Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
WACO YMF
Old 08-12-2017, 02:12 PM
  #19051
tmac48
tmac48's Avatar
Originally Posted by mrdhud
tmac my friend used two pc of 3/4" plywood as a shim to mount the engine on. Hope this helps.
Thanks for that. I was thinking of doing the same but I thought it would be better to have a larger footprint at the firewall end. I have ordered a carbon mount from Comp arf that they use on the P47, and will see if I can adapt it to the Waco. I also have a alloy mount being manufactured that I will most likely end up using.Will post pics when I have them set up.
Regards tmac48.
Old 08-13-2017, 06:18 AM
  #19052
FMBB
Regards tmac48.
Hi Tmac,
I tried to attach two photos to show how I did the installation of the Moki. I placed an additional case in front of the firewall and made a separate bulkhead which is laminated with birch ply and carbon fiber. 2mm of ply and three layers of carbon (back side, between the 2 ply parts and front side). The aluminum engine tray was srewed to the back side of this separate bulkhead whereas the bulkhead itself was screwed by shock mounts to the case. Your approach to make a new engine tray is a very good one. A friend did this as well enlarging the center bore where the tray is attached to the engine. This gives you the advantage to have a much better access to the carb. and to the pressure line which might have to be removed after a while to clean it because there might be some crease getting in from the crankcase.
Peter
ID:	2227776   Click image for larger version
Old 08-13-2017, 05:45 PM
  #19053
Flyrc67
Bettsmums:
Could you please post a few pics on how you are dealing with the battery mounting for that 6 cell. Did you make a hatch? Very interested in how the electric version turns out as I have been thinking about doing something similar.
Thanks.
Old 08-13-2017, 10:33 PM
  #19054
tmac48
tmac48's Avatar
Pete thanks for the pics, yes that was another consideration of mine. Will post pics of the Comp ARF mount that has the right and down thrust built in but not sure that I want to go that route. It sure is neat and tidy though!
Regards tmac48
ID:	2227871   Click image for larger version
ID:	2227872   Click image for larger version
Old 08-14-2017, 02:13 AM
  #19055
tmac48
tmac48's Avatar
Talking
Originally Posted by ctflyboy
Terry TMAC48
Hope your Grandson is feeling better
George
George the little tacker is on the mend,home now 5 kg lighter very week but will make a full recovery!
regards tmac48
Old 08-15-2017, 05:41 AM
  #19056
bettsmums
Default Ready for the maiden flight
The plan is to maiden it this weekend weather permitting. It came out at 13 1/2 pounds ready to fly with the flight battery. I am using an old Hobby King SK 50-65-380kv motor with an 18-6 prop. The speed control is 125 amps. I haven't run it yet but expect around 2.2 Kw. The battery hatch is where the forward pilot would sit. I used a couple of magnets to hold it in place. The battery ends up being right on the CG so the weight doesn't really matter. The battery is a six cell 4000 with a 70C rating. I just made a plywood box where the fuel tank would go outlined by the original location of the hardwood engine mount beams. The plywood box extends about an inch in front of the original firewall. I also found that a liquid chrome marking pen from Molotow worked really well on the cowl blisters.
ID:	2228016   Click image for larger version
ID:	2228017   Click image for larger version
ID:	2228018   Click image for larger version
ID:	2228019   Click image for larger version
Old 08-15-2017, 06:08 AM
  #19057
tmac48
tmac48's Avatar
bettsmums that looks amazing terrific colour scheme!
tmac48
Old 08-15-2017, 08:04 AM
  #19058
toolman 1
Hello to everyone for the past few months I have been reading and enjoying this thread very much. It has inspired me so much that I bought both the 1/6 and 1/5 scale Waco plans to build, also just received 1/4 scale plans from Wendell Hostetler's. I have started cutting for the 1/5 scale so I look forward to applying the things I've learned here, I've been building since 1984 and its been a pleasure to see that some are keeping the craftsmanship of the hobby alive. Hope this thread stays alive for future builders and I would like to become a member of the brotherhood . I am new to posting on thread blogs so bare with me as I will be learning as I go, when I get pictures I will try to post them as I go. Have a blessed day!
Old 08-15-2017, 06:20 PM
  #19059
Flyrc67
bettsmums:
​​​​​​​ Great looking WACO!, and thanks for the info on the battery hatch. Good luck with the maiden.
Old 08-18-2017, 04:14 PM
  #19060
mrdhud
My Feedback: (48)
mrdhud's Avatar
Welcome to the Brotherhood
Lets welcome the toolman1 to the Brotherhood you will be Brother # 267.
Looking forward to your build.
Check out the revised manual may be helpful.
Wix.com clasicair created by mrdhud based on blank-website | Wix.com!
