WACO YMF
#726
My Feedback: (16)
BC, CANADA
RE: WACO YMF
Bill:
Educate me, I have never seen a full scale with the fairing [:-]
http://www.airliners.net/search/phot...nct_entry=true
#727
RE: WACO YMF
ORIGINAL: chris1949
Hi guys just a thought I shoot archery and the aluminum arrows today are very large in diameter 25/64in diameter if you go to a local archery shop in your area ask for the cutoffs when they make arrows.Some are carbon fiber also and extremely strong,I use them for pushrods also,and wing dowels.They probably also have bent ones also try local sportsmans clubs most would save them for you thats where I get mine.Keep up the good work work guys isnt it fun but sometimes challanging thanx Chris
Interesting how things turn around. My first radio was an Electronic Developments ED 12"? black cube transmitter with a microswitch on a cable. The black box sat on the ground with an earthing spike and a full wave? aerial from aluminium tubes, I think it was about 10' high. The box was heavy with hundreds of single dry cells connected to make up the high tension voltage. The Heater battery was another huge lunp that needed constant replacement. The airborn radio reciever was a single valve super-regen mounted on rubber bands. The servo was a rubber motor connected to an escapement.
The model (KK Jr 60) made a good glider and eventually I used the aerial rods as arrows, more fun than my first radio! Especially since I couldn't start the engine.
old git - - - - - - aka John L.
Waco Brotherhood No 14.
#728
RE: WACO YMF
ORIGINAL: Hughes500E
Bill:
Bill:
Bill, AMA 4720
WACO Brotherhood #1
#730
RE: WACO YMF
Lordy, I've been tearing the internet up this morning, trying to find a YMF with the tonneau in place. There ain't one. I'll have you a pic of the tail wheel fairing in just a moment.
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
#734
CA
RE: WACO YMF
Although I've owned a Pica 1/5 scale YMF kit for a few years, I can officially join the brotherhood now as I've bought two previously owned Wacos - both 1/5th and 1/6th scale. The 1/6th will be converted to electric for flying at my local field.The 1/5th has a 120 FS sticking out the top of the cowl, so I think it will get the 160 twin treatment. So do I get a brotherhood #?!!!
Look forward to spending more time in this forum.
Clay
Clay
#735
IN
RE: WACO YMF
So...I've been wanting to build one of these guys for awhile now, but haven't been able to scrounge up any plans. Is there a source for the Pica or similar (1/5-ish size) plans? And if so, can it be scratched from them, or is there insufficient information?
Chris
#736
My Feedback: (63)
RE: WACO YMF
I have both the 1/5 and 1/6 pica plans in tiff or pdf format. It would cost you a bit to have a printing service get them out on paper to the proper scale. They are nice to look at though.
Also, this hobby is dying out. Please avoid bashing the ARF people. Make friends with them and get them out to the field theycan see a nice hand built and you can invite them to see your shop. Win them over to building.
#737
IN
RE: WACO YMF
ORIGINAL: ronj10
Anyway, if I shoot you my email, would you mind sending me the plans?
Chris
#738
AZ
RE: WACO YMF
Hi Chris - The AMA plans store has what they describe as the 1/5th scale PICA kit plan - $33 less shipping - cheap at twice that price . I was looking for a smaller version (1/2A or so... ima skeerda big models[X(]) and saw that one - does seem kinda steep though (??). Never seen the original PICA plan, but they say that's what it is and I don't know if you could build from it. One of these guys should know.
Hope that helps you out.
Todd
Todd
#740
RE: WACO YMF
ORIGINAL: ClayH
Clay
Clay
ChrisMH,
The plans will be necessary in order for you to build the plane. The bad news is: There are no parts callout on the plans. I am working as we speak to cut the master parts and copy them to a master file (PDF) so that all can have them. I am having to fit the cutting in as I can, and I'm going as fast as possible. They will get there.
By the way, do wou want a Brotherhood number?
