Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
WACO YMF
Reply
Old 01-16-2007, 08:53 PM
  #876
Skinny Bob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: WACO YMF
yel914, I don't think you will find any 3-views of the QCF except from NASM. They charge .75/sq. ft. for copies of drawings and maybe plans that you can't preview. Other guys have said you might have to spend a lot of money to finally get what you want. I tried to find 3-views and or plans for the UBF which I beleive is the same as the QCF. If you find anything please let me know. I ran across these attatched drawings of the UCF, I don't know where they came from but they may help you if you are interested. I am tracing over them and working on drawing up plans for my UBF-2. I don't know if I can get the job done as I don't have any experience in this area. Sure going to try.
ID:	599713   Click image for larger version
Skinny Bob is offline
Old 01-16-2007, 09:08 PM
  #877
Stickbuilder
Stickbuilder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WacoOne,
I was referring to the ones that come with the kit. I'm thinking about using roof valley flashing aluminum, and making a buck, and forming the corrugations in the aluminum, and epoxying it into place. Probably time intensive, but it should look more scale like than anything else out there. This aluminum is really light, and easily formed. By the way, I ain't gonna beg you to take a number.
KHodges,
Dang, what's with all the grey????? I'm going to do the H-Stab trim on the next one as well. There will be a slight gap between the Stab and the fuse, but so does the full scale.
Bill, AMA 4720
WACO Brotherhood #1
Stickbuilder is offline
Old 01-16-2007, 09:41 PM
  #878
av8ter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Stickbuilder
Oh wise one and knower of all waco's
I wish to be on of the Waco brotherhood.
Larry
av8ter is offline
Old 01-16-2007, 09:48 PM
  #879
khodges
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Stickbuilder
KHodges,
Comes from worryin' about my airplanes, I guess. Better it should turn gray than turn loose.
From what I can see, even though the new WACO Classic is built under the same FAA type certificate as the original, there's lots of detail differences. I only have a couple of pics of original WACO's, most all of my YMF stuff is the new version, so I'm going to follow that in my model. There must have been some variants of even the new one; remember I posted a pic showing the rudder with an aerodynamic counterbalance? I found a couple with the straight hinge line, so I don't know for sure how I'll do mine yet. I think the H stab is a pretty doable thing, it sure will look good with that gap like the full scale has. I've got some carbon fiber tubing that will be perfect for that.
ID:	599746   Click image for larger version
khodges is offline
Old 01-16-2007, 09:54 PM
  #880
av8ter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: av8ter
Stickbuilder
I wish to be one of the Waco brotherhood.
What is the next number?
Pics of the soon to be resurected YMF
Larry
ID:	599753   Click image for larger version
av8ter is offline
Old 01-16-2007, 10:03 PM
  #881
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Okay, Here is the roster to date.
WACO BROTHERHOOD MEMBERSHIP:
#1 stickbuilder
#2 Hughes500E
#3 Jim Henley
#4 mmattockx
#5 CTflyboy
#6 michaelj2k
#7 Ronj10
#8 gwulle
#9 jim schroer
#10 Skinny Bob
#11 Bart5495
#12 Pimmnz
#13 HarryJ
No. 14 Old Git
#15 ChrisMH
#16 Nerevar
#17 Ricatic
#18 Clay H.
#19 Tripp2Loo
#20 KHodges
#21 Bill Hogue (WACO One)
#22 Mangolo (Waldo)
#23 av8ter
#24 yel914
#47 Todd (NightStalker)
Bill, AMA 4720
WACO Brotherhood #1
Wow. this is growing.
Bill, AMA 4720
WACO Brotherhood #1
Guys, I'm having to keep this page current, so bear with me for moving it forward.
Bill
[/quote]
[/quote]
Old 01-16-2007, 10:04 PM
  #882
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
av8ter,
You are herinafter to be known as ol' #23. Welcome to the WACO Brotherhood.
Bill, AMA 4720
WACO Brotherhood #1
We are now two dozen strong (and growing)
Old 01-16-2007, 10:05 PM
  #883
khodges
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh, I forgot about the dummy engine. Here are the pics. There are the cylinders, the front crankcase, and a ring that everything mounts to that has the pushrod tubes on it. The material is a hard plastic/resin. I find the front cover to be too deep, and I have to cut it out anyway for the prop shaft to fit through the hole. I'm hoping that I can mount it on a thin piece of ply and fit it against the Zenoah, with just enough cutout around the #4 and #5 cylinders to allow air to the G-26 cylinder. I will paint the barrels of the cylinders black, but leave the heads silver, and make a wiring loom with spark plug cables.
ID:	599757   Click image for larger version
ID:	599758   Click image for larger version
ID:	599759   Click image for larger version
ID:	599760   Click image for larger version
khodges is offline
Old 01-16-2007, 10:09 PM
  #884
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dang!!! I was already planning to do the next one with the counterbalance. Now this.... Naw, I've seen them both ways. I will (I think) add a little meat to the tail surfaces to replicate the tubing of the perimiter. I'm thinking about adding cap stripping to the wing ribs, and extending it over the L.E. sheeting to make it appear that the rib goes to the L.E. Tube. The more I think about the corrugated aileron surfaces, the better I like the idea of using flashing aluminum, and forming it into a buck to make the corrugations.
