Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
WACO YMF
Reply
Old 01-06-2007, 12:43 AM
  #701
bart5495
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: WACO YMF
John nice to hear from you. Thought you might like to know that my dad was a b24 pilot with 445th squadron 703 group. flew out of Tebengham field. Is that field close to you?
Doug
Waco Brotherhood #11
bart5495 is offline
Old 01-06-2007, 12:46 AM
  #702
Hughes500E
Hughes500E's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bought mine from Uncle Willie LOL, small world!
Hughes500E is offline
Old 01-06-2007, 04:48 AM
  #703
old git
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: bart5495
Doug
Hi Doug,
I didn't recognise Tebengham field at all so I googled it and found Tebenham airfield, (Jimmy (James) Stewart was CO and 445 Squadron flew Liberators (B24) from there. This field is in Norfolk County (UK not Virginia) and home to the Norfolk Gliding club. I've never been there but will next time we are in Norfolk
I thank your father for his efforts on our behalf. I saw the aerial fighting from both Croydon and Bristol as a child. My father was medically unfit for flying (despite his civil aviation experience) and wound up as an officer in the Royal Artillery, never left our shores.
I saw in RCU a comment that seems very accurate.
"If you can read this, thank a teacher!"
"If you can read it in English, thank a Veteran!"
old git - - - - - - aka John L.
Waco Brotherhood No 14.
old git is offline
Old 01-06-2007, 09:01 AM
  #704
old git
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Stickbuilder
As to your masking situation, can you guys get 3-M Fine line tape over there? If you can, that is what I would use to outline the blisters, and purple masking tape for the rest of the cowl. The fine line is as flexible as electrician's tape would be if you could get it down to 1/8" wide. The purple tape will not allow the paint to be pulled off when removing the tape.Bill, AMA 4720
WACO Brotherhood #1
I found fine line tape on eBay UK http://stores.ebay.co.uk/Jammy-Dog. He is a Brit seller and delivers quickly.
It cost me £4.00 (circa $8.00) plus post. For that I got four rolls of 25 Metre long @ 0.5mm, 1.0mm, 1.5mm and 2.0mm wide.
I was wondering what would be the best method to use the tape. Paint the area where I want the line with a De Vilbiss, mask over it and then spray the rest of the cowl?
I have used drafting tape for masking, it's low tack to avoid tearing the drawing paper.
I have used "pull out" masking tape to sold desecrate, sorry customise cars. The stuff is really easy to use, lay down the tape and tear out the middle, doesn't like to go around model sized curves.
pld git - - - - - -aka John L.
old git is offline
Old 01-06-2007, 09:13 AM
  #705
Stickbuilder
Stickbuilder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I paint the entire cowl, then using the fine line tape (very flexible) mask off the rest of the cowl and the portion of the blisters that you wish to remain the base color, and lightly scuff (400 grit wet or dry) the area to be painted, and inspect to make sure you didn't move or cut into the fine line tape. If everything is intact, paint the trim color. Give the trim paint time to flash, and remove all the masking tape. Allow time for the trim paint to cure, and clean the entire cowl with wax and grease solvent (or isopropyl alcohol) I then add a contrasting pin stripe at the trim line with a dagger brush, and then mist a coat of clear on. Once the mist coat has cooked off, give the cowl a gloss coat of clear, and then wax to your heart's content.
Bill, AMA 4720
WACO Brotherhood #1
Stickbuilder is offline
Old 01-06-2007, 02:54 PM
  #706
flyguy888
flyguy888's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: bart5495
Hey, are you guys really up at during the wee hours of the day to anwser these email's. What are your spouses and girlfriends doing. I'm having a quilt problem spending so much time in my aircraft assembly area.
Doug
Gee, am I glad you mentioned this. I don't believe I have checked in on my wife since July. I know she still loves me because everyday she leaves a plate of hot food on the floor just outside the workroom door and the towels in the shower get changed every week. You know, if your kids are moved out and you have electronic payroll deposit your wife can get by pretty well. Now quit whining and get back to work on that airplane.
flyguy888 is offline
Old 01-06-2007, 03:01 PM
  #707
Hughes500E
Hughes500E's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm having a hard time coming up with a RESPECTABLE tail wheel assembly. The idea of relying on a set screw attached control arm is less than appealing in a hard to get at assembly. Other than making my own, with thought to using pull pull on the rudder, what have you come up with?
