Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
WACO YMF
Old 04-18-2007, 06:49 PM
  #2026
Jim Henley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: WACO YMF
Hey, Ron It's good to hear from you!
Jim Henley is offline
Old 04-18-2007, 07:08 PM
  #2027
Stickbuilder
Stickbuilder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: ronj10
Good job on the tshirts
Put me down for (2) XXL
Ron,
Where have you been hiding. Good to see you back buddy. Don't be such a stranger.
Bill, AMA 4720
WACO Brotherhood #1
Stickbuilder is offline
Old 04-18-2007, 07:48 PM
  #2028
CROWMAN17
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Stickbuilder,
I have both the 1/5 and 1/6 Pica kits to build, and feel the WACO is the sharpest bi-plane around. The information from this thread has really given me the modivation to start one of the kits instead of just looking at them! I also would like to join the Brotherhood!
Marc
CROWMAN17 is offline
Old 04-18-2007, 07:59 PM
  #2029
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Stickbuilder
Okay, Here is the roster to date.
WACO BROTHERHOOD MEMBERSHIP:
#1 stickbuilder
#2 Hughes500E
#3 Jim Henley
#4 mmattockx
#5 CTflyboy
#6 michaelj2k
#7 Ronj10
#8 gwulle
#9 jim schroer
#10 Skinny Bob
#11 Bart5495
#12 Pimmnz
#13 HarryJ
No. 14 Old Git
#15 ChrisMH
#16 Nerevar
#17 Ricatic
#18 Clay H.
#19 Tripp2Loo
#20 KHodges
#21 Bill Hogue (WACO One)
#22 Mangolo (Waldo)
#23 av8ter
#24 yel914
#25 damifino
#26 skylarkmk1
#27 Jacque
#28 Edwin
#29 AROPLANE
#30 CubNut (Anthony)
#31 BQuartucy (Bob Q)
#32 AERORON
#33 funkymusic
#34 RCOutlaw
#35 obo (Bob)
#36 Jackk36 (Jack)
#37 fatherrooster (Jim)
#38 Ilikebipes
#39 Kestrel0222
#40 CROWMAN17 (Marc)
#47 Todd (NightStalker)
#55 vasek
#66 Mobyal
Guys, once again, we have a new Brother. Let's all welcome Marc (CROWMAN17) as Brother #40. Marc, we all wish you the best, and good luck with your WACO's. We will be here for you when you require assistance, or encouragement.
Bill, AMA 4720
WACO Brotherhood #1
[/quote]
Old 04-18-2007, 08:24 PM
  #2030
khodges
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bill- You wanted to see the fuse after I primed it, well here it is. It amazed me how smooth it came out without sanding the primer. The flash kind of washed out the tail detail.
I haven't primed anything else yet, I want to mount the fittings for the flying wires on the wings before I spray them, but all the doping (three coats) is done.
ID:	667597   Click image for larger version
ID:	667598   Click image for larger version
khodges is offline
Old 04-18-2007, 08:32 PM
  #2031
Jim Henley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ken,
Waaayyy Cool! I need to get back in gear and finish covering the fuse on mine, so I can get it in primer. The detail on your fuse is just great! Did you use white or light grey primer? It looks white, but I guess that could be the flash?!?
Old 04-18-2007, 08:53 PM
  #2032
khodges
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's white. Rustoleum Clean Metal Primer. I brushed on the first coat, after seeing what a friend's plane looked like using the primer as a filler for the fabric. his technique using a foam brush must have been better than mine, so I sprayed a second coat. I may not even have to sand it before painting, it came out so smooth. I'm just gonna spray the wings. There will be some color on the plane by weekend.
khodges is offline
Old 04-19-2007, 12:46 AM
  #2033
EscapeFlyer
EscapeFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey guys, I have to admit, I really don't like the way the wing builds. For some reason, I simply don't like the spar exposed to the bottom of the wing. Now -obviously- it doesn't effect anything, but I have a hard time keeping the sheeting flush to the bottom of the spar, and the wing is not built in three seperate pieces.
Do you guys change this proceedure at all, or am I just being stupid!!! (Be honest!)
