Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
WACO YMF
Old 12-11-2012, 08:15 AM
  #15751
skylarkmk1
skylarkmk1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: WACO YMF
Joe,
If you have the proper shears (scissors) with the correct "pinked" spacing you can cut your own biased tapes from the covering fabric, just cut at 45° to the weave. The tough part is cutting the tape with parallel sides.
In the photo of the wing the tip tape starts at the transition from straight to curve (in this case at the marker light base) around to the trailing edge.
skylarkmk1 is offline
Old 12-11-2012, 08:28 AM
  #15752
Dash7ATP
Dash7ATP's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John,
Idon't have any pinking shears. The tape I'm using actually has 25 pinks to the inch (1/5 scale). They may not even show up once I'm finished. I jut hope the Solar Tex tape has enough stretch and shrink to form to the curves. We'll see.
Joe
Dash7ATP is offline
Old 12-11-2012, 11:02 AM
  #15753
nine o nine
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Joe, Don't try to fill the pinked edges. If you scaled down from the full scale you could never them. On my 1/3d I tried to leave the pinks showing as well as the rib stitching and the craftsmanship judge at TopGun remarked about the good surface detail.
BTW I used automotive basecoat clearcoat for a very shiny surface dirctly over the Solartex so the weave peeked through on close inspection. Mitch WB100
nine o nine is offline
Old 12-11-2012, 12:22 PM
  #15754
Dash7ATP
Dash7ATP's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Mitch,
Thanks for the tips!Maybe I won't put so much dope on this baby after all. I'm guessing I will need at least three coats on the stitching, just to seal it good. The big difference is I'm using Koverall for my covering rather than the Solartex, so it does need filing where the Solartex needs very little if any.
Joe
Dash7ATP is offline
Old 12-11-2012, 01:44 PM
  #15755
nine o nine
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, you're right that the Koverall needs filling more than the Solartex. Don't try to get a shiny filled dope finish though. Mitch
Old 12-11-2012, 10:48 PM
  #15756
skylarkmk1
skylarkmk1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Guys,
Over in the Don Smith Cessna T-50 thread, rhsmrt50 is building a1/5th scale Jacobs engine (dummy, resin cast) that has others beat hands down. Take a look starting about post 792 http://www.rcuniverse.com/forum/m_10...32/key_/tm.htm and check it out. Pay attention to post 831.
Old 12-12-2012, 06:02 AM
  #15757
Dash7ATP
Dash7ATP's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
His dummy Jacobs is a work of art!
Joe
Dash7ATP is offline
Old 12-12-2012, 04:24 PM
  #15758
Jim Henley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes it is, the detail is simply fantastic, wonder if one would work in front of a 30 .cc Syssa
Jim Henley is offline
Old 12-12-2012, 05:14 PM
  #15759
chuck l
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have to put 14 screws in the a wheel fairing cover for third scale Waco. Any ideas of a simple way to evenly space the holes around the perimeter of the part?
Chuck
chuck l is offline
Old 12-12-2012, 05:29 PM
  #15760
jymster
jymster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Chuck, why don't you use a piece of string, or other flexible strand, and measure the circumference of the shape. Then divide this measurement into 14. Then place marks at the appropriate spacing on the string and wrap it back around the faring to transpose the marks onto the fairing.
James.
jymster is offline
Old 12-12-2012, 07:23 PM
  #15761
chuck l
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
James,
Thanks for the suggestion. About ten minutes after posting the question, I ran a piece of masking tape around the perimeter and marked the spaces on that. Just what you suggested, but with tape.
Chuck
chuck l is offline
Old 12-12-2012, 08:05 PM
  #15762
johnboy151a
johnboy151a's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You could find a known start point and walk off the distance of each screw with a set of Dividers. No different then walking off Rivet pitch on a full scale sheet metal repair.
Just my 2 cents.....
johnboy151a is offline
Old 12-12-2012, 08:15 PM
  #15763
jymster
jymster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: johnboy151a
Good idea, except that you need a way to find out what the distance between the screws is first. You could use the string/tape method, followed by the dividers.
James.
jymster is offline
Old 12-13-2012, 12:09 PM
  #15764
VOX
VOX's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello,
Some new photos ... These two small forms I need to do first.
Albert
ID:	1829607   Click image for larger version
ID:	1829608   Click image for larger version
ID:	1829609   Click image for larger version
ID:	1829610   Click image for larger version
ID:	1829611   Click image for larger version
ID:	1829612   Click image for larger version
ID:	1829613   Click image for larger version
VOX is offline
Old 12-13-2012, 02:46 PM
  #15765
jymster
jymster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking good, Albert. I assume this will be available as a kit some day soon?
James.
jymster is offline
Old 12-13-2012, 04:47 PM
  #15766
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I finally ordered my parts from AMR to rebuild my Waco. After looking it over and talking it over with Dany from AMR it was deemed necessary to build a new fuse. Too much structural damage in critical strength areas to attemp a repair. I had Dany cut me new fuse parts and ship me a new cowling. I should have all the parts in hand around the Holidays. I hate building something twice but the Waco was just too nice to scrap out.
