Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
WACO YMF
Old 04-17-2012, 09:20 AM
  #14651
ceije
Default RE: WACO YMF
tmac48
your wings look super, i only hope mine come out half as good. what did you use for a base coat i plain to shoot a thin coat of auto primer and then a light wet block sand. keep up the good work, can't wait to see the final product.
regards,
chris melhus ceije 196
Old 04-17-2012, 03:05 PM
  #14652
tmac48
tmac48's Avatar
ORIGINAL: ceije
tmac48
regards,
ceije
Nothing special about the base coat, automotive 2k primer. dry sanded 220 then 400 then scotch brite a lot of sanding time but I fond it rather difficult to fill all the weave in the sig Coverall, I reckon I would have applied at least six coats of dope, some mixed with talcum powder and still ended up with a few pin holes after the base coat (primer). Will post a photo after spraying the top coat.
Regards tmac.
Old 04-17-2012, 03:17 PM
  #14653
aminiet
aminiet's Avatar
I got this picture from facebook. Does any one knows which ship it is
Old 04-17-2012, 04:29 PM
  #14654
WacoNut
WacoNut's Avatar
It is "Discovery"
Old 04-21-2012, 01:02 PM
  #14655
Stickbuilder
Stickbuilder's Avatar
Been at the drafting table today. I wanted to do the ribs by the composite method, and so they shall be. Tuning wires inside the wing and all. It's gonna be a beast to build, but it will be scale.
Bill, Waco Brother #1
Old 04-21-2012, 03:36 PM
  #14656
tmac48
tmac48's Avatar
ORIGINAL: Stickbuilder
Bill, sounds like an interesting build, please keep us up to date with your progress and don't forget we all like to see plenty of photos.
regards tmac.
I was going to leave the alloy panels in the natural finish but decided to paint instead, a photo in the primed state.
Old 04-21-2012, 08:18 PM
  #14657
alpwd2
Thanks for the reply Chris, I seen the posts (571) and I did go to the Centryjet site and boy that landing gear is expensive. I think I'll pass on that, I can buy Two WACOS for that price ($615) buckaroos, WOW.
Regards AL (AMA # 1295
Old 04-23-2012, 10:18 PM
  #14658
tmac48
tmac48's Avatar
To all. Had a friend who owns a metal spinning shop spin me up an alloy nose ring.
ID:	1754217   Click image for larger version
ID:	1754218   Click image for larger version
ID:	1754219   Click image for larger version
ID:	1754220   Click image for larger version
ID:	1754221   Click image for larger version
ID:	1754222   Click image for larger version
ID:	1754223   Click image for larger version
Old 04-24-2012, 02:29 AM
  #14659
Errol Levin
Errol Levin's Avatar
Hi tmac and everyone else
One of my buddies at the flying club had some louvers that he bought in the U.K. years ago. He gave me some which were perfect. I have made up a panel with them for my Waco.
Thanks anyway for all the help and advice you guys gave.
Old 04-24-2012, 05:29 AM
  #14660
Jaybird
The detail work on these kit built WACO's is amazing!
I've gotten a little further with my Great Planes ARF version. I've had fun using some small screw sets from the E-flite Blade series of helicopters to add some detail and to aid in mounting the fiberglass lower wing fairings. They were rather misshapped and I had to work hard to get them to conform to the fuselage sides. I added covering to the ends of the lower wing saddle and painted the slot where the landing gear mounts. I've used the Robart control horns on the upper ailerons and plan to use them on the top wing and tail.
Next comes the final motor installation and pushrods for the tail. I'm going to make the top wing panels removable from the center section with a slight variation of what I have seen done. I've cut a second servo extension slot on the right side of the fuselage to run the cable up the cabane strut and another hole in the bottom of the center section.
I'd like to make the hand holds in the trailing edge of the center section but I'm not sure if it's solid balsa at that point or hollow.
Hope to break in the motor this weekend and fly the following if weather allows.
Jaybird
ID:	1754313   Click image for larger version
ID:	1754314   Click image for larger version
ID:	1754315   Click image for larger version
ID:	1754316   Click image for larger version
Old 04-24-2012, 06:34 AM
  #14661
Truckracer
My Feedback: (19)
Cowl Trim Painting?
Sorry for butting in here but this thread clearly has a good mix of builders so I thought I'd ask a question. I searched the thread for the answer but after some time didn't find the info I needed.
What are most of you doing for trim on the cowl bumps? Freehand masking and paint, stencils and paint, vinyl graphics, etc? I have (2) projects going and I'm looking for a process that is repeatable. I can freehand one time but reproducing it 14 times is a problem! Any help would be appreciated! If I missed the info in my search perhaps you could redirect me.
Oh yes, the projects are an old Pica Waco and a Ikon NW D145 Moncoupe. I like to say that I'm "scratch building" them from the kits as it seems like there is more redesign than original kit! The paint used is automotive basecoat / clearcoat.
Thanks for any help!
Old 04-24-2012, 01:17 PM
  #14662
ceije
FMBB
Peter,
Errol Levin and I have been back and forth about the aileron counter weights in your 1/4 scale YMF kit. Are they necessary, we understand they are for flutter control. We are of the thought process that if a strong enough servo is used or a 4 servo system they would not be necessary. If they are installed I realize one end attaches to the aileron, does the other end just free float in the wing?? The kit design is yours so were asking for your views. Please advise.
