WACO YMF
BC, CANADA
RE: WACO YMF
ORIGINAL: mrdhud
Dave will we be see that big green Waco again this year?
See you all there.
Cheers,
Dave.
W/B #180
RE: WACO YMF
HI guys,
I'm thinking about ordering the 1/5 scale Pinked tape that Mick Reeves sells. It's the correct width for two inch tape with the correct number of pinked point per inch. Only problem I can possibly see it's is made from the Iron on solartex fabric he sells, and I would be appling it over a doped (three coats of Nitrate) Koveral surface. My question is this: will ironing this material over the doped fabric cause any problems? As for the rib stitches, I may use the wood glue (like doing rivits) over the ribs prior to adding the tape. Would the heat cause a problem with white glue?
Another way to do the rib stitching would be to lace heavy thread over a piece of fabric ( at the propper spacing of course), and dope it down, and then cut it into strips the width of the ribs and dope it to the fabric prior to doing the pinked tape.
Comments, warnings, etc., appreciated.
Joe
RE: WACO YMF
I have used solartex tapes over Koverall and it is not an issue. I get my tapes from Gary Siebert at Pink-it.net He offers them in many sizes.
You will want to seal the edges of the tape down after you get them applied. I usually use Polycrylic for filling the weave of the fabric and I give it another coat after the tapes are applied.
For Rib Stitching I get them from Scale Rib Stitch.
Later!!
Anthony
Later!!
Anthony
RE: WACO YMF
ORIGINAL: mrdhud
Bill,
Glade to see your Waco back on the work bench. The cabanes look good. Monster planes is coming up soon will you & Janelle be coming down? Hope so.
Any one else planning on attending monster planes this year? Dave will we be see that big green Waco again this year?
Bill,
Bill, Waco Brother #1
RE: WACO YMF
Hi Guys
Busy covering now with Solartex. What a pleasure! The best covering material I have used. Pink it and scale ribstitch also the best in the market.
ERROL #204
ERROL #204
RE: WACO YMF
I'm having a tough time deciding what to work on. I'm torn between the Ryan ST-A and the Waco. Maybe a little here, and a little there.
My Feedback: (9)
RE: WACO YMF
Hey Bill, you and I have the same dilemma! I too am torn between the Waco and a Ryan STA. I have the Pica 1/6 Waco kit, and have a Technopower radial to go in it (though it is currently pulled apart for repair). But I also just bought a 1/4 scale Ryan STA kit, and have an O.S. IL300 that might find a home up the front of it. I actually now have 4 Ryans. I have an old SIG Ryan that I am converting from STA to STM-S2 (all polished metal), a Great Planes Ryan ARF (currently with busted wing, and out of action), a spare SIG Ryan kit in box, and now the 1/4 scale kit. As you might be able to tell, I am a Ryan fan!!
If you need any Ryan photos, I have a bunch that I took of the Temora Aviation Museum's Ryan STM-S2 here in Australia.
James.
James.
RE: WACO YMF
ORIGINAL: jymster
James.
James.
RE: WACO YMF
ORIGINAL: jymster
Looks good Bill. Yes I saw this on another thread on the Ryan. How scale is the Byron kit? Any obvious errors?
RE: WACO YMF
Hi Bill, I've been flying a Byron ST for years with a St2500 glo (ugh) on the stock firewall and the disc and tube mount...no problems. Mitch WB100
RE: WACO YMF
ORIGINAL: nine o nine
RE: WACO YMF
The more I work on these wings for the Ryan, the less I like them. Grrrrr. I really hate fixing what someone else designed. They would be just okay for flying, but to make them ding proof and more scale takes more time than it would to frame a set up.
RE: WACO YMF
Bill,
A local guy is building a 1/2 scale version. He showed me some pics during our Father's Day Fly-In at our club field. Nice looking plane. He also sells plans for a .60 size, 1/4 and 1/3 scale. Here is a link to his web site if interested. [link=http://www.alien-aircraft.com/ryansta.html]Alien-Aircraft[/link]
I still plan on building a giant STA one of these days. My work is sending me to CAD classes next month. I want to do a full design in CAD including scale struts.
Later!!
Anthony
Later!!
Anthony
RE: WACO YMF
Anthony, this one is a quarter scale version. The struts are about the only thing on the wing that Byron did right.
By the way, did Ryan use landing light/s on the ST-A, and did they use any Navigation lights. I am having a problem finding any photographic evidence of either.
RE: WACO YMF
The YPT-16 Army version at the Wright-Patt museum does not have any lights. If you are going to model a military version then I would not add lights.
Banned
RE: WACO YMF
I have a copy of Profile Publications #158, The Ryan PT/ST series, and nothing in that publication shows any lights. I find no copywrite date, but it is quite old.
Les
Les
RE: WACO YMF
Hi Guys
Just to get back to the subject of Waco's, I've been busy today doing the tapes on my tail feathers. Have a look.
Regards
Errol #204
Regards
Errol #204
RE: WACO YMF
ORIGINAL: rccrasher65
Joe what is the thickness of the brass sheet, you used for your fittings, thanks George
I'm sorry I took so long to answer this one. I just noticed it when it popped up when the page opened. I don't know how iI missed it when it first came up.
The fittings in the aircraft structure, both the wings and fuselage, are from the K &SBrass and Ithink they were about .032". It may be overkill, but I was just being sure. The fittings on the ends of my N-Struts were made by wrapping a thinner piece of brass around a 1/8" hard brass tubing. I think thery were done with .016" brass and that assembly was soldered to the heavier piece that went into the end of the N-Strut. If that is confusing, let me know.
Joe
My Feedback: (35)
RE: WACO YMF
Thanks Joe, just wanted the thickness of the brass sheet stock. I have your pictures from the earlier posts, pretty straight foreward, if I have any questiions I will be sure to ask, Thanks again for all your help. I haven't been on very much lately, but getting back to full build soon. I have two on the boards, My 1/5 WACO YMF, and a Brian Taylor Messerschmitt 109 F, keeping me pretty busy, bouncing back and forth. George
