image for larger version.
    John F Howard (aka skylarkmk1)
    AMA 10955, WACO Brotherhood #26, AWC, NWC
  3. #3778
    Big_Bird's Avatar
    Join Date
    Dec 2001
    Arlington, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    John, very good photos.
    Surely someone out there knows what the spacing of the SIG corrugated sheet is.
    Ken
  4. #3779
    Stickbuilder's Avatar
    Join Date
    Nov 2005
    Leesburg, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Ken,
    Welcome to the Brotherhood. You are now Brother #70. I hope you enjoy it. Guys, let's all extend a hearty welcome to Ken (Big Bird)
    Bill, AMA 4720
    WACO Brotherhood #1
    Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
  5. #3780
    Join Date
    Sep 2002
    St. Catharines, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    John - Thanks for the great pix of the ailerons. I wonder if there is a photo available of the whole aileron clear enough to blow up, so I can see how the rivets run up the middle support struts. I believe they form sort of a double"V". My sample pix I posted was just a test strip. Since this is a labour of love - I will take my time.
    Jim, MAAC #5343
    WACO Brotherhood #56
  6. #3781
    Big_Bird's Avatar
    Join Date
    Dec 2001
    Arlington, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Thanks Bill, does this come with a secret hand shake?
    Ken
  7. #3782
    Live Wire's Avatar
    Join Date
    Nov 2002
    Sterling , CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    B B
    As close as I can measure it is 5/8 inch
    Larry K
    Sig Brotherhood # 1 Sig Kadet Brotherhood # 4 WACO Brotherhood #34 Cub Brotherhood 14
  8. #3783
    Join Date
    Nov 2005
    Leesburg, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ORIGINAL: Big_Bird
    Yeah, but if I show it to you, I'll have to confiscate all your planes.
    Bill, AMA 4720
    WACO Brotherhood #1
  9. #3784
    Join Date
    Jul 2003
    newton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ORIGINAL: Big_Bird
    I do, I used it on my UMF ailerons, works very well, although the spacing is not exact scale for 1/5, it is close.
    The prices are about a year old, but:
    SIGRPCP404A--sheets are 5-1/8" x 12", thickness is 0.010", rib spacing is 15/32". These sheets aren't long enough to get a complete aileron on the 1/5 scale without piecing it, but the rib spacing is closest of the three to 1/5 to scale, and is almost dead nuts exact for 1/4 scale. These are $1.99/sheet. If carefully cut, you could piece them, but you'd need two sheets each for top and bottom of each aileron in 1/4 scale, as they aren't wide enough to do both surfaces out of one sheet, or long enough either.
    SIGRPCP2571--sheets are 8" x 17", thickness is 0.010", rib spacing is 21/32", the price is $2.59/sheet. This is the size I used for my ailerons. I think the scale # of ribs is 33 or 34 per aileron, this sheet will give you 21 ribs/aileron on the 1/5 scale, and the sheet is wide enough and long enough to do top and bottom of one aileron per sheet in 1/5 scale, don't think so in 1/4, though.
    SIGRPCP2572--sheets are 6-1/2" x 13-1/2", thickness is 0.010", rib spacing is 23/32", price is $1.99/sheet. Very close to the one above.
    The "other" Ken
ID:	774308   Click image for larger version.
    Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
  10. #3785
    Big_Bird's Avatar
    Join Date
    Dec 2001
    Arlington, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    khodges, we were posting at the same time and I didn't see your information until I had posted, therefore, that is the reason that I edited this post. That is exactly the info that I needed.
    Bill, I've decided that I don't need to see the secret hand shake. Thanks anyway. []
    Ken
  11. #3786
    Join Date
    Mar 2004
    Lafayette, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    thank you all !
    Tony, AMA 120246
    WACO Brotherhood #71
  12. #3787
    skylarkmk1's Avatar
    Join Date
    Sep 2004
    Festus, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Jim,
    Three shots of ailerons, the Turquoise Blue from the YKS (bottom side), Light Blue from UPF-7, NC 173E (top) and the grey from UBF-2, NC 12002 (top). The rivet pattern is mostly on the inboard area of the aileron and in the 16th space from the tip rib (grey aileron). Khodges is correct, 34 ribs (or corrugations) and 35 spaces per aileron. Also note the different locations of the mounting plate for the aileron connection struts.
ID:	774328   Click image for larger version.
ID:	774329   Click image for larger version.
  13. #3788
    Big_Bird's Avatar
    Join Date
    Dec 2001
    Arlington, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    I just finished ordering 4 sheets of: SIGRPCP2571--sheets are 8" x 17", thickness is 0.010", rib spacing is 21/32", the price is $2.59/sheet plus $8.99 for shipping.
    I can cover both sides of the aileron with one sheet. This will give at least 25 ribs per aileron on 1/4 scale. Not scale I know but khodges looks good.
