If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 43 of 756 FirstFirst ... 3341424344455393143543 ... LastLast
Results 1,051 to 1,075 of 18895
Thread: WACO YMF
  1. #1051
    Join Date
    Jul 2003
    newton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Here's more of the tailwheel assembly.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	608661   Click image for larger version.
ID:	608662   Click image for larger version.
ID:	608663   Click image for larger version.
ID:	608664   Click image for larger version.
    Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
  2. #1052
    Join Date
    Jul 2003
    newton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Now for the "finished" piece. When you look at the prototype, the post exits perpendicular to the bottom edge of the fuse. The way the kit tailwheel mounts, it "leans" forward. In order to get the angle correct, the black tailwheel mount must be shimmed. I used a wheel collar to get the angle I wanted, when I do the permanent mount, I'll make a wooden wedge to place on top of the black mount so that the tailwheel pivot is at the proper angle. The same mounting screw holes can still be used. The hole in the fiberglass fairing must be elongated to clear the post and the brace.
    It's obviously a heavier setup than the included one, but is lighter than you might think, because of all the solder and brass. The wheel is actually heavier than the entire bracket. Looks better than the one that comes with the ARF, don't you think?
ID:	608688   Click image for larger version.
ID:	608689   Click image for larger version.
  3. #1053
    Join Date
    Nov 2005
    Auckland, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Much better.
    Evan, WB #12.
  4. #1054
    Join Date
    Apr 2006
    Imlay City, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Jeesh, you guys do some amazing stuff. I like the new tailwheel a lot. If you guys keep it up, it could be easier to build the kit. Oh, I forgot, thats your goal.
    Ricatic
    Waco Brotherhood #17
  5. #1055
    Stickbuilder's Avatar
    Join Date
    Nov 2005
    Leesburg, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ORIGINAL: Ricatic
    Well, Now since you can get the plans from the AMA, and the parts for the build are posted right here, what's your excuse? Sheesh, you can even get the cowl from one of several companies, and the wheel pants as well. I'm doing a compression style sprung landing gear, and Khodges has come up with a tailwheel, I guess you'll have to build one.
    Bill, AMA 4720
    WACO Brotherhood #1
    Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
  6. #1056
    Join Date
    Nov 2005
    Leesburg, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Oh, forgot to post the gear drawing..... heh....heh The only thing that will be different is a longer threaded lug, and a compression spring under the nut.
    Bill, AMA 4720
    WACO Brotherhood #1
  7. #1057
    Join Date
    Nov 2005
    Leesburg, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    damifino, didja get the e-mail that I sentcha?
    Bill, AMA 4720
    WACO Brotherhood #1
  8. #1058
    damifino's Avatar
    Join Date
    Jul 2003
    Winston Salem, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    STICKBUILDER- I printed off pages 4 & 10 to see how they would come out. The 6" reference on page 10 printed 5 7/8" and the 3" ref. on page 4 printed out 2 31/32". Hopefully we can overcome this. I have not done the math yet but maybe the error is consistent and can be corrected with a copier set to enlarge 102.2% !! I know, I know! We can't do a tenth of a percentage point on a copier so 102% would suffice if the copier is capable, yes?
    Everybody knows you can\'\'t make a time machine out of a Tilt-A-Whirl.........-:WACO Brotherhood 25:-
  9. #1059
    Join Date
    Nov 2005
    Leesburg, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Maybe when I get to the website with ChrisMH, the thing will work as it's supposed to. Failing that, I can get all the pages copied, and send them snail mail. Of course, It could be because it's a jpeg file too. Is there another type of file that keeps the original dimension better?
    Bill, AMA 4720
    WACO Brotherhood #1
  10. #1060
    Join Date
    Jun 2003
    Mesa, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Here is the tailwheel I'm going to use on my Genesis Waco-YMF. Max dia 2 3/4", should be able to scale down to 1/5 scale.
    Harry J
    Waco Brotherhood Lucky #13
  11. #1061
    Join Date
    Jun 2003
    Mesa, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    OOOOOOOOOOooooooooooooooops....................... .didn't get image.
    Harry J
  12. #1062
    Join Date
    Nov 2005
    Leesburg, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ORIGINAL: HarryJ
    Durn show-off
    Bill, AMA 4720
    WACO Brotherhood #1
  13. #1063
    Join Date
    Jun 2003
    Mesa, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Still operating with one hand, not much better than two at times.