Pictures would be nice!
Thanx
Old 01-06-2007, 05:47 PM
  #708
flyguy888
flyguy888's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Hughes500E
Thanx
To help secure the set screw you can put a small dimple or flat in the steel shaft with a dremel tool grinding point. That will make a very solid and seat for the set screw and then shaft will not spin inside the collar. You can also use very small socket head screws instead of a set screw so you can really apply torque to the screw. I've done that before.
Old 01-06-2007, 05:48 PM
  #709
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I know that you directed your post to Ron, but I have some ideas on using a pull-pull to drive the tail wheel as well. Let me know if you are interested.
Bill, AMA 4720
WACO Brotherhood #1
Old 01-06-2007, 05:56 PM
  #710
Jim Henley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
H-500,
For what it is worth, I ground flat spots on the music wire I formed the strut out of and then applied small amount of loc-tite as well.
Jim Henley is offline
Old 01-06-2007, 06:46 PM
  #711
Nerevar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I flew the 1/6th Waco with an Enya 60 4 stroke and it was excellent. If I were to build a 1/6th, you could be guaranteed a Saito 72 or 82 would be on the nose!
_____________________________
WACO Brotherhood #2
Yep, thought so. Saito offers the 60 twin for $549.99 which is an ABC engine with muffler. They offer the 90 twin for $599.99 which is the AAc engine (no muffler mentioned), and get this... the 100 twin is just $499.99 and this one is an ABC engine with muffler.
The max width on the 60 is 160mm. The length from mount to prop hub is 125 mm.
The max width on the 90 is 170mm. The length from mount to prop hub is 120 mm.
The max width on the 100 is 169mm. The length from mount to prop hub is 100 mm.
These numbers are directly from the Saito twin cylinder manual, and the prices are direct from Horizon's web site. You can download the manual by doing a Google search and typing in: Saito model airplane engines, and selecting the Horizon site, and specifying Saito engines. I just did it.
It looks as if the 100 twin would be perfect for the 60 size Pica Waco. The width is about 6 1/2"
Bill, AMA 4720
WACO Brotherhood #1
THANKS GUYS!! [sm=thumbup.gif][sm=thumbup.gif][sm=thumbup.gif]
One of those Saitos will more than likely be the power for my Waco.
If I'm measuring the inside diameter of the cowl correctly, I've got to keep it within 6 3/8" to stay inside it without cutting it up.
I'm going to Horizens site and check out the twins, and the 72 and 82.
Many Thanks! [sm=teeth_smile.gif]
NI
WACO Brotherhood #16
Nerevar is offline
Old 01-06-2007, 06:57 PM
  #712
Hughes500E
Hughes500E's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not directing anything at all, asking EVERYONE
I just can't use a set screw type setup. I'm going to construct my own using a maple block with 1/8th inch music wire. It will be spring loaded etc. I'm also going to run a 2-56 rod to drive it off the inboard hole of the large pull pull rudder servo arm.
Been working on it for awhile!
Thanx for the replies!
Old 01-06-2007, 07:43 PM
  #713
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do you have access to a mig welder, or do you have a friend who does? Make up a tiller bar from flat steel stock, drill your hole for your tail wheel strut, and your holes for the pushrod. use a new wire (one that you have not bent) and get the tiller bar welded to the strut wire. run the strut wire through your block of wood, then make the necessary bends to make it into a tail wheel strut. No worries ever, and no set screw either. I do it on my landing gear (wheel pants mount bars) and it works very well.
Bill, AMa 4720
WACO Brotherhood #1
Got my scale gas tank fillers made tonight, and I think you guys will like them. Got the scale navigation lights made as well. Now I just have to mount them. I'll post the method that I use to make the filler necks. (Helps to have auto technicians around from time to time ... they give me lots of good stuff)
B.
Old 01-07-2007, 10:18 AM
  #714
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I took a few pics of the parts for the scale fuel pipes. They are made from discarded automobile valve stems (from the wheels). I simply removed the Schrader valves, and cut the threaded portion off (using the Dremel cut-off wheel) I then shortened the cap to appear more scale like, and It's done. I will mount them today. The Nav lights were made from a small piece of Brass tubing, with a Red and a green decorative pin head C/A'd in place. The light for the rudder post was made by repeatedly dipping a T-pin into epoxy, until the mass was of the desired size. I kept rotating the coated pin, until a teardrop shape was attained. I taped off the top part, and painted the bottom portion. Simple, cheap (I like that part) and effective.