Bill, AMA 4720
WACO Brotherhood #1
Old 01-16-2007, 10:12 PM
  #885
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wonder if anyone ever made a scale version of the Jacobs 225? Lord, I don't want to have to do that...[:@]
Bill, AMA 4720
WACO Brotherhood #1
Old 01-16-2007, 10:23 PM
  #886
WacoOne
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[quote]ORIGINAL: Stickbuilder
WacoOne,
WacoOne is offline
Old 01-16-2007, 10:24 PM
  #887
Nightstalker
Nightstalker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
"Just like a Doggie to pick a number out of sequence (and a rotor-head at that)". Dang near half way to my # Larry... Story O' my life... always happens...
Welcome Larry #23, O' the Brotherhood.
See?... 'told you these guys are vey clickish and don't just let anybody in... good luck in getting any useful building tips out of these guys . They're more secretive than an ARMY Special Ops unit... (but their planes are shiny'er)
Todd (Nightstalker)
Doggie 47 - O' the WACO Brotherhood.
Nightstalker is offline
Old 01-16-2007, 10:25 PM
  #888
WacoOne
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Stickbuilder:
You already gave me a number last week! #21. It's in all my posts.
Bill Hogue
WACO Brotherhood #21
WacoOne is offline
Old 01-16-2007, 10:28 PM
  #889
Nightstalker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
He gotcha there, Bill - I'm keeping score cuz they're gainin' on me... I can run... but I can't hide.
Doggie 47
Old 01-16-2007, 11:19 PM
  #890
yel914
yel914's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sure Stickbuilder, I'll take a number. I don't plan on starting mine for a while yet-too many projects. I was thinking that I might build my YMF and try to cobble together plans for a QCF down the road. Thanks for the info!
yel914 is offline
Old 01-16-2007, 11:24 PM
  #891
Hughes500E
Hughes500E's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What kind of hinges you all plan on using ?
I can't get a good enough look on a full scale YMF to tell!
Thanx
PS
Need more pictures of you guys and a I'll post a real one of me
Hughes500E is offline
Old 01-17-2007, 05:58 AM
  #892
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
annnnnd, yel914 is now the proud holder of #24 Welcome.
Bill, AMA 4720
WACO Brotherhood #1
ps to NightStalker... You can't build a shiny airplane (it just ain't in you) Does the name, Ballard ring a bell?
Old 01-17-2007, 06:00 AM
  #893
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use only the Robart pin type (1/8") be sure to add a little more meat to the surfaces so they can gain some bite. I may give the DuBro pinned hinges a look as well, they would be a little more scale like (maybe) With the Robarts, you can do a small pocket, and they look very well.
Bill, AMA 4720
WACO Brotherhood #1
Old 01-17-2007, 07:37 AM
  #894
flyguy888
flyguy888's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
selfedit - not per topic
flyguy888 is offline
Old 01-17-2007, 10:29 AM
  #895
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ron,
I seriously doubt if they will allow that. Who would decide what was worth seeing, and what is not. This forum is kind of loose, and not at all like what you find on RC SCALEBUILDER, where the posts are pretty much sanitary, and therefore somewhat boring. I personally feel that a little lightheartedness is worth reading through here. Not a put down, but who would make these decisions. These guys are somewhat humerous, and quite frankly, I enjoy the bantering. Readers are capable of choosing what is of value to them and what is not. I really hope that I didn't step on your toes with this reply, but that is how I see it. You are welcome to take your position up with the moderators/administrators, but I don't think that they will see it as being nothing but an information thread. It is, after all a gang of guys that like the same airplanes, sitting around sharing information and shooting the bull. Enjoy,
Bill, AMA 4720
WACO Brotherhood #1
Old 01-17-2007, 11:49 AM
  #896
Hughes500E
Hughes500E's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ditto
This is a good thread, the only thing that bothers me is some of you guys can't build. Geesh, 2 cylinder, 3 cylinder engines, scale cockpits, flat wire, operating hatches, tail wheel suspensions, scale fuel fill valves, scale ailerons, adjustable scale Interplane struts, genuine Waco aircraft labels, come on guys lets take it up a notch
Old 01-17-2007, 12:17 PM
  #897
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Hughes500E
Ditto
That data plate is worthless. It has no information on it, so it ain't scale.
Bill, AMA 4720
WACO Brotherhood #1
Old 01-17-2007, 12:40 PM
  #898
Nightstalker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry Ron - Looking through this thread, the majority of my posts aren't on topic - just trying to lighten up the thread with funny stories or joking sarcisms. I'll watch it from now on.
Oh, and I am a Mfg. Engineer too (and tooling machinist) and have scrap metal / plastic etc. by the bucket loads that is perfect for modeling. So if you get overwhelmed with requests for a small hunk of metal or whatever, PM me. As long as it's going to a good cause and someone can't find it or justify spending a lot of money on something we are tossing out anyways.
Todd
p.s. Bill - shiney airplanes are one thing - but I can put a beautifully shiney finish on a hunk of metal (then I send it out for flat black anodise )
Old 01-17-2007, 12:45 PM
  #899
Hughes500E
Hughes500E's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll remove it.......................
Now if I only knew where to mount it [:-]
Old 01-17-2007, 03:05 PM
  #900
Ricatic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Brothers,
I too enjoy the banter on this thread. It keeps it interesting. Man can not spend all his time learning the finer arts of building scale Waco's. He would not have time to fly them. You artisans do fly?
Ricatic is offline
Reply
Display Modes
