WACO YMF
#5551
RE: WACO YMF
That is a bit dissapointing but Oh Well,
I will look at making a cowl to pull a mold from. I am assuming a solid wood cowl will work for pulling a mold?? I can make a blister then get a buddy to vaccum form the rest for me then add them to the cowl before making the mold.
Anthony
btw: I have started building my 1/4 scale Waco and I am posting pics in the Scratch Build forum.
Anthony
#5552
RE: WACO YMF
ORIGINAL: khodges
Anybody heard from damifino lately? Is he still having computer/'net problems?
Bill, AMA 4720
WACO Brotherhood #1
#5553
RE: WACO YMF
Anthony,
If you have access to a wood lathe to form the base cowl that would be a great start. I was going to use builders foam insulation and some plywood, but a solid wood plug would be stronger. Carve a master cowl bump, make a mold from it and make fourteen bumps, glue them to your base cowl, apply a little putty to fill any voids, seal and wax the completed plug. It’s got to shine. I would them make a 3 or 4 part mold to make the cowls from. Maybe the guys at Stan's might buy your mold from you. A couple of places to look for cowl making tips;
RCU Composite Forum;
Fiberglass How to: Plug to Mold to Parts by DocJones199
How To Make Mold For Cowl by GSAV8R
Other places;
CST http://www.cstsales.com/index.html Look in the Tutorials (top bar) for different tutorials in PDF format.
Steve Jones www.fiberglassmoldmanual.com sells a comprehensive manual about making molds, parts, making plugs, multiple piece molds for complex parts and more. Lots of good info in the manuals.
Fibretech Great Britain http://www.fibretechgb.co.uk/DefaultHome.htm has a tutorial for making a glass cowl from an ABS cowl under Working Tips.
Good luck
Other places;
Good luck
#5557
ON, CANADA
RE: WACO YMF
Jim/Ken.....................Some pictures of my progress on the 1/6 Waco landing gear. Not completed yet, shows the under fuselage cutout, parts and soldered brass plate. Just need to figure out how far it should protrude out the bottom of the fuselage. In your picture I noticed that your hardwood block has two wood screws. Is that piece of h/w glued in also ?.
Thanks again.
Charles.
Waco Brotherhood #87
Thanks again.
Charles.
#5558
RE: WACO YMF
All,
I have finally received my copy of the Pica Plans from the AMA. I have been working from the PDF Plans posted on the House of Moy (HoM) site and have noticed a few differences.
The date on the AMA version is 1990, HoM plans have no date.
HoM is 3 sheets - wings, fuselage w/rudder, tail (stab, elevator) with additional patterns for the front cockpit cover, door, access panels and fuselage sheeting templates, etc.
AMA is 2 sheets (not counting the templates stickbuilder provided) – wings, fuselage with stab and rudder. There is a separate small sheet with just the interplane struts. The location of the fuselage sheeting is shown (no templates).
Tail Wheel location has been relocated on the AMA version to the correct scale location at F-14B, HoM has the tail wheel on the rudder.
HoM plans have the templates for conversion to an enclosed rear cockpit and vertical fin/rudder and stab/elevator outlines for UPF, YPF and ZPF or cabin version (enclosed rear cockpit?).
AMA - Stringers are numbered in addition to being lettered.
There may be a few more minor differences. The 1/6th HoM plans are similar to the AMA plans on a smaller scale with out the tail wheel being relocated or stringers being numbered and the layout is slightly different (stab on wing sheet, etc).
My suggestion is to download a copy of the HoM plans as a reference to the AMA plans especially if planning on doing an enclosed rear cockpit.
#5559
RE: WACO YMF
ORIGINAL: Garthwood
Ken..................... noticed that your hardwood block has two wood screws. Is that piece of h/w glued in also ?.
Thanks again.
Charles.
Thanks again.
Charles.
