Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
WACO YMF
Old 11-19-2007, 12:25 AM
  #4501
Hughes500E
Hughes500E's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: WACO YMF
My thought with the flat wire, seriously above my ability and patience to setup and re setup and take off and re setup and take off and re setup repeat etc.
Now if it were a 1/4 scale or larger, I would have kept with it.
Anyone know of a "for looks" option that would be acceptable?
Hughes500E is offline
Old 11-19-2007, 12:41 PM
  #4502
Stickbuilder
Stickbuilder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
MrDHud,
Dan,
I talked with Stan's Fibertech on Saturday, and he was laying your cowl up then. Won't be too long now. We are going to need to cut the lip down on the front of the cowl. It will set too far back into the engine compartment. This can easily be done by taping off what you want to keep, and using a Dremel with a cut off wheel to remove the unwanted part. You can finish off the cut with sandpaper.
Bill, AMA 4720
WACP Brotherhood #1
Stickbuilder is offline
Old 11-19-2007, 03:33 PM
  #4503
JoeAverage
JoeAverage's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: SuperCub Man
Quote:
ORIGINAL: Stickbuilder
Hughes,
I'm thinking seriously about ordering a set from Switzerland. Have you seen them? They look real.
Bill, AMA 4720
WACO Brotherhood #1
Bill - If you are talking about fittings as in the pix. the flat wire is available from Nelson Hobby Specialties in Texas http://www.nelsonhobby.com/wires.html and the fittings are available from Bob Holman Plans http://bhplans.com/. I'd suggest you phone him. You get a pair of fittings for about 2.50. One is threaded and the other end is not so that you can simply turn the wire and tighten it to your specs. I think these are the same as Reeves offers. I got them and will be using them on my Dragon Rapide!
Them's the ones. How about posting an address, phone number, and/or internet address?????
Bill, AMA 4720
WACO Brotherhood #1
I thought I just did!!
On the phone with Jerry Nelson right now hoping he had that flying wire back in stock. I had just asked him a month ago about it last time. He has been out for a few months. He suggests Proctor. They have a flat wire that is actually clock spring. It is shown on Proctor Enterprises site if memory serves. It is "flat" not streamlined. It keeps getting tougher to find this stuff. The stuff Nelson had was an industrial product that was no longer needed, hence no longer made. Jerry said it would have been about 15K to get a batch done just for him. I didn't mention he might take it off his site.
JoeAverage is offline
Old 11-19-2007, 03:57 PM
  #4504
JoeAverage
JoeAverage's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: WacoJoe
Quote:
ORIGINAL: skylarkmk1
I don’t know if any YMF/UMFs were converted to cabin versions.
I've never seen any records to indicate that a YMF/UMF ever had a canopy installed. F-6 series (ZPF-6 primarily) had the canopy over the rear cockpit, and there may have been some F-7s as well.
Joe
WB #54
WacoJoe,
Sorry I can't post the photo as it can't be downloaded but the Waco Club has a beautiful 1935 UMF-5 NC14687 posted on their site with a first rate canopy conversion done to it. (I took a photo of it off my monitor though) It looks like an old photo so maybe the factory had something to do with it. Originally sold to Ms. Hope Noyes Aviation. C.C. Hicksville, L.I. N.Y. I don't know what the C.C. means in the production record unless it has something to do with Custom Canopy.
Edit This looks like one of Texaco's AC at one time as well. It's c/n is 4215. It looks like it met it's end on or before 1945. It has not been redesignated. Records show c/n 4214 is a YMF-5 and still Airworthy.
Would you know if Waco had it's own factory in Ft. Erie, Ontario, Canada or if someone like Fleet was building them under licence? I was surprised to find out recently that there were Canadian built Wacos. The upper right corner of the one cover shows that this Waco was built in Fort Erie, Ontario. The other cover cuts off the name of Canadian City with Waco plant.
John
ID:	807364   Click image for larger version
ID:	807365   Click image for larger version
Old 11-19-2007, 06:46 PM
  #4505
Jim Henley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
H-500, I use beading cord that is available from craft supply stores. It has enough elastic to keep it tight, and you do not have to worry with the tension. I use black on the Super Stearman and silver for the WACO.
Jim Henley is offline
Old 11-19-2007, 08:50 PM
  #4506
skylarkmk1
skylarkmk1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John (Joe Average),
You are correct that UMF NC14687 is pictured with a canopy and I missed it when I looked at the picture before. After looking at the photo, I also noticed that the navigation lights are on the leading edge of the upper wing like most UPF-7s and not halfway between the LE and tip like most original YMF/UMFs. The photo also reveals fairings over the strut mounts, a metal foreward cockpit cover and the foot peg pretty well. The emblem on the fusealage appears to be a triangle and not a star like Texaco used. The pictures below are from the HARMs UBF-2 NC 155Y "TEXACO 17"
ID:	807622   Click image for larger version
skylarkmk1 is offline
Old 11-19-2007, 09:15 PM
  #4507
JoeAverage
JoeAverage's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello John,
You're right about the triangle. Because of it's sporty appearance I thought "Texaco" but the ownership didn't jive. It could have been, and would make sense that the triangle and enclosed cockpit may be a Civil Air Patrol role. ??? Another example shown.