The rebuild will not take that long but the covering and detailing will be a stretch to get it all completed before spring.
Later!!
Anthony
WacoNut is offline
Old 12-13-2012, 05:05 PM
  #15767
johnboy151a
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: jymster
James.
When I was still doing Sheet Metal repairer on Army Aircraft, all I needed was the starting point. You stated that you want 14 screws to hold the fairing, so find the point you want to start and walk the dividers 14 times. Adjust the distance to make it walk the pitch in or out until you have your 14 points and end up back at the point you started.
Old 12-13-2012, 05:33 PM
  #15768
jymster
jymster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, will also work, but a lot of trial and error involved. Whatever works, I say.
James.
jymster is offline
Old 12-14-2012, 05:48 PM
  #15769
mrdhud
mrdhud's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anthony,
Glad to see you getting the Waco repaired. Hopefully it will go easy & fast for ya. I know you painted your Waco with latex paint but did you clear coat it and if so what did you use. I have a plane covered with solortex that need to be sealed with some thing.
mrdhud is offline
Old 12-15-2012, 01:45 AM
  #15770
Stickbuilder
Stickbuilder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: mrdhud
Anthony,
Dan, Don't forget about weight. Filling weave really put's on the pounds.
Bill, Waco Brother #1
Stickbuilder is offline
Old 12-15-2012, 01:47 AM
  #15771
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm trying to come up with a way to seal Koverall that remains light. I'm thinking about using Minnwax Polycryl. It is water based, and once the water evaporates, it should be fairly light. Comments?
Old 12-15-2012, 01:48 AM
  #15772
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Okay, Here is the roster to date.
WACO BROTHERHOOD MEMBERSHIP:
#1 stickbuilder
#2 Hughes500
#3 Jim Henley
#4 mmattockx
#5 CTflyboy
#6 michaelj2k
#7 Ronj10
#8 gwulle
#9 jim schroer
#10 Skinny Bob
#11 Doug
#12 Pimmnz
#13 HarryJ
No. 14 Old Git
#15 ChrisMH
#16 Nerevar
#17 Ricatic
#18 Clay H.
#19 Tripp2Loo
#20 KHodges
#21 Bill Hogue (WACO One)
#22 Mangolo (Waldo)
#23 av8ter
#24 yel914 (Rick)
#25 damifino
#26 skylarkmk1
#27 Jacque
#28 Edwin
#29 AROPLANE
#30 WacoNut (Anthony)
#31 BQuartucy (Bob Q)
#32 AERORON
#33 funkymusic
#34 Live Wire (Larry)
#35 obo (Bob)
#36 Jackk36 (Jack)
#37 fatherrooster (Jim)
#38 Ilikebipes
#39 Kestrel0222
#40 CROWMAN17 (Marc)
#41 redcesar
#42 S. Christensen (Scott)
#43 Bill Deidrich
#44 Mike Barbee
#45 mrdhud (Dan Hudson)
#46 SoCalSal
#47 Todd (NightStalker)
#48 argon (Bob Gonzalez)
#49 mango 12 (Scott)
#50 skyjet 1
#51 ZIG
#52 Didg
#53 MarvinE255 (DOC)
#54 Joe Norris (Full Scale WACO Pilot)
#55 vasek
#56 SuperCub Man (Jim)
#57 Black Drape (Ron)
#58 aminiet (Angel Minet)
#59 Snowball
#60 doc zinger
#61 jagnweiner (Scott)
#62 Meesh (Bob)
#63 BigBoy99 (Bernie)
#64 stifts (Steve)
#65 RCWalker (Wallace)
#66 Mobyal
#67 lazyace
#68 bladerunner1955 (Don)
#69 trlambsr
#70 Big Bird (Ken)
#71 Tony V (Tony)
#72 red 1
#73 412t1 (Sean)
#74 Mr Lucky (Ben Warner)
#75 RICKSTUBBZ (Rick Stubblefield)
#76 ffdg (Fred)
#77 tomcraig
#78 Michou41a Michel
#79 Watzscale (Dick Watz)
#80 Devens
#81 msilvestro (Mark)
#82 Cheechukranch (Lewis)
#83 kruzin55 (Chris)
#84 lynchr (Ron)
#85 airplanegeek
#86 TexasSkyPilot
#87 Garthwood (Charles)
#88 RCBOATMANIAC (Dave)
#89 Thomas B
#90 George Werber
#91 frequent flyer (Don)
#92 adamiani Alex
#93 Kvlasblom
#94 geertdewit (Geert)
#95 Wobble Wing (Bud Halverson)
#96 Joe Gulik
#97 T.L.A.R.eng
#98 kurrikan
#99 Nathan King
#100 nine o nine (Mitch Epstein)
#101 dsquire (Don)
#102 Mr. WACO (Charlie Nelson)