    Harry J
  14. #1064
    Join Date
    Jul 2003
    newton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    Master Chief-- If it's true that great minds think alike, could it also be true that Navy Chiefs and Air Force Lt.'s can do the same?
    I have been thinking of the exact same thing for my plane (your sprung main gear struts) almost down to the eraser marks on the drawings . It's amazing, and more than a little scary. I feel a lot better about it now, I guess it WILL work.
    Right now, my next change to the ARF will be the ailerons. The ARF's hinge in the middle, where the prototype's are top hinged. Since mine is gonna have a ton of differential, the small gap at the bottom of the aileron will be no problem. As you can see in the first pic, I filled in the "notch" on the top half and then sanded the hinge surface flat, at an angle to permit the surface to clear when the aileron is in the 'down" position. I'll also sheet the tops and bottoms with 1/64 ply and strip them with 0.080 in. styrene angles to make the corrugated surfaces. The prototype has 31 ribs per aileron (each surface), so it'll take a bunch of angles to do it.
    As the late, great, Jackie Gleason used to say, "And Awaaaay We Go!"
ID:	608918   Click image for larger version.
ID:	608919   Click image for larger version.
  15. #1065
    Join Date
    Apr 2005
    Calgary, AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ORIGINAL: Stickbuilder
    Bill, AMA 4720
    WACO Brotherhood #1
    Bill,
    For what you want to do a pdf is the best choice. Get the copies scanned at 100% and they can be printed at 100% with no issues on most printers. JPEG's will never give you a consistent scaling from page to page...
    Mark
    Waco Brotherhood #4
  16. #1066
    damifino's Avatar
    Join Date
    Jul 2003
    Winston Salem, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    #1- I got the e-mail. No problem making them, however, let me know Monday your thinking on the thickness. I'm thinking around .050 stainless. I'll knock the corners down so you won't get cut, OK?
    #2- Landing gear spring eye is no problem either, gimme a bolt size and I'll do up a couple of long ones so you can cut to lenth.
    #3- I can wait on the wood parts drawings. Hopefully the web page deal will work. If not, the USPS can bring them to me.
    Flew my Super Skybolt again today. Man, what a YS 110 FZ will do for a .60 size bipe. Can you say B A L L I S T I C ? She'll fly nice and slow with that 14 X 7 MA 3 blade prop. Point her straight up at half throttle and she goes pretty darn good, WFO and she becomes real small, real fast, rolling along the way if you want! I know it's an ARF, but I gave her a little soul by cutting a forward cockpit and building a new instrument panel/cowling for the pilot. The windscreens were cut from the stock, full canopy and a little scrap vinyl and pinheads make up the 'upholstery'. Scale appearing gear struts have since been added as well as a smoke system. The exhaust exits the bottom of the cowling in a scale location via the stock YS muffler screwed to a custom header I made.
    Also thrown in here is a picture of my modified Bruce Tharpe Venture 60 kit. I built-up and planked the foredeck and cowling, moved the cockpit back, clipped the wings, built the floats from a kit and scratch built the float struts, scale-like dual rudder steering and retract stuff. Flies real nice with a Saito .080.
ID:	608978   Click image for larger version.
ID:	608979   Click image for larger version.
ID:	608980   Click image for larger version.
ID:	608981   Click image for larger version.
  17. #1067
    Michaelj2k's Avatar
    Join Date
    Sep 2006
    Newark, DE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ORIGINAL: Hughes500E
    Looks good Jim,
    I must of overbuilt mine
    So I'm looking at the template you showed me and on my manual, page 39 shows the blisters in the exact same locations as my glass cowl in the pictures above. I am unsure as to why Pica would do this but if your guys' plans and templates are different than mine, then we found another difference in the age of these kits [:'(]
    That explains why my 1/6th is the same as this one as well, NUTS!
    Guys,
    If you look at the drawing of the blister locations Hughes500E posted in message #1042, you will see that the top of the cowl as indicated on the drawing is actually 180 degrees off. On a radial engine, the #1 cylinder is always at the top. So when mounting the cowl, make sure that the two blisters for the #1 cylinder are at the top and not the bottom as indicated by the drawing.
    "He's crazy Lew, he builds toy airplanes!"