I'm sure someone will know for sure and advise.
John
Old 11-19-2007, 09:36 PM
  #4508
skylarkmk1
skylarkmk1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John,
The Civil Air Patrol emblem is a good possibility with the Dark Blue background (looks Black in the B&W photo). Since the registration was cancelled in 1945, I feel the chances of conformation is slim to none.
Old 11-19-2007, 09:57 PM
  #4509
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John,
The Civil Air Patrol gets it's marching orders out of Scott AFB. Maybe someone there has info, If that fails, the CAP museum is at Maxwell AFB in Montgomery AL. Chances are they would have information on all CAP aircraft, especially those that were used as patrol aircraft during WWII.
Bill, AMA 4720
WACO Brotherhood #1
Old 11-19-2007, 10:38 PM
  #4510
Hughes500E
Hughes500E's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Jim, I'll look into that.
Old 11-19-2007, 10:41 PM
  #4511
skylarkmk1
skylarkmk1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bill,
Thanks for the CAP info, I'll start digging. I felt and still feel that voluntary conformation is doubtful, but with the info you have provided, there is a good chance that a record exits that may prove that UMF NC14687 was a member of the CAP.
Old 11-20-2007, 05:52 AM
  #4512
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There were hundreds of civilian owned airplanes that were used for patrol aircraft during WW II. One was credited with sinking a U-Boat off the Atlantic coast. Who knows how many other ships were scared-off because of them. They pretty much provided our coast lines with anti-submarine patrols for the entire war. Heck, they dang near sank one of ours.[:@]
Bill, AMA 4720
WACO Brotherhood #1
Old 11-20-2007, 08:24 AM
  #4513
mango12
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I live about two hours from Maxwell AFB. If they do have any records of a Waco being used by the CAP, I'll be glad to make the drive for more research, if it is any help.
Scott
mango12 is offline
Old 11-20-2007, 08:36 AM
  #4514
red1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Skylark1
See http://history.nhq.cap.gov/historica...atrol_airc.htm regarding General Memorandum-29, May 25 1942. "...now required the removal of the red three bladed propellor from the CAP aircraft emblem on all airfraft assigned [to Costal Patrol]. The official CP insignia now consisted of a blue circle with white isosceles triangle was the only authorized insignia for CAP-CP aircraft. This was in keeping with the current practice of the AAF to avoid confusion with Japanese emblem. This directive and practice remained in effect until the Costal Patrol units were disbanded in 1945."
Red 1
[formerly LtC, Historian, Maryland Wing, Civil Air Patrol]
red1 is offline
Old 11-20-2007, 09:44 AM
  #4515
red1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi JoeAverage,
See my post above. Also, the caption on your photo reads as follows: "NC14000 is a 1937 Waco YKC mc/n that is owned by Byron and Jeannie Hight of San Jose. As this plane was once used by the Civil Air Patrol to patrol for enemy submarines, Byron has recently added CAP [Costal Patrol ] markings and is looking for a shackle, for his dummy bomb."
I have forwarded this photo to Col. Leonard Blascovich, CAP National Historian, asking if he knows of any CAP CP AC registration list.
Red 1 [aka Don Borton]
AMA IMAA
Waco Brotherhood #72
red1 is offline
Old 11-20-2007, 01:15 PM
  #4516
skylarkmk1
skylarkmk1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Don,
Thanks for the link to the CAP emblem information. As I read it, my interpretation is that only the Coastal Patrol Aircraft had the Red Propeller deleted and all other aircraft flying missions in the interior of the US retained the red propeller.
If Col. Blascovich does have a listing of CAP A/C used during the war and there is a link, could you please post it? My search so far has found links to current activities, State Wings and other stuff, but not to historical info (except for the history on the CAP Museum pages) such as aircraft and/or personnel listings.
Also ask Col. Blascovich about 1935 Waco UMF, NC 14687, s/n 4215. Its registry was cancelled on Jan 16, 1945, no reason given.
As you were the Historian for the Maryland CAP Wing, you may have connections to info that is hard to come by for those not connected with CAP. Thanks for any info you can provide.
Old 11-20-2007, 02:15 PM
  #4517
michou41a
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So everyone knows :
Aircraft Modelers Research is bringing back the most famous 33% and 40% Waco kits. Shipping to start in February 2008, ready to take your order now. The new owner is particulary proud of its new product : lighter then the previous and more fiberglass parts.
Michel Normandin
Waco Brotherhood #78
michou41a is offline
Old 11-20-2007, 02:33 PM
  #4518
red1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Skylarkmk1
red1 is offline
Old 11-20-2007, 02:34 PM
  #4519
red1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Skylarkmk1,
Let's try that again. Wilco.