#103 Ken Acosta
#104 denoferth (Dennis)
#105 germrb (Bob Germaine)
#106 J.D. Ramsay
#107 ccrebidoux (Chris)
#108 LarryN (Larry)
#109 X3heimmr (Marty Heim)
#110 Lou Melancon
#111 BEARMX (Barry Waters)
#112 Sir Crashalot (Bob J)
#113 RPSBLS (Bob)
#114 Squeakalong (No name given)
#115 Uminchu (Dave)
#116 Avaiojet (Charles)
#117 Mud Duck (Shaun)
#118 XTRA230 (Rob)
#119 3drc tim
#120 Cubman
#121 Ekim (Mike)
#122 tom czenthe (Mr. Tom)
#123 curt switzer (Mr. Curt)
#124 bbogart (Bruce)
#125 skypup50
#126 RCplanman
#127 froghair1
#128 lrayj (Lonnie)
#129 codiddley
#130 king arthur 1953 (Ron)
#131 sdstick06 (Shawn)
#132 hopkimf (Michael Hopkins)
#133 Cricklewood (Chris Kerrigan)
#134 montiu
#135 carbunkle
#136 Wolfinwisc
#137 mamoose124 (Mike)
#138 pbunster (Paul)
#139 Paul of the North (Paul)
#140 eagledancer (Todd Bixby)
#141 Cottco RC
#142 Neil K (Neil Kilchriste)
#143 Aerowoof
#144 Phlip (Phil Duncan)
#145 flyinjay (Mark)
#146 Cursor (Rick Allison)
#147 Teus
#148 Steve Percifield
#149 rootsgroup
#150 johnboy151A (John Shrick)
#151 georgewaldrop (George Waldrop)
#152 rkflyingboats (Bob)
#153 reyn3545 (Mike Reynolds)
#154 PanHeadAndy
#155 Amscat (Andy)
#156 Skipb (Skip)
#157 Dirtydingus (Jim)
#158 cdbarker (Carl Barker)
#159 TJDNC (Thomas Dugan)
#160 Gunner3 (Bob Faetsch)
#161 fishinchickens (Neil Abbot)
#162 pittsdriver (Don)
#163 rc wings (Marko)
#164 greybeardaviation
#165 tokpilot
#166 davivgeorge212 (David G)
#167 lanny haff
#168 Dick Pettit
#169 abergmann
#170 FMBB Peter Barth
#171 Redbiscuits (Gary)
#172 ross felix
#173 biplano (Oscar Aitken)
#174 RBACONS
#175 flightstick (Gary)
#176 Mark Wolf
#177 paulemv (Paul T. VanDenburgh)
#178 scubajohn
#179 jerry325i (Jerry)
#180 mogman (Dave)
#181 DRCRAIG (Craig
#182 JRM23 (John)
#183 jn4dflyer (Larry)
#184 acerc (Robert)
#185 Jstephen1h
#186 MormonMike
#187 Skillet92
#188 MinnFlyer (Mike B.)
#189 cocobear (Dave Johnson)
#190 AncientCityFlyer (Mike)
#191 Cannonball200 (Eddie)
#192 Bkyrdflyer (Jeff R)
#193 althepal88
#194 oppie
#195 kim seyler
#196 ceije
#197 Airboss 45
#198 lablover
#199 ZebraOne
#200 GEORGE QUINN (posthumous Brother)
#201 Tmac48
#202 wreck-em-rich (Richard)
#203 cherry629
#204 Errol Levin
#205 n6iap Jimm
#206 Jason Mansfield
#207 Ken Mansfield
#208 sevans16
#209 rccrasher65 George
#210 Claude McCullough (posthumous Brother)
#211 Blackwidow (Tom)
#212 Handyman220 (Paul)
#213 rone1948 (Ron Elliott)
#214 catflyer
#215 ma mulcahy (mike)
#216 wingstrut
#217 wed-subawu
#218 p40warhawk67 (Daniel)
#219 Dash7ATP (Joe)
#220 Carl Hammond (posthumous Brother)
#221 Lins
#222 RCjunky67
#223 Jaybird (Jay)
#224 peterduplessis (Peter)
#225 dadrivet
#226 Stevemyers (Steve Myers)
#227 Rainbow1
#228 jymster James
#229 VOX (Albert)
#231 BobH
#232 jhambright (JohnH)
#233 Chuck l (Chuck)
WACO Sisterhood Roster:
S-1 Janelle (Lady Stickbuilder)
S-2 Sissy Nightstalker
S-3 Barb Barbee
S-4 LadyMango (Lynda)
S-5 BUMBLE GEE BEE (Gabi)
S-6 Sue Watz
S-7 Joanie Allison (Lady Cursor)
S-8 Lady RCBOATMANIAC (Christine)
Bill, AMA 4720
WACO Brotherhood #1
Old 12-15-2012, 04:41 AM
  #15773
nine o nine
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Bill, Polycrylic should do just fine on coverall. What paint will you use over it? Mitch
Old 12-15-2012, 06:26 AM
  #15774
BobH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How about.. dope? Nitrate specifically. It's a great sealer and helps with closing the weave. Probably the lightest there is.
BobH is offline
Old 12-15-2012, 02:36 PM
  #15775
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bob, actually the polycrylic is lighter than enough coats of nitrate to seal the weave. Plus it's water based, and there is no stink. Keeps the War Department happy.
Display Modes