    Frank Towns - Flight of the Phoenix (1965)
  18. #1068
    ChrisMH's Avatar
    Join Date
    Aug 2006
    Fort Wayne, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    To: CHRISMH,
    I have the fuselage parts traced, and ready to send to you for posting on the website. I need your e-mail address since I cannot e-mail a website. The first posting has 16 pages of full size parts. Each page has a size reference drawn. If it does not copy at the size indicated, you will need to correct the part before cutting. All parts show the dimension of the material, and also the kind/s of material used. The modification/s for using a radial mount are indicated, as is the stock part configuration for those who wish to use the Maple engine bearers. Also the provisions for making the tank a rear loader are shown as well. This is a major undertaking, and I sure hope that some of you build one. It was worth the time spent. This one won't die.
    Bill,
    AMA 4720
    WACO Brotherhood #1
    Sorry, Bill, didn't touch the Internet over the weekend
    Send anything you want posted to: hogancm@gmail.com and I'll put it up right quick!
    Chris
    WACO Brotherhood #15
    Chris Hogan
    WACO Brotherhood #15 - http://www.houseofmoy.com/waco
  19. #1069
    Join Date
    Jul 2003
    newton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ORIGINAL: Michaelj2k
    Guys,
    I think that is an illusion; if you considered the blisters that are closer together as a cylinder pair, then you're right, but it's actually the blisters that are further away from each other that constitute a cylinder pair. Most all the pictures I have of YMF's all show the blisters essentially the same distance apart all around the cowl. It would actually depend on the model, and the engine used, as to the proper spacing of the valve blisters, and the Jake's valve train is fairly evenly spaced.
  20. #1070
    Hughes500E's Avatar
    Join Date
    Nov 2002
    Armstrong, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    That's the whole idea of my post:
    in order to build this Pica model scale, you have to use the Cowl with the grouped blisters like the picture I posted.
    This Pica model is scaled after the Waco YMF-3 NC-14031
    If you want it to be scale and use blisters that are spaced equally all the way around, don't use the #'s NC-14031 on it.
    As far as I know there are only two kits available, the blue one and the red and white one.
    I know about the blue one and I just bought a kit of the red and white one. I was hoping the #'s were different but it too is NC-14031
    Anyone have a kit or a set of plans with different #'s??????
  21. #1071
    flyguy888's Avatar
    Join Date
    Nov 2004
    coon rapids, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    I just pulled up som pics of the NC-14031 and in the pictures it shows both types of blister layout. The oldest black and white photos show equal spacing, the newer color ones show grouped. Obviously it was fitted with a different cowl at some point because maybe it had a different engine put in or somthin. Point being if the full scale had different ones you can't go wrong having one or the other.
    http://www.nationalwacoclub.com/f3f5album/
    If you love to build you have to pay the price
    Waco Brother #7
  22. #1072
    Join Date
    Nov 2005
    Leesburg, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ORIGINAL: ChrisMH
    Chris
    Okay Chris, Yo now have the e-,ailed parts tracings. Let's see what you can do with them....[8D]
    Bill, AMA 4720
    WACO Brotherhood #1
  23. #1073
    Join Date
    Nov 2005
    Leesburg, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ORIGINAL: khodges
    And as the late (Greater) John Wayne once said,........."NOT HARDLY"!!!
    The very Idea an Air Scout Butter Bar, in the same general area of a Master Chief, and one who was Chief of the Boat as well.....The very idea.....
    Bill, AMA 4720
    WACO Brotherhood #1
  24. #1074
    Join Date
    Nov 2005
    Leesburg, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    ORIGINAL: khodges
    Khodges,
    I just printed the photo of the, "Shaky Jake", and checked the spacing on the rocker boxes. On the Jacobs engine the rocker boxes are spaced dead on evenly both between cylinders and on the same sylinders. It would then follow that the YMF cowl had the blisters evenly spaced, while the UMF would have used the paired blisters. I can't see where it would make a great difference, since this is at best a stand-off scale model. Pica stated that they did not have to deviate from the scale outline, but there are enough items where ease of building would preclude this from ever being a Top Gun caliber model. Please, let's not have a general falling out over anything as trivial as this. Me? I like them both.
    Bill, AMA 4720
    WACO Brotherhood #1
  25. #1075
    Hughes500E's Avatar
    Join Date
    Nov 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: WACO YMF
    I'm not sure the conversation would turn negative, it's important, however, I do stand corrected in light of the above, many thanks.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