Red 1
red1 is offline
Old 11-20-2007, 04:05 PM
  #4520
Tony V.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Damifino,
Did you ever come up with paint masks for the cowl...
Tony V. is offline
Old 11-20-2007, 04:06 PM
  #4521
BigBoy99
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Guys,
does anybody have files in the format .svg = scalable vector graphics, for the decals of a YMF-5?
I have one in the .dwg format , but I cannot convert them. Also possible is jpeg. They must be compatible with Corel Draw.
Regards
Bernie
BigBoy99 is offline
Old 11-20-2007, 04:32 PM
  #4522
skylarkmk1
skylarkmk1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bernie,
Check back on page 175, post # 4357 and go to the website posted. After you click on the down load button for the Waco logo, another page comes up that has Corel Draw listed. If Corel can open an .EPS file (Encapsulated Postscript file) you are good to go. On pages 175-176 the are more logos listed and posted. If any I have posted can be of use (.jpg format) send me a PM.
Old 11-20-2007, 05:36 PM
  #4523
WacoJoe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: JoeAverage
WacoJoe,
Hi John,
Waco was all about building aircraft to customer specifications, so they did a lot of custom and one-off stuff. That being the case, it's very possible that they did the canopy installation on the YMF-5 that you're referring to. I've just never seen any documentation of it is all. That certainly doesn't hold a lot of water because there are several folks who are much more well versed on the history of Waco than I am. But if the factory did it, it's a pretty well kept secret!!
I have no knowledge of Waco building aircraft in Ontario Canada, but again that is not a guarantee that it didn't happen. My guess is that it may have been a license agreement situation. I'll have to see what I can find out about that. Someone on the National Waco Club forum will have the scoop.
Cheers!
Joe
WB #54
WacoJoe is offline
Old 11-20-2007, 06:29 PM
  #4524
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: BigBoy99
Hi Guys,
Regards
Bernie
Bernie,
I just sent as set for the 1/5th scale version to damifino. He is looking into getting them scanned for reproduction. It should be simple for them to enlarge them to 25% size.
Bill, AMA 4720
WACO Brotherhood #1
Old 11-20-2007, 09:09 PM
  #4525
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Okay, Here is the roster to date.
WACO BROTHERHOOD MEMBERSHIP:
#1 stickbuilder
#2 Hughes500
#3 Jim Henley
#4 mmattockx
#5 CTflyboy
#6 michaelj2k
#7 Ronj10
#8 gwulle
#9 jim schroer
#10 Skinny Bob
#11 Bart5495
#12 Pimmnz
#13 HarryJ
No. 14 Old Git
#15 ChrisMH
#16 Nerevar
#17 Ricatic
#18 Clay H.
#19 Tripp2Loo
#20 KHodges
#21 Bill Hogue (WACO One)
#22 Mangolo (Waldo)
#23 av8ter
#24 yel914
#25 damifino
#26 skylarkmk1
#27 Jacque
#28 Edwin
#29 AROPLANE
#30 CubNut (Anthony)
#31 BQuartucy (Bob Q)
#32 AERORON
#33 funkymusic
#34 Live Wire (Larry)
#35 obo (Bob)
#36 Jackk36 (Jack)
#37 fatherrooster (Jim)
#38 Ilikebipes
#39 Kestrel0222
#40 CROWMAN17 (Marc)
#41 redcesar
#42 S. Christensen (Scott)
#43 Bill Deidrich
#44 Mike Barbee
#45 mrdhud (Dan Hudson)
#46 SoCalSal
#47 Todd (NightStalker)
#48 argon (Bob Gonzalez)
#49 mango 12 (Scott)
#50 skyjet 1
#51 ZIG
#52 Didg
#53 MarvinE255 (DOC)
#54 Joe Norris (Full Scale WACO Pilot)
#55 vasek
#56 SuperCub Man (Jim)
#57 Black Drape (Ron)
#58 aminiet (Angel Minet)
#59 Snowball
#60 doc zinger
#61 jagnweiner (Scott)
#62 Meesh (Bob)
#63 BigBoy99 (Bernie)
#64 stifts (Steve)
#65 RCWalker (Wallace)
#66 Mobyal
#67 lazyace
#68 bladerunner1955 (Don)
#69 trlambsr
#70 Big Bird (Ken)
#71 Tony V (Tony)
#72 red 1
#73 412t1 (Sean)
#74 Mr Lucky (Ben Warner)
#75 RICKSTUBBZ (Rick Stubblefield)
#76 ffdg (Fred)
#77 tomcraig
#78 Michou41a Michel
#79 Watzscale (Dick Watz)
#80 Devens
#81 msilvestro (Mark)
#82 Cheechukranch (Lewis)
#83 kruzin55
#100 nine o nine (Mitch Epstein)
WACO Sisterhood Roster:
S-1 Janelle (Lady Stickbuilder)
S-2 Sissy Nightstalker
S-3 Barb Barbee
S-4 LadyMango (Lynda)
Bill, AMA 4720
WACO Brotherhood #1
Display Modes