#5560
RE: WACO YMF
ORIGINAL: Mainer_Jim
I Have a friend who is very good at making cowl molds. I will ask him if he is still doing it.
Jim
Jim
I will be very interested in a cowl if your buddy is willing to take on the challenge. I will be more than willing to cough up the money for a cowl. I have been fixing some issues with the Pepino drawings and drawing up some scale fittings for the cabane and "N" strut attachment points. Looks like I will have to take the drawings to my brothers shop and have them wire EDM'd. Do you think a 4-40 bolt at each strut end will be strong enough or should I go with 6-32?
Anthony
#5561
RE: WACO YMF
If you find someone to pull a mold for you, you will need to make sure that the plug that you have made is as slick and smooth as what you would like to get as a finished cowl. We went through this with Stan's Fibertech, and we got some great products (thanks to damifino). It is not an easy task, but it can be done.
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
#5562
My Feedback: (19)
RE: WACO YMF
Anthony,
On something 1/4 scale I wouldn't use anything as small as a 2-56 on anything structual, period. That's just me, though. Of course, my stuff never ever falls apart in the air, and I know LOTS of guys whose stuff does!
If those are your only choices, go with the 4-40.
Bill, should I ever get involved in the practical application of readying a plug, anything I produce would make you plum proud of me. I used to do autobody work and I also used to custom-paint, and your surfaces have to be perfect for most of that. However, as long as I live in Maine and as long as it's winter, I can't really do this stuff because I can't use the necessary products indoors. I'm not in a huge rush anyway. I'm a gatherer, I gather stuff together until I'm ready for a build. I usually have enough in the wings to keep me busy in the meanwhile and just keep my eyes open as I go.
Jim
Jim
#5563
RE: WACO YMF
I would never think of using 2-56 for the attachments either,
I think 4-40 will suffice for the number of attachment points will spread the load.
Anthony
Anthony
#5564
RE: WACO YMF
ORIGINAL: CubNut
Anthony
Anthony
I have not been able to confirm the strut bolt size on the full scales as of yet. However, in the pictures I've seen, they look to be 1/2". If they are indeed 1/2", in quarter scale, 6-32 would be about .010" over size were as 4-40 would be about .010" undersize. Give or take a couple thousandths. Either would be as accurate as the other, why not go with the stronger of the two???
#5565
RE: WACO YMF
Rick,
I did measure a few of the strut bolts on UBF-2 NC 2091K at the wing/strut and cabane/fuse connections and they were 1/4" [X(](the nut measured 7/16" which is correct for 1/4 x 20 bolts). I know it sound small, but other Wacos in the hanger had similar bolts. I was not able to get the thed count, not enough thread was exposed and the Waco Mechanic was not there that day.
I did measure the interplane bolts on the Pepino Waco I picked up for Mainer Jim and they are 4-40, but a bit loose were the strut connects to the wing. I think the strut end fitting could be drilled out or tapped for a 6-32 for a snugger fit but I will let Jim determine that when he gets the plane and has time to check it out. The clevises appear to be the Dubro RC 4-40 Threaded Rod Ends (part # 302).
#5566
RE: WACO YMF
ORIGINAL: skylarkmk1
Rick,
Rick,
Thanks, for that information. I woulkd have never guessed that a 1/4 bolt works for the strut connections on the full scale aircraft.
Anthony, that blows everything I wrote above right out of the water. Sounds like your idea with 4-40's will be the best option.
#5567
RE: WACO YMF
Rick,
I added a bit more to the above post, The 4-40 hardware does not look too far out of place, the "jam" nuts could be smaller (outside diameter/wrench size) on the clevises.
Also remember that the bolts on the full scale are aircraft grade bolts and are much stronger that the commonly found bolts (grade 3) at the local hardware store.
#5568
RE: WACO YMF
I did some close examinations of a full scale Stearman,
All the flying wire ends and the bolts for the strut attachment were fine threads ie: 1/4-28 etc: It was surprising how small some of the hardware was but like John said it is all aircraft grade hardware.