    Ken
  14. #3789
    Join Date
    Jul 2003
    newton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ORIGINAL: Big_Bird
    B.B., you don't know where his hand's been, be careful
  15. #3790
    Join Date
    Nov 2005
    Leesburg, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ORIGINAL: khodges
    ORIGINAL: Big_Bird
    Bill, AMA 4720
    WACO Brotherhood #1
  16. #3791
    Join Date
    Nov 2005
    Leesburg, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ORIGINAL: khodges
    ORIGINAL: Big_Bird
    The very idear, I'll have you to know that I washed that hand (actually both of them) last week. Of course, you Officers were taught to wash your hands after you go to the bathroom, while Master Chiefs know not to use the bathroom on your hands.
    Bill, AMA 4720
    WACO Brotherhood #1
  17. #3792
    Nightstalker's Avatar
    Join Date
    Sep 2004
    Glendale, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ORIGINAL: Stickbuilder
    ORIGINAL: khodges
    ORIGINAL: Big_Bird
    Bill, AMA 4720
    WACO Brotherhood #1
    You guys need to try utilizing the "CRT" (Crew Relief Tube) in the back of a pitching MH-47 Chinook... at night even. Man I used to go through a lot of Nomex flight gloves...
    Oh and Lt. - This may be a dumb question (I know... you'd expect such from an ARMY Doggie), but what would be so difficult about making the aelerons out of sheet balsa and square stock to resemble the plastic ones. You said they are not quite 1/5th scale, so why not make wood ones that are 1/5th scale? Sounds like something even I could do Unless it's a weight thing.
    Out Here,
    Todd
    WACO Brotherhood #47
  18. #3793
    Join Date
    Nov 2005
    Leesburg, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Todd,
    I did a set using 1/16" square stock (sanded to shape) and it looked good. It did, however, seem to take forever to make them.
    They were fairly light, but there are materials out there that lend themselves to the process in a much easier manner.
    If you guys would fly your Hooks at a more reasonable altitude, you wouldn't have had that problem.
    Bill, AMA 4720
    WACO Brotherhood #1
  19. #3794
    Join Date
    Sep 2004
    Glendale, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Todd,
    Bill, AMA 4720
    WACO Brotherhood #1
    Well, your soybean field was looking a little dry, so we were just helping you out with a little aerial irrigation. What's so unreasonable about 10 feet AGL at 150 knots? Unless you REALLY gotta go #2 [8D]
    Todd
  20. #3795
    lazyace's Avatar
    Join Date
    Jul 2002
    buffalo, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    stickbuilder
    hi this is brotherhood 67 just got my kit from e-bay all the wood looks pretty good but no plans were sent in the kit, got your updated manual , sent an e-mail to the shipper , but who knows I guess I got taken , so were do I get a set of plans , my shop is waiting for this build to start can't wait to get started thanks , oh by the way b&b has a mount for the fuji 23 that lets you not cut out the back of the firwall I think you need 71/4" to prop nut from the back.
    charlie
    charlie AMA 8916
    WACO brotherhood #67
  21. #3796
    Join Date
    Jan 2002
    Bethesda, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Charlie
    I have been given a 1/5 pica kit to dispose of. I was debating about duplicating the drawings before I do that. If you would pay the cost of extra copies I would order more then one
    TR
    WACO BrotherHood # 69
  22. #3797
    Join Date
    Sep 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Trying to spot if the YMF Classic has a strobe on the belly that I can't see in this shot. Too lazy to drive to the airport and with todays weather, he probably wouldn't be home anyway! It looks like landing lights and wing tip lights only! Is this correct?
    Jim, MAAC #5343
  23. #3798
    Join Date
    Nov 2005
    Leesburg, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Charlie,
    You can order the plans from the AMA plans service, or let TR run a set for you.. If you opt for the copied sed, check the measurments for square, since some copy machines can and will skew the drawings.
    Super Cub Man,
    It depends on the plane. You can specify lighting for the application with the Classic. I would think that all newer planes would have the strobe package. Check with Mike Barbee, since his third scale Genesis is about the best detailed one that I have seen. Doesn't mean that there is not one nicer, but I haven't seen it. Mike is a Brother, so he should be happy to give you the info.
    Bill, AMA 4720
    WACO Brotherhood #1
  24. #3799
    Join Date
    Jul 2003
    newton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ............. to use the bathroom ................
    How long you been out of the Navy, Bill? You've stopped using NavySpeak, anyway. I thought the proper phrase for an old salt was "make a head call"
  25. #3800
    Join Date
    Nov 2005
    Leesburg, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ORIGINAL: khodges
    I've been out 19 years 1 month and 23 days. I would have used the term, "Head", but would have needed to retrain the rest of you. Just wait until I start talking about Charlie Noble, and the Scuttlebutt, and the Geedunk.
    Bill, AMA 4720
    WACO Brotherhood #1
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