Old 08-21-2017, 12:13 AM
  #19061
bettsmums
Default Successful Maiden Flight
The maiden went very well. The plane flies like it is on rails and looks great in the air. The roll rate was excellent but I had to mix aileron into the rudder as the differential was not sufficient even with only 30% rate down. My left thumb is too lazy to always coordinate the rudder. The first day was flying on an 18-6 prop which is way to small for my power setup. I propped up to a 20-8 and there was still more left in the motor (1.8kw on the ground). The 20 inch prop looks too big so I settled for an 18-8 with a wider blade profile. I am pulling almost 1400 watts on the ground and can do 400 foot diameter loops from level flight. It flew equally well from asphalt or grass. I considered the Pica kit a bucket list kit to build but was a little disappointed in how much engineering was required to assemble everything. The finished result was well worth the work and I have received many comments about how good it looks.
ID:	2228819   Click image for larger version
ID:	2228820   Click image for larger version
ID:	2228821   Click image for larger version
Old 08-21-2017, 03:05 AM
  #19062
mrdhud
My Feedback: (48)
mrdhud's Avatar
Congratulations on your maiden flight bettsmums looks like you have a winner.
Old 08-21-2017, 10:09 AM
  #19063
Flyrc67
Bettsmums: CongratuLtions on the maiden and it sure does look great in the air! Could you please let me know what kind of flight times you were getting with the different prop set ups and battery combo you used. Thanks.
Old 08-21-2017, 11:23 AM
  #19064
bettsmums
Default Battery Life
I only used a China Hobbyline 6s4000 70c battery pack. I didn't fly until a timer went off. The only flights were an 18-6 and an 18-8. I flew around 5 1/2 minutes and was at 3.94 per cell. I was only at full power maybe 10 - 15 seconds during the flight as it takes very little thrust to fly scale like. The motor and speed control were at air temperature right after landing. The red brick speed control does not have any on-board telemetry so I can't be more precise. I would think that 8 minutes would be possible if I flew it scale. The battery is on the CG so you could put in 5000 - 6000 battery and go even longer. I have been flying a Freewing AvantiS EDF jet and my timer goes off at 2 1/2 minutes on it with the same battery so the Waco seems like it is flying forever. The AvantiS pulls 2.4kw and flies at full throttle more than 75% of the time. If I went with an even bigger 20-10 prop that would cut the safe time down to less than four minutes but it would have enough thrust to hover on the prop but who wants to see a YMF do 3D aerobatics? .
Old 08-21-2017, 05:34 PM
  #19065
Flyrc67
Thanks bettsmums for the battery info, I appreciate it.
Old 08-25-2017, 12:07 PM
  #19066
tih
Just wanted to share this: today, I received a package in the mail, with DVDs of WACO blueprints, from Aircraft Reports - Aircraft Helicopter Engines Propellers Aviation Manuals Blueprints Profile Publications Video. The contents look like just what I wanted, but there's more: as can sometimes happen in the mail, one of the DVDs was partly damaged, and the other completely unreadable. I contacted the company by email, and now, about an hour later, I have the complete data set. They set up a temporary download area for me, so I could pull it all down over the net. Now, that's what I call service!
Highly recommended!
Old 08-27-2017, 04:08 AM
  #19067
rickj
My Feedback: (213)
rickj's Avatar
Hello,
I would like to join the Brotherhood.
Thanks, Rick
Old 08-27-2017, 01:59 PM
  #19068
mrdhud
My Feedback: (48)
mrdhud's Avatar
Lets welcome rickj to the Brotherhood you will be Brother # 268.
Old 08-27-2017, 02:09 PM
  #19069
mrdhud
My Feedback: (48)
mrdhud's Avatar
David ran his new 250 moki with electric starter today what a sweet sounding engine. Will post video when I can.
ID:	2229587   Click image for larger version
Old 08-27-2017, 06:30 PM
  #19070
mrdhud
My Feedback: (48)
mrdhud's Avatar
Heres the video
Old 09-07-2017, 03:36 AM
  #19071
dirtdart
dirtdart's Avatar
I just got back from three months in England. My basement flooded, taking with it the fuselage. Wings and rest of the wood survived. Now I get to try to find another kit or try to reproduce the parts. Talk about a kick in the junk....
Old 09-07-2017, 04:02 AM
  #19072
mrdhud
My Feedback: (48)
mrdhud's Avatar
dirtdart sorry about your flood sick feeling in the gut i'm sure. If you can't find a kit you can download all the templates and cut all new parts here.
Old 09-07-2017, 04:19 PM
  #19073
dirtdart
dirtdart's Avatar
Thanks. The flooding also destroyed 25 years of army plaques, all of my aviation books, pretty much all my memories.... Really sucked.
Old 09-09-2017, 05:38 AM
  #19074
astrohog
astrohog's Avatar
I have a pristine, NIB kit that I would sell. PM me if you are interested.
Regards,
Astro
Old 09-10-2017, 12:11 PM
  #19075
mrdhud
My Feedback: (48)
mrdhud's Avatar
Hope all the Florida brothers stay hi and dry. Stay safe until this hurricane passes.