Bill, AMA 4720
WACO Brotherhood #1
#741
RE: WACO YMF
ORIGINAL: Stickbuilder
Okay, Here is the roster to date.
WACO BROTHERHOOD MEMBERSHIP:
#1 stickbuilder
#2 Hughes500E
#3 Jim Henley
#4 mmattockx
#5 CTflyboy
#6 michaelj2k
#7 Ronj10
#8 gwulle
#9 jim schroer
#10 Skinny Bob
#11 Bart5495
#12 Pimmnz
#13 HarryJ
No. 14 Old Git
#15 ChrisMH
#16 Nerevar
#17 Ricatic
#18 Clay H.
#19 Tripp2Loo
#20 KHodges
#47 Todd (NightStalker)
Bill, AMA 4720
WACO Brotherhood #1
#1 stickbuilder
#2 Hughes500E
#3 Jim Henley
#4 mmattockx
#5 CTflyboy
#6 michaelj2k
#7 Ronj10
#8 gwulle
#9 jim schroer
#10 Skinny Bob
#11 Bart5495
#12 Pimmnz
#13 HarryJ
No. 14 Old Git
#15 ChrisMH
#16 Nerevar
#17 Ricatic
#18 Clay H.
#19 Tripp2Loo
#20 KHodges
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
#742
RE: WACO YMF
NightStalker, You can build from it, you just can't cut the parts from it. (Ribs and formers) The rest of the parts could probably be traced and cut from the plans. When are you going to join up? When are you going to build a shiny model?
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
#743
IN
RE: WACO YMF
Yep, You are number 18. Let's all welcome Clay to the Brotherhood.
ChrisMH,
Bill, AMA 4720
WACO Brotherhood #1
ORIGINAL: ClayH
Clay
Clay
ChrisMH,
Bill, AMA 4720
WACO Brotherhood #1
I don't know if I deserve a number yet, since I don't actually have one...but I promise to build one So if you're offering, sure!
Chris
#744
My Feedback: (16)
BC, CANADA
RE: WACO YMF
Interplane struts, something that has not been talked about much. I had it all worked out in my mind, went and purchased the aluminum K&S streamline tubing got back to the shop pulled out the strut template and now I'm scratching my head. Can't weld it, can't rivet it, thought I could join it with ply, any good ideas out there? [:-]
#745
AZ
RE: WACO YMF
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
I'll reserve, if I may #47... again an ARMY Spec Ops thing... (MH-47E Chinnook). Yeah, not a biplane, albeit tandem rotor... but (very) BIG, BAD and SHINEY !... (well BIG anyways... and definitley BAD) And to think I am not even remotely interested in RC helo's...go figure.
I'll keep you guys posted when I get the plans for this smaller scale WACO.
Todd
#746
RE: WACO YMF
Mark
#748
RE: WACO YMF
Hughes 500,
This may (or may not) help but what I have done in the past is to use normal threaded wire for the strut ends (with steel quick links) hard soldered into the appropriate sized K&S brass tube on a jig so that you can set the lengths the same for the foward and rear struts. These can then have the streamlined tube slipped over them, ends of the ally tube slit, epoxy dribbled in and the tube ends folded in around the wires. the full `N' strut can be made this way, its adjustable and can be removed off the wing for maintenance. Compression and tension loads are then taken through the internal tubing and the outer streamline tube is just along for the ride. 1/5 biplanes can use 2.56 wire/links, 1/4 up will need 4.40 ditto.
Bill, your list has me down twice, pimmnz (or Evan) needs only #15, number 12 is still available.
Evan, WACO Brotherhood #15.
#749
RE: WACO YMF
Leave it to a Doggie (and a rotorhead at that) to want a number out of sequence...
Never let it be said that we don't accomodate everyone in here. Todd, you are #47. Tripp, you are #19, Clay is #18 and ChrisMH is #15 Let's all give these guys a hearty Welcome.
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
#750
RE: WACO YMF
Bill, AMA 4720
WACO Brotherhood #1