Anthony
Anthony
#5569
MA
RE: WACO YMF
I am asking this ? for WACO Brotherhood #90. He is presently putting in a OS TWIN 160 and would like to know. If he will be having any fuel problems. The tank is higher than the carb. If so, what have others done to correct the problem. Thanks for your inputs.
#5570
ON, CANADA
RE: WACO YMF
I was not sure if I should glue it in case it needed to be removed, I did glue it though, but first I mounted the spring, bolt and the L Angle on a square piece of hardwood first with a screw in the bottom of the aluminum L angle at the base. There's not that much room to work on the 1/6Th unless I remove more of the bottom sheeting. Instead I glued around the L angle square blocks of HW . There's no way the L angle going to move up or sideways. I did this in case I need to remove the L aluminum angle, I can just reach for that one screw and it will come off. I'll send you some pictures when I get some taken. I tested the landing gear wire by spreading the wire, wow........it does work. That spring idea is just great. The landing gear gives under the weight and yet the spring does the job in keeping the wire landing gear under control while softening the impact. Thank you Jim and Ken for such a great idea.
Charles
#87
Charles
#87
#5571
RE: WACO YMF
All,
The aileron corrugations detail has been solved. I just got my copy of Bob Banka’s UPF-7 3 view (Sb 2821) and on page 3 of 3; upper right hand corner was the answer we have been wanting. The corrugations are 3/16” high, 5/16” wide with a 1/16” inch radius at the bottom and are spaced 1-11/16” apart. This is a good 3 view (3 pages) with cross sections, airfoil coordinates and lots of other full scale detail. It is drawn by Nicholas Karstens and is similar to the Paul Matt drawings of the YMF/UMF.
On the other hand, the Waco UMF, Waco N, Waco F/F2 are just outline 3 views with no detail, the 3 view on the Pica plans is similar and actually has more detail than the Banka 3 views.
All,
I received my package from Bobsairdoc today. I agree, the UPF7 three views are worth the price of admission. I do beleive a fellow could scratch build a plane entirely with that three view. Have read two of the ten articles on the catalog disk. For those like me (wannabe scale builder)[sm=49_49.gif], it is good information. I picked up the AcroSport three views as well. I have some more number crunching to do...But, I think I will bash the BalsaUSA EAA into an AcroSport. Thanks to all you guys on this thread--What was going to be a sport radio control airplane is starting to progress into a semiscale aircraft.
#5572
RE: WACO YMF
ORIGINAL: flyer495th
Bill, AMA 4720
WACO Brotherhood #1
#5573
ON, CANADA
RE: WACO YMF
ORIGINAL: ctflyboy
Jim Henley,
SOLARTEX, as far as I'm concerned, I won't use anything but Solartex, on any of my builds.
George
WACO Brotherhood # 5
Jim Henley,
George
Do you or anyone know of this product and have used it? How did it work? Are there subs for it? What paint do you normally use on Solartex?
A lot of questions I know! I normally use Krylon and with nitro models over-coat with water based polyurethane but with gas models I just leave it. I'm wondering, (other than coverall and dope Bill!) what others use but just on Solartex! Do you use any kind of primer? I never have! Always looking to try something new!
#5574
My Feedback: (22)
RE: WACO YMF
I have used solar tex for years , the only thing I use on the air frame is the cheapist hair spray I can find ,It really works. Jerry Nelson from Nelson hobbies passed that on to me.
The paint I use is Nelson water based paint or if I change color I use pray cans of Krylon with there primer first fom home depot.
JAcque
Botherhood #27
JAcque
Botherhood #27
#5575
RE: WACO YMF
ORIGINAL: SuperCub Man
Well, my super-caffeinated jumbo Starbuck's mocha cappuchino latte is starting to kick in, gonna head to the shop and churn up some balsadust, Ca my fingers together, and try to get this BirdDawg in the hunt.