I understand your view about 4 servos not being a necessaity and your stand on building light due to the weight limits in Germany.
While I'm here, I have asked before I still would like to purchase a second cowl for emergencies, do you have any means of selling replacement parts for repairs/maintainence or are we ( those who have purchased kits) out of luck and have to buy another kit to do so. I know you provide missing parts as necessary.
regards,
Chris Melhus, ceije 196
Old 04-24-2012, 01:59 PM
  #14663
tmac48
tmac48's Avatar
ceije, Peter will supply any part that you wish to order, he has all the parts listed on his web site. You can quote the relevant part no and he will follow up very quickly. I have obtained extra pieces from him for my WACO in the past and found Peter to be most helpful and prompt.
Regards tmac. PS I did not install the counter weights but did install 4 servos.
Old 04-24-2012, 02:21 PM
  #14664
tmac48
tmac48's Avatar
ORIGINAL: Errol Levin
They look good mate, post some photos of your build, I love photos of the model while under construction. I ended up going with these.
Old 04-24-2012, 02:27 PM
  #14665
tmac48
tmac48's Avatar
truckracer I have not got to the painting of the cowl bumps yet,but can see that it will be a pain in $ss. Would be interested to hear what method others have used as well.
regards tmac .
Old 04-24-2012, 05:11 PM
  #14666
ceije
tmac48,
thanks for the information, i'll contact him via his e-mail and go from there.
regards chris melhus,ceije 196
Old 04-24-2012, 05:27 PM
  #14667
WacoNut
WacoNut's Avatar
I masked my 1/4 and 1/3 scale cowl bumps and painted then trimmed the paint with 1/16" 3M automotive pinstriping tape. This may look too large for a 1/6 or 1/5 scale cowl.
Later!!
Anthony
Old 04-24-2012, 08:28 PM
  #14668
tmac48
tmac48's Avatar
ORIGINAL: WacoNut
I masked my 1/4 and 1/3 scale cowl bumps and painted then trimmed the paint with 1/16'' 3M automotive pinstriping tape. This may look too large for a 1/6 or 1/5 scale cowl.
Later!!
Anthony
G,day Nut, could you post some close-up photos of your cowl?
Regards tmac.
Old 04-25-2012, 03:41 PM
  #14669
WacoNut
WacoNut's Avatar
Hi Tmac,
I went down and snapped a few shots. It is a bit dark in the room I have the plane stored in.
I sprayed the cowl white then masked the white areas and sprayed the Insignia Blue. The edges were trimmed with gold 1/16" pinstripe tape.
Later!!
Anthony
ID:	1754962   Click image for larger version
ID:	1754963   Click image for larger version
Old 04-25-2012, 11:19 PM
  #14670
tmac48
tmac48's Avatar
Thanks Nut, good job,hope I can do as well.
Regards tmac
Old 04-26-2012, 04:21 AM
  #14671
Errol Levin
Hi tmac
As requested here are some pics of my Waco.
Basically I am ready to cover the fuselage, so I am busy making all the panels as well and providing sturdy places to screw them all in place. Most of the electrics is done in a modular fashion and color coded so they can just be plugged together. All the servo trays, fuel tank tray etc. are all removable individually as well. The wings are ready for final sanding, all the struts are made, so basically I have dozens of pieces, but from hereon it just assembling and then painting.
Regards
ERROL #204
ID:	1755148   Click image for larger version
ID:	1755149   Click image for larger version
ID:	1755150   Click image for larger version
ID:	1755151   Click image for larger version
ID:	1755152   Click image for larger version
ID:	1755153   Click image for larger version
Old 04-26-2012, 06:47 AM
  #14672
tmac48
tmac48's Avatar
Errol, real neat work, good shots of your building skills, post more photos when you can. Real envious of your dash panel,I think I can recognize it as the one supplied from Voglesang is this correct?
regards tmac.( PS what motor are you going to use?)
Old 04-26-2012, 07:38 AM
  #14673
Errol Levin
Hi tmac48
Yes the dash is from Vogelsang. Pricy but very nice. I could never make it so well. I am using a Saito 5 cylinder radial with a custom Kelio collector ring exhaust. Should have sufficient power. Unfortunately it is a glow engine. The Moki engine would not fit in the cowl.
Regards
ERROL #204
ID:	1755200   Click image for larger version
Old 04-26-2012, 11:15 AM
  #14674
Truckracer
My Feedback: (19)
ORIGINAL: WacoNut
Hi Tmac,
I sprayed the cowl white then masked the white areas and sprayed the Insignia Blue. The edges were trimmed with gold 1/16'' pinstripe tape.
Later!!
Anthony
Very nice! I'm not sure I have the patience or talent to duplicate that sort of thing 14 times on a cowl. I guess I'll have to give it a try though. Has anyone tried vinyl stencils. These would at least provide a consistent pattern (paint mask) for the basic decoration shape. Then pinstripe tape could be used for the outline followed by a clear coat for protection / appearance.
Old 04-26-2012, 01:47 PM
  #14675
WacoNut
WacoNut's Avatar
The probelm with a mask is the blister is full of compound curves. A real nighmare to apply a stencil. I tried[&o] I wound up just maskig each one individually.
Later!!
Anthony