EscapeFlyer is offline
Old 04-19-2007, 04:51 AM
  #2034
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Ilikebipes
I do build the wings as 3 seperate pieces. Also the spar joiners are way too small, so I make them much longer. I build the center sections first, and then the outer bays. I'm not crazy about the spar being exposed to the wing bottom, so on this one (the one that I'm building now) I'm adding 1/16" cap stripping top and bottom. These will begin at the leading edge and terminate at the trailing edge. At the leading edge they will taper away to nothing for the final 1/4" to replicate the tubular leading edge of the full scale. This should eliminate the spar showing on the covering and look much more scale like. I have not had any problem with keeping the D-tube sheeting even with the spar, but then again, my technique may differ from yours. Think about the cap strips, and let me know your thoughts on this techinque.
Bill, AMA 4720
WACO Brotherhood #1
Old 04-19-2007, 05:29 AM
  #2035
pimmnz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check out the the piccies on post 270, page 80 and pretend that the rib is sheet balsa. The capping strip just holds the fabric off the spar, and is the same thickness as the L/E sheeting. This allows a full depth spar, that doesn't show through the finish or affect the wing profile.
Evan, WB#12.
pimmnz is offline
Old 04-19-2007, 06:36 AM
  #2036
yel914
yel914's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jay, Excellent work on the T shirts. Please put me down for 2, XL.
yel914 is offline
Old 04-19-2007, 03:05 PM
  #2037
EscapeFlyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys.
My building techniques fall a lot more in line with what you said Stickbuilder. I just do it that way, the way I feel comfortable with.
Old 04-19-2007, 06:04 PM
  #2038
damifino
damifino's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are some pictures of my progress so far. I built up the crutch by laminating three 1/8" and one 1/16" sticks for each side.
We are getting there on the tee shirt order; the target is to print 72 shirts. I think we have requests for 28 so far.
ID:	668194   Click image for larger version
ID:	668195   Click image for larger version
ID:	668196   Click image for larger version
damifino is offline
Old 04-19-2007, 06:25 PM
  #2039
jim schroer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll be ordering a pair ,L, and you did a super job on them. Thanks for the extra mile. Jim #9
jim schroer is offline
Old 04-19-2007, 06:42 PM
  #2040
damifino
damifino's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, everyone, for the great comments on the shirt design. This may turn into a deal where there is a 'yearly edition' of Brotherhood shirts............
damifino is offline
Old 04-19-2007, 08:44 PM
  #2041
Jim Henley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jay,
The fuse looks good, are you building this from a kit or from scratch? The reason I ask is the way the numbers are printed on the formers !
Old 04-19-2007, 09:27 PM
  #2042
ChrisMH
ChrisMH's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
2x XL T-Shirts for me!
ChrisMH is offline
Old 04-19-2007, 10:22 PM
  #2043
damifino
damifino's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Jim Henley
Jay,
Thanks, I'm scratching it. I bought a set of 3/8" rubber stamps at the craft store. I cut a batch of parts and stamp them as I go. I'll post a picture of them sometime.
damifino is offline
Old 04-19-2007, 10:38 PM
  #2044
damifino
damifino's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
We are halfway there on the shirt count!
damifino is offline
Old 04-20-2007, 04:32 AM
  #2045
Stickbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jay,
I like the rubber stamp thing. It beats using a roller ball pen all to the dickens. The kit never had the parts identified at all.
Bill, AMA 4720
WACO Brotherhood #1
Old 04-20-2007, 10:00 PM
  #2046
khodges
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jay, there's a Big Bird Fly-in at Mocksville tomorrow, just found out about it a while ago. A bunch of us will be there.
All the wing wire fittings are in place, time to shoot more primer.
khodges is offline
Old 04-20-2007, 10:07 PM
  #2047
damifino
damifino's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Our whole neighborhood is having yard sales tomorrow, wish I could be there at Mocksville.. The Statesville club will be having their big bird deal in June I think. I try to go to that one every year.
damifino is offline
Old 04-21-2007, 07:59 AM
  #2048
pimmnz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Damifino,
Would love a couple of `L' shirts, but you will have to send them to New Zealand, and we will have to find some way of recompense, Ideas?
Evan, WB#12.
pimmnz is offline
Old 04-21-2007, 10:35 AM
  #2049
damifino
damifino's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got any ideas? Mail a money order in U.S. dollars?
damifino is offline
Old 04-21-2007, 01:54 PM
  #2050
Yank II
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice shirts!![sm=thumbs_up.gif][sm=thumbs_up.gif]Put me down for 2ea XXL.
Jim
WACO Brotherhood #37
Yank II is offline
Display Modes