Bill, AMA 4720
WACO Brotherhood #1
Pics in the next post box.
Old 01-07-2007, 10:19 AM
  #715
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And here they are.
ID:	592700   Click image for larger version
ID:	592701   Click image for larger version
ID:	592702   Click image for larger version
ID:	592703   Click image for larger version
Old 01-07-2007, 10:29 AM
  #716
Ricatic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bill,
You are the man!!! You ability to come up with this detail stuff amazes me. Your willingness to share it is much appreciated.
Ricatic
Waco Brotherhood #17
Ricatic is offline
Old 01-07-2007, 10:54 AM
  #717
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Ricatic
Bill,
Ricatic
That's why it's called a Brotherhood. We share, cause It's neat, It's cheap, and it works. (every time). Here's the stuff installed.
Bill, AMa 4720
WACO Brotherhood #1
ID:	592737   Click image for larger version
ID:	592738   Click image for larger version
Old 01-07-2007, 11:26 AM
  #718
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And as I was saying earlier, If you want to get completely stupid with the scale junk, Here's the pull-pull setup for both rudder and elevator on The Corben Super Ace. If that is not enough, check out the articulated tailwheel drive. Both sides are mirror image just to balance things out. Never again. The Ailerons are pull-pull as well. Not fun.
Bill, AMA 4720
WACO Brotherhood #1
ID:	592762   Click image for larger version
Old 01-07-2007, 03:20 PM
  #719
Hughes500E
Hughes500E's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fittings look good, linkage is quite complex , I like it!
Here's a picture of my tail wheel. Picture doesn't do it much justice but I really like it. I have about 1/2 an inch travel on the compression spring, it's a medium to heavy tension, and the Silver Solder took real nice, I used MPS Gas with Oxygen on one of the little BernZomatic cutting torches, worked better for this smaller job than an Acytelene Plumbers Torch!
Just making a doubler for the rear bulkhead, going with a more scale location and I'll mount it. The only problem now, the spring will be visible [:'(] I guess after paint it up it won't be too bad.
Old 01-07-2007, 05:22 PM
  #720
Hughes500E
Hughes500E's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A little more challenging than I thought [:-]
Had to adjust the height of the cut out in the bulkhead so the linkage would clear in all positions.
Spring doesn't show that much either !
Old 01-07-2007, 05:55 PM
  #721
gwulle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bill;
Would you go through how you hooked up the exaust extentions on your 160 twin and the parts used.
Gaines
gwulle is offline
Old 01-07-2007, 06:13 PM
  #722
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
H500,
Build a fairing around it. The full scale ones had the fairing. I really like the tailwheel. Glad you posted it.
Gaines,
I went to Lowe's or Home Depot (don't remember which) in the plumbing section, you should find a lavaratory supply pipe. They are available in increments up to about 24". The price is prohibitive...(about 6 bucks) They are chrome plated copper. They are bendable by hand. All you do is cut them to somewhere about the right length (leave them a tad long) and normally you will have to tap them onto the original exhaust pipes. The fit is very close. I used a dab of high temp RTV (red) for insurance. Then just bend them by hand, and do the final trim for length. That is all there is to it.
Bill, AMA 4720
WACO Brotherhood #1
Old 01-07-2007, 06:50 PM
  #723
gwulle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bill;
Thanks alot for the info. You are correct,it is simple. Good thing !!(LOL)
gwulle is offline
Old 01-07-2007, 08:14 PM
  #724
chris1949
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys just a thought I shoot archery and the aluminum arrows today are very large in diameter 25/64in diameter if you go to a local archery shop in your area ask for the cutoffs when they make arrows.Some are carbon fiber also and extremely strong,I use them for pushrods also,and wing dowels.They probably also have bent ones also try local sportsmans clubs most would save them for you thats where I get mine.Keep up the good work work guys isnt it fun but sometimes challanging thanx Chris
chris1949 is offline
Old 01-07-2007, 08:20 PM
  #725
old git
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi all you Waco Brotherhood men, still looking.
Thanks for all the great info', I've always been inclined to collect ideas, these are gratefully received.
I'm enjoying them too! also I'm trying to keep my mouth shut unless I have something useful to say.
old git - - - - - - -aka John L.
old git is offline
Reply
Display Modes
