WACO YMF
RE: WACO YMF
ORIGINAL: mrdhud
tmac
That would be great if you would share your method on how you did your frame. That is one of the things I would like to improve on mine. If your willing to be the teacher I’ll be your student.
ORIGINAL: tmac48
Greybeard & mrdhud,
Thanks for your comments but it is not really hard to do. I could run you through as to what I used & how to do it or if you still think it is beyond you then if you send me a profile of the size & shape of the 1/5 screen then I will have a go at them for you but they may not conform perfectly to the fuse. Payment,no, not worth trying to put a price on them, if they are any good & you can use them then good luck.
Regards tmac
Greybeard & mrdhud,
Regards tmac
RE: WACO YMF
Ok then let's have a go at trying to put to pen as to what I used & how I did it. The alloy is plain old ordinary alloy from the local hardware store, trace the out line of your screen frame onto the alloy(.5 mm thick) leaving about 10 mm extra width at bottom & sides to allow for the forming to the fuse. The outside cuts are the easiest ,just a deep scour with a stanley knife then a couple of bends on the edge of your table & presto,a good clean break. The centre cut outs are a lot harder, you just keep pasing the knife over the cut untill you get all the way through. ( I went through about 1/2 doz blades) The big piece of formed metal was used to do the forming on. Start with centre section then the sides. I clamped the sides between two pieces of timber then small bends at a time. You should be able to find something about the same diameter as your fuse that is hard enough (eg gas cylinder small & empty) to keep working on the shape untill you are happy with it. I used all the tools you see in the photos, small round bar, small ball peen hammer and a piece of soft timber.
All the best, any questions just ask & remember there is no such thing as a dumb question.
Regards tmac.
Regards tmac.
My Feedback: (19)
RE: WACO YMF
tmac,
You've obviously never had me asking too many questions around you.....I've come up with a few dumb questions in my day!!
LOL
Thanks for the excellent info, we're enjoying this....
~ Jim ~
LOL
~ Jim ~
My Feedback: (48)
RE: WACO YMF
tmac
Thanks for the great explanation and all the pictures. A picture is truly worth a thousand words. I’ll give her a shot this weekend.
RE: WACO YMF
Dan, We eagerly await the results of your efforts. Based on what I've seen of your work you should be able to pull this off.
TMAC, Yes, thank you for the explanation and pictures !
RE: WACO YMF
To all.
Just one observation to an excellent set of instructions.
To make the cut outs for the wind shield, use about a 1/8" drill bit for the corners. This will give you a nice radius to make it look more profesional
My Feedback: (48)
RE: WACO YMF
Well, here’s my first shot. OOPS one slip of the blade is all it took to file this one 13 LOL that’s all right I’ve got plenty aluminum. tmac you forgot to tell up not to slip LOL
My Feedback: (48)
RE: WACO YMF
ORIGINAL: aminiet
To all.
To make the cut outs for the wind shield, use about a 1/8'' drill bit for the corners. This will give you a nice radius to make it look more profesional
To all.
RE: WACO YMF
ORIGINAL: Neil K
Hi Fishinchickens, Can you post a picture of it? Im sure someone on here could identify what you have.
Neil K WB#142
Neil K WB#142
ON, CANADA
RE: WACO YMF
Thought I'd post an uodate on my Waco ARE. Here are a few pix. #1 Shows the fuse with stringers yet to be added on the top rear of the fuse. Also tops of the flaps will be sheeted with 1/64 ply - ailerons are fabric covered.
Pix #2 shows a front view with one of the "Grimes" style retractable landing lights in place and the F/G cowl just sitting there! Gear is made and needs to be sheeted
Pix #3 shows the scale tail wheel in place and Pix # 4 shows the detail. Made mainly of brake line tubing with steel plate for the wheel fork. SSoldered a 3/16" wheel collar for the shaft. Got the shock from the R/C auto section. It is a Duratrax DTXC - 9008 for the Losi-Mini T. I dug up stronger springs from the local hardware store. Had to mount two of them to get enough resistance. Think it will work fine. Steering wires and springs will come back from the rudder to the tail wheel horn as per the full size. Fun and games !!
SC
RE: WACO YMF
tmac,
Thanks for sharing your windscreen construction pics and instructions. I'm sure you just boosted the RC WACO communities skills a bunch!
David
WB#164
Fly low & slow
David
WB#164
Fly low & slow
My Feedback: (19)
RE: WACO YMF
A spring from an R/C car? I HATE those cars, but THAT is a stroke of genius! And finally a real good use for them...tearing them to pieces and using the parts to make our planes better.
Excuse me, I need to go now and put on my flame-proof suit....
LOL
~ Jim ~
LOL
~ Jim ~
ON, CANADA
RE: WACO YMF
ORIGINAL: RCplanman
JIM, HI, Looks good. Is that from DARIO'S plans? and if so how do you like them?..Bill
RE: WACO YMF
ORIGINAL: Stickbuilder
Great job on the windscreens. One of these days I'll do a how to on the ones that I build for mine.
Bill, Waco Brother #1
Regards tmac
RE: WACO YMF
It'll have to wait until I can get Janelle to shoot some photos of mine. It's fairly time intensive, and there are a lot of little bitty pieces involved.
RE: WACO YMF
tmac48,
These are what I have at the moment of the 1987 WCA YMF NC 14081. JFYI, the front wind screen on this plane is completely different, is removable for solo flying and folds up for storage.
P1 - Overhead shot of the rear cockpit wind screen
P2 - Side shot of the wind screen and Pilot/Owner Robin William and Passenger Debbie in the front seat.
P3 - Front wind screen on NC14081
RE: WACO YMF
Skylarkmk1
Thank you for the photos, that is exactly what I was looking for. Will have a go at the rear one first and post a photo of the result.
The front screen should be a piece of cake when I find some piano hinge the right size
Regards tmac
Will post a photo of the spats & covers in their final place.
Regards tmac
RE: WACO YMF
Y'all need to remember that there is a vast difference between what is found on the original YMF and the Waco Classic and super.
RE: WACO YMF
Yes Bill you are correct, but I'am a sort of scale builder,I like to have my models look scale and at the same time look pleasing to me all the while keeping in mind my limited ability at doing certain parts of the build. I always start out with great intentions but when the going gets too tough or frustrating I tend to compromise a fair bit. Having said all that I just like the look of the metal screen frames and that is what I would like to duplicate if I can do so in an acceptable manner. Hope you can make sense as to what I mean.
Regards tmac
PS still looking forward to your build info on your screens.
Regards tmac
SC
RE: WACO YMF
OK gents,
I've started my rebuild of the 1/6 scale I picked up at Perry & I'm going to need decals. Anyone know of a source where I can pick up a sheet for this project? Any/all help is appreciated.
David
WACO Brotherhood #164
Fly low & slow
David
Fly low & slow
RE: WACO YMF
Contact #116 Avaiojet (Charles). He can make you a set in any N number, color or style you want. It may take him a bit as I understand he just moved to Florida and may not be set up yet
